Stanley Meyer Explained
  • boguslaw
    It may sound funny but all of you may have right.
    Surely Meyer method is pure potential but the effect could be large power generated from electrons pulled from water which is natural ground.
    Did you saw Kapanadze device videos on youtube ? He is sucking displacement current from ground using high frequency HV in resonance with telluric current I suppose.
    100W=1A at 100V = 0.001A at 100000V
    You cannot get 1A from ground fortunately but what about 0.001A=1mA ?
    What would you need ? Or course 1000000V with no current !
  • Oneminde
    @lamare
    The wite pouder is also known as Ormes - read the pdf!
  • lamare
    Hi all,
    There's a whole lot of info on a.o. Stan Myer at:
    The H2earth Instititute - CYBRARIUM: The Waterfiles Archive
    The most interesting document is this one:
  • sebosfato
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    another book
  • tutanka
    Laser leds inside GP start action of collision amplified from glass lens that summed to positive corona discharge producing plasma, for it GP is provided of glass lens, these focalized lasers and obtain at the same time Leds protection from reaction. But as explained are present others products from this reaction.
  • sebosfato
  • h20power
    Quantum ionization
    In quantum mechanics, ionization can still happen classically, whereby the electron has enough energy to make it over the potential barrier, but there is the additional possibility of tunnel ionization.
    [edit] Tunnel ionization
    Tunnel ionization is ionization due to quantum tunneling. In classical ionization, an electron must have enough energy to make it over the potential barrier, but quantum tunneling allows the electron simply to go through the potential barrier instead of going all the way over it because of the wave nature of the electron. The probability of an electron's tunneling through the barrier drops off exponentially with the width of the potential barrier. Therefore, an electron with a higher energy can make it further up the potential barrier, leaving a much thinner barrier to tunnel through and, thus, a greater chance to do so.
    [edit] Non-sequential ionization
    When the fact that the electric field of light is an alternating electric field is combined with tunnel ionization, the phenomenon of non-sequential ionization emerges. An electron that tunnels out from an atom or molecule may be sent right back in by the alternating field, at which point it can either recombine with the atom or molecule and release any excess energy or have the chance to further ionize the atom or molecule through high-energy collisions. This additional ionization is referred to as non-sequential ionization for two reasons: One, there is no order to how the second electron is removed, and, two, an atom or molecule with a +2 charge can be created straight from an atom or molecule with a neutral charge, so the integer charges are not sequential. Non-sequential ionization is often studied at lower laser-field intensities, since most ionization events are sequential when the ionization rate is high.
    [edit] See also
    Does this sound like what we are doing? Now re-look at the video of a gas processor without the LEDs in action: YouTube - Lec 10 | MIT 6.013 Electromagnetics and Applications, Fall 2
    and to see the relaxation time of water and the maximum image charge voltage it will take before spliting into smaller droplets: YouTube - Lec 9 | MIT 6.013 Electromagnetics and Applications, Fall 20
  • sebosfato
    I'm not surprised he gave you this answer. To excite the oxygen molecule you would need x-rays. This proves that the visible light laser energy stanley was using was not to excite oxygen but the electrodes to free up electrons allowing them to collide. Yes the high voltage is important and is related to the spacing. Read this book to understand everything about collision could help you all.
    take you own conclusions
    This is the book i mentioned
    And follows 3 links you should check to understand what i'm saying.
    Wave-Particle Duality
    Work Functions for Photoelectric Effect
    Visit http://www.energeticforum.com/renewa...eyer-true.html and you'll see the light
    Best Regards
  • HMS-776
    Interesting...
    I have wondered a lot lately about the role of the LED's in the Gas Processor. It is my belief that if the voltages are high enough to ionize the atoms then they must also excite the atoms....I think the LED's may have been used only to give the proper amount of energy to keep the atoms from releasing a photon and going back to a lower state, Or possibly what you mentioned above, although right now I need to do more research to fully understand it.
    I recently talked to someone who is in the physics dept at nist.gov about the Gas processor, not mentioning what it was, only how I read it to work so as not to get a complete denial of such a device. My final answer was this:
    sorry, any practical source of radiation that will efficiently convert O to O4+.
    That will be done more efficiently by plasma processes such as you mention below.
    Modeling of such processes tends to be fairly complicated. I do not see a simple obvious
    role for LEDs in enhancing such processes - only detailed modeling would reveal
    opportunities. LEDs now operate only down to wavelengths above 200 nm, which are
    insufficient to excite multiply-ionized oxygen atoms.
    Thanks for your interest in the programs of the National Institute of Standards and
    Technology.
    Below is the email I sent-Above is the reply
    The reason why I asked you about the Oxygen atom is to understand the following:
    I have recently learned of a device used to obtain hydrogen decay in an easy way, similar the Muon process.
    Air is pumped through a high voltage ionization chamber which ionizes the Oxygen Atoms (up to 4 electrons) and at the same time laser energy (from LEDs) is used to excite the Oxygen atoms to an energy level high enough to ionize the hydrogen atom (>1312KJ/Mol I think).
    The ionized, excited Oxygen is added to a mixture of hydrogen gas, and when the gas is ignited the excited Oxygen ionizes the only electron from the hydrogen atom, causing atomic decay of the hydrogen atom.
    I have seen pictures of the device as well as a patent.
    I wanted to ask you what you think about such a device. If it does work what wavelengths of LEDs would it use, and would the electric field change the needed wavelengths?
    Again, I thank you very much for your time. I hope what I shared can also be of interest to you.
    Seeing what he mentioned above. Makes me wonder if we need a certain V/cm and plate spacing to accomplish the task correctly...I think there may be a little more going on with the Gas Processor than previously believed...
  • sebosfato
    Originally posted by HMS-776 View Post
    Now my question is:
    Do we know yet, has anything been confirmed about the wavelength of the LED's used in the Gas Processor?
    I have been wondering the following:
    While reading thorough one of Stan Meyers patents he mentions the Gas Processor inducing resonance of the electrons.
    It really makes me wonder if this induced resonance has any effect on the wavelength that the atoms will absorb?
    When we have an atom in a high voltage field we weaken the atom because we are reducing the speed at which the surrounding electrons flow around it. It really makes me wonder what effect this could have on the photon absorbtion wavelengths?
    If you want to ionize a molecule in a high voltage field you need free electrons to collide with the ones you want to knock out, for this stanley meyer used the lasers to overcome the surface barrier of the electrodes as to allow them to emit free electrons that will fly from the cathode to the anode and being the molecules in the middle they collide with them liberating electrons and photons that will collide with another molecules liberating even more electrons this is the chain reaction meyer talk about."gas production grows up exponentially under resonant condition" On the anode the current will be much higher than cathode as free electrons will be absorbed by it due to the high voltage.
  • HMS-776
    Now my question is:
    In a general outline of the method, a first gas mixture including at least a portion of hydrogen and oxygen gases is provided. The gas mixture is subjected to a pulsating, polar electric field whereby electrons of the gas atoms are distended in their orbital fields by reason of their subjection to electrical polar forces. The polar pulsating frequency applied is such that the pulsating electric field induces a resonance with respect to an electron of the gas atom. A cascade effect results and the energy level of specific resonating electron is increased in cascading, incremental steps.
    -Stan Meyers Patent # 4,826,581, Paragraph 3
  • sebosfato
    Onemind do you understand what i say? the picture i showed? I'm totally crazy? is incredible people decide to ignore what is write in the books about Townsend coefficients. Is exactly the same schematics that meyer showed about the production of the gases being increased exponentially under resonant action. He just said one thing and was another thing. He gave the tips one that have studied seriously high voltage books should understand his technology only looking at it. Because one that knows, knows he was changing the words to protect his technology. But looking at his drawings and knowing how resonance really works, and collision too one can do it. For example have you ever heard about Ravi he came up with the clue that the electrodes must have a coating of calcium oxide but why calcium oxide??? That he didn't said.... As many other things.... Calcium is a metal with very low working function. Look for what I'm talking about...
    Visit my thread you're all welcome to learn a lot. No ignorance lists up there.
  • HMS-776
    The isolated ground I was referring to is basically meaning that the negative of the high voltage transformer for the gas processor is connected to the outer electrode.
    NOTE: That is only the case if your capacitor plates are not close enough to take advantage of the polarization effect that will create a negative charge all on it's own. The effect has many names, Stan calles it "electron clustering", it's also known as polarization, electrostatic induction, induced polarization charge, etc.
    Electrostatic induction - Wikipedia, the free encyclopedia
    When a charged object is brought near an uncharged, electrically conducting object, such as a piece of metal, the force of the nearby charge causes a separation of these charges. For example, if a positive charge is brought near the object ,the negative charges in the metal will be attracted toward it and move to the side of the object facing it, while the positive charges are repelled and move to the side of the object away from it. This results in a region of negative charge on the object nearest to the external charge, and a region of positive charge on the part away from it. If the external charge is negative, the polarity of the charged regions will be reversed.
    I just want everyone reading these posts to understand how in all of Stan Meyers work the principle of splitting the water is the same. High volatges of opposite polarity! The only thing that has changed is the shape and size of the devices used.
    "electron clustering effect" produces a Negative Electrical Voltage Intensity in equal magnitude to the Positive Electrical Voltage Intensity
    -Stan Meyer, Technical Brief page 8-3 (describing electrostatic induction creating a negative charge within the injectors, resulting in opposite charges which are used to split the water molecule)
    Just remember it depends on the spacing, as to whether or not you can use the principle described above. If your capacitor gap is wide your result is a reduced capacitance which results in an increased resonant frequency, and greater changes in resonance, and the need to use a transformer which can supply both a positive and negative charge.
    Everyone's design will be different, but as long as they work we have achieved our goal!!! Good luck to everyone on this forum!
    H2OPOWER, if there's anything else I can do with the circuits, let me know....Hope you've read the posts on the PLL, they helped me understand how it works much better!!!
  • Oneminde
    @sebosfato
    He does not respond to us anymore... you can talk to the rest of the "group".
  • sebosfato
    Check my last posts h20 on my thread you'll see i talk about how to make it self oscillating... I would advice you the opamp i'm using for the resonant scaning circuit is lf411.
