Farrah,
Is the lpm such a big deal? Seems the sceptism is 2-fold:
1- No way that cell can produce that much gas
2- that lpm ain't cut it to run a run off
Obviously, the whole supposed point of FF's work as presented so far:
1- Claimed high pressure (you'll see 1lpm when it's really 4lpm)
2- Output gas is not standard HHO as we know it from basic electrolysis.
I'm am not even a novice compared to researchers like yourself, but 40 or 50lpm, at that pressure...why not? The cell seemed active enough, and there's the claimed ~4x compression going on.
Also, how are you going to measure 50lpm? Sure, fill a garbage bag with im easy enough. But I'd not want a couple buckets worth of HHO (let alone a claimed more punchy gas) to be in an enclosed container like that. It's just a lot of gas.
We can all come up with thousands of simple tests for FF to lend credibility to his work. If he could just fill a lab tube with his HHOi, for others to test the blast output of... Put it in a balloon and let us here the boom, compared to boring old HHO.
I'm quite a talker myself, but FF is making his viewers look silly to believe it all. Disclosure is a formality of mere minutes of uncu video, as we all concluded before. I was telling friends how I was sure this guy really did IT, but I'm not using this example anymore. I just cross my fingers and wish.
ara mixture).[1] Notably, the boiling points of parahydrogen and normal (3:1) hydrogen are nearly equal; for parahydrogen ∆Hvap = 898 J/mol at Tb = 20.277 K. It follows that nearly all the residual rotational energy of orthohydrogen is retained in the liquid state. Orthohydrogen is consequently unstable at low temperatures and spontaneously converts into parahydrogen, but the process is slow in the absence of a magnetic catalyst to facilitate interconversion of the singlet and triplet spin states. At room temperature, hydrogen contains 75% orthohydrogen, a proportion which the liquefaction process preserves if carried out in the absence of a catalyst like ferric oxide, activated carbon, platinized asbestos, rare earth metals, uranium compounds, chromic oxide, or some nickel compounds[4] to accelerate the conversion of the liquid hydrogen into parahydrogen, or supply additional refrigeration equipment to absorb the heat that the orthohydrogen fraction will release as it spontaneously converts into parahydrogen.
