P.S. Each Circuit must have a frequency adjustment from 50HZ to at least 20 MHZ
as an initial discovery
some questions for those who know:
1. Signal A to EEC Relay for consuming device
2. Signal Vc to VIC / EEC Relay for Ionizer
The two above (1&2) go hand in hand according to FIGURE 11 one is on and the other is off...alternating
3. Signal L to LED Light Array on Ionizer
4. Signal C to electromagnetic coils at entry and exit of Ionizer
These two (#3 & #4) need to have independent frequency adjustments
5. Signal Va to VIC for cylinders 1, 3
6. Signal Vb to VIC for cylinders 4, 2
maybe (5&6 ) can be combined into one?
7. Signal P to fuel pump
Circuit 7 needs to sense pressure and keep it steady at 125 LBS
8. Signal S1 to fuel solenoid cyl 1
9. Signal S2 to fuel solenoid cyl 2
10. Signal S3....
11. Signal S4...
These 4 (8-9-10-11) are controlled by electric eye/ rotating window in distributor. should be easy... interfaces with throttle control
12. PLL Circuit that tracks resonance for Signal Va (taper resonant cavity x 2)
13. PLL Circuit that tracks resonance for Signal Vb (taper resonant cavity x 2)
14. PLL Circuit that tracks resonance for Signal Vc (ionizer chamber)
finally the hardest parts (12, 13, 14)
!!! found a missing entry already..
ADD:# 15
TOC Ver 1.1
10. Signal S3....
11. Signal S4...
15. Signal T for pulse width interface to fuel solenoids S1 - S4 (Throttle)
