Water Sparkplug
This topic is closed.
  • Apologies!
    Smw1998a and Aaron
    Apologies for my previous assertion - I really thought that frequency would be the limitation.
    So please could I ask at what frequency was the video made? Would it wear out the spark plug? Is the current to high to be feasible? Does it still ignite water? What is the next step?
    Gazza
    • @smw1998a
      Hello! Congratulate, well successfully (http://de.youtube.com/watch?v=vdxBbb-tR3s)! Unfortunately I do not have so much luck to copy a such circuit. Can you give us please an exact connection diagram, which you used in the video? thanks in advance!
      YouTube - Videos von multiuser0815
      • Attached Files
        • @smw1998a
          I was planning on making a somewhat more elaborate circuit however I don't have time at the moment to develop it but what I can do is to respectfully help you to refine yours:
          1. Use triac (preferably alternistor sort) instead of thyristor. It would allow capacitor/primary circuit more free oscillations. It should also be
          2. Your optocoupler/transistor combination is not impervious to self-triggering or latching up. You should rather consider using dedicated triac triggering optocoupler incorporating diacs. One without the zero crossing detector that I often employ is MOC3021 and I suggest that you use additional snubber network to prevent uncontrollable triggering.
          3. What you should also do is to employ another alternistor between AC power supply and diode bridge. You could use another MOC30xx optocoupler but this one with zero crossing detector (so that you don't need additional serial resistors).
          4. You should employ additional circuitry (bistable logic comes to mind) to have those two triacs (the charging one and discharging one) working in opposite cycles. It's necessary to prevent latching up of the discharge triac when the capacitor is being discharged and AC mains suddenly start pushing current into the system. The reason is that if primary impedance is sufficiently low the current will flow from bridge (effectively from AC source) and back through primary possibly keeping the discharge triac opened.
          5. A slight pause have to be introduced between those two cycles (during which both triacs are not driven) in order to allow for the charging triac to close completely during the zero crossing point of the AC cycle.
          6. The periods of charging cycle can be calculated by common formulas that takes into account AC voltage and frequency as well as the capacitor capacitance. If you calculate it properly you can manipulate charging time in order to have faster charging by introducing higher AC voltage but shortening the charging cycle. That would allow for higher charge/discharge frequency.
          One must also have in mind fact that triacs and thyristors are not high frequency devices. Also, the bigger the current rating the slower it is to open thus lowering it's maximum frequency even more. As I can see you already know that.
          If you have time and knowledge you can easily make suggested adjustments and significantly raise efficiency and max frequency of your circuit. If not, please be patient since I will most probably have some spare time next week to develop full circuitry myself. I would prefer to use microcontroller (as I'm sure you would too) to allow for simple, precise periods tweaking but I guess I will use one or two 556's in order to make things simple and cheap enough for amateurs to build.
          That being said I respect your idea and I just want to help you refine your circuit (that is if you need my help). I will gladly discuss further development with you over PM or mail (in order to keep the thread clean from unnecessary details) but I'm off untill tuesday. Keep up the good work and please don't be offended by my suggestions.
          http://www.nequaquamvacuum.com/en/en...n/alt-sci.html
          http://www.neqvac.com
          • Originally posted by smw1998a View Post
            Hello All
            @gazzzwp
            Looks like some of you are discovering what I suspected a few days ago from my own trials - that the effect is not reproducible at faster frequencies.
            I disagree. Switching speed can be increased however, so will current draw. How far the frequency of the ignition coil can be pushed in this circuit is unclear. In a car using contact breakers, the time of induction is limiting factor in the operating frequency of the coil. In our circuit the time it takes to charge the capacitor is the limiting factor using solid state switching. The relay slows the circuit considerably.
            Here is a link to my solid state experiment.
            YouTube - Water Sparkplug II
            Regards Lee...
            @smw1998a, excellent circuit development and video presentations.
            Luc
            • scr discharged cap
              Originally posted by gazzzwp View Post
              What is the next step?Gazza
              Follow the concept of what SWM is doing with the SCR discharged cap. As long as the power source keeps the cap charged up, you cannot get a frequency too high with an engine that the circuit cannot keep up with.
              This is basically already what an off the shelf CDI does except it is charged from a 12v source.
              • great spark vid!
                Great vid and thanks for bringing awareness to Energetic Forum!
                Hello All
                @gazzzwp
                Regards Lee...
                  Aaron is quite right. CDI is perfectly capable of charging its main cap at red line maximum engine rpms. CDI basically takes the 12 volt battery input, uses a step-up transformer to boost the voltage to between 400 and 600V, and a charging circuit using a rectifier (to prevent premature discharge) charges the main cap. At this voltage range, the cap is charged nearly instantaneously. A triggering circuit then breaks the charging circuit, allowing the cap to discharge through the ignition coil primary.
                  Lee, have you measured the actual voltage applied to the cap through your ss charging circuit? Nice diagram, and I enjoyed your video.
                  Best regards, Rick
                  • >I can't find the photo of S1R's spark plug. Can you post a copy here?
                    I also don't have any pictures of his plugs. I was just quoting his message, he never show picture I think ...
                    tq
                    MDG
                    • Great Demo, Lee
                      Lee,
                      Great demo of the SCR capacitor dump system. It shows that higher speed operation is possible and that solid-state systems are the way to go to get up to "engine firing speeds". It also shows, with out a doubt, that Luc has given us a "miracle" breakthrough with the HV diode trick!
                      Your control circuit seems to work very well, but it might be unnecessarily complicated. I remember when I was working with John Bedini on the first SCR cap-dump battery chargers run from the SSG, that the SCR was able to reset itself as long as the capacitor was being charged with intermittent pulses. As long as there was a pause in-between the charging pulses, the SCR would reset automatically, and we didn't have to turn the charge system off to dump the cap. Even some of the schematics Aaron has shown me of commercial CDI's don't look like they shut off the cap charging circuit when they dump the cap with the SCR.
                      Just thinking out loud here, but there might be a simpler way..... (Lighty, I consider your suggestions the "professional" way to go for a circuit that will work perfectly!!! I'm just trying to get more "backyard tinkerers" to try the experiment, too.)
                      Actually, that you are getting all of that PUNCH from a 4uf cap is very impressive!
                      Peter
                      Peter Lindemann, D.Sc.
                      • metal spheres
                        SWM,
                        Do you have any tiny metal spheres you could put that spark to? I might get some copper bb's to solder at the end of some copper rods. I want to see really what the spark difference is with the same power with and without spheres.
                        • Comment
                          • Hi guys,
                            I have my hands full with other replications at the moment (Im not superman like JETIJS is ) but I stumbled across this the other day while looking for parts.
                            I dont know if it is of any help or has already been mentioned, I just saw Cap Discharge and thought of this thread, along with other Bedini devices...
                            Jaycar Electronics
                            • Hi, smw1998a,
                              forgive my stupid, which H11D1 do you used in your circuit?
                              • H11d1
                                Hello adamhy,
                                Here is a link to the data sheet
                                http://komponenten.es.aau.dk/fileadm...Opto/H11D1.pdf
                                Regards Lee...
