Water Sparkplug
This topic is closed.
  • Yes, that would be very helpful.
    Anyway, dingo, try to connect the primary of the ignition coil in reverse and/or to provide a small air gap (1mm) between the HV and the LV circuit. The LV must be allways connected to the spark plugs.
    The spark plugs and spark plug wires must be resistorless.
    At the same time, it probably matters how the capacitor is connected inside the CDI. My CDI had it connected to the ground and to the ignition coil. Then the thyristor (SCR) connected between the ignition coil and the ground.
    Cheers.
    Real PEACE from the Prince of Peace: Jesus Christ!
    • very simple, but reliable cdi schematic
      • What type of transformer do You use? Just curious.
        I am not shure, but You should probably connect the HV diode in reverse.
        As I said before, in my CDI the capacitor was connected different from your setup. See 4A in the diagram below.
        • @Dingo
          Dingo, your diagram looks correct for the basic circuit.
          Kinetix, the diode is correct if the ignition coil is positive polarity.
          • Hydrogen/plasma mods June issue of DieselPower mag
            I subscribe to DieselPower. The last couple of issue's have ads in them for hydrogen assist addons for diesel engines. This months issue has a small article about research at Southern California's Combustion and Fuel's Research Lab. They are doing plasma research!!! DieselPower is currently talking to them and I think they will be doing a demo which they will talk about in August's edition.
            David P
              hmmm....i dont measure any voltage at the anode. I can measure 300V on the other side of the Cap. but not on the diode side
              on a separate tangent: ...if i disconnect the anode side of diode from the cap, and let the CDI fire, there is all kinds of backEMF coming thru the diode...can this not be put to work somehow?
              • Hydrogen flame speed and WFC gases speed
                Detonation - A Must for Hydrogen
                In order to do work on a piston, the fuel-air mixture needs to burn at a speed faster than the piston is moving. The following discussion exclude hydrogen detonation, which is much different from combustion. At stoichiometric ratio (no air nitrogen?), hydrogen (uncertain H2 and O2 mixture, with HHO ?) flame speed has been reported up to 3.46 m/s [11.35 feet/second] which would be nearly an order of magnitude slower than gasoline 40 m/s [from 70 up to 170 feet/second], and at lean mixture, the hydrogen flame velocity decreases significantly. However, engine experts are not working in stockiometric condition but report hydrogen-air mixture flame front speed and gasoline-air mixture flame front speed accordingly.
                Stochiometric is an ideal situation which does not occure in IC. With gasoline, engine do not run exactly stochiometric mainly to preserve the exhaust valve from overheating, and to reduce NOx production. Quite the same with hydrogen in combustion engine. Difference in comparison is also with the mixture power density because hydrogen is a gas with a low power density. Per pound hydrogen is more powerful but at atmospheric density, hydrogen is less powerful compare to gasoline mixture. Matter may still be open to discussion, but lower hydrogen flame speed observed in IC engine condition is a disadvantage shared with most other gaseous fuels. This is why a detonation capable engine is so important to overcome these limitations. Source: Mark's Standard Handbook for Mechanical Engineers, Section 9, Internal Combustion Engines, Flame Speed, more at
                Top 10 nền tảng affiliate network hoạt động hiệu quả nhất hiện nay. Tìm hiểu chuyên sâu về nền tảng tiếp thị liên kết, phân loại lợi ích, và các chiến lược tối ưu để thành công trong lĩnh vực affiliate.
                An average vehicle engine rotating at 2,000 rpm (33 revolutions per second) produces piston linear speed of 45 feet/second in the middle-stroke, which is already 5 times faster than the hydrogen flame front speed ! The fact that a hydrogen-air mixture has a flame front speed of about 1/10 that of a gasoline-air mixture contributes to explain why hydrogen engines only run at reduced power and low rpm under load. However, the detonation mode is extremely rapid and totally removes this limitation to hydrogen. This is why the detonation mode (not compatible with piston, but with the Quasiturbine) is somewhat critical for the future of the hydrogen engine.
                Quasiturbine> Type> Hydrogen
                Al
                • YouTube - PLASMA IGNITION SYSTEM
                  • Originally posted by tutanka View Post
                    Plasma in fact is only UV and heat togheter.. for that reason UV have an important part inside process.. of corse normally UV don't have enough force for dissociate water but maybe in sequence can be.. about meyer injector plug.. that is very similarry to old WFC but include also plug inside.. water fuel isn't burnable as some peoples think.. is only an ions mixture ready to react inside injector plug.. create and burn N2H4/N2O at the same time releasing thermal explosive energy .. on the same principle you can create NH3/N2O using water PH <7 and use directly inside engine.. plasma is needed for start reaction inside chamber? Maybe yes .. maybe not.. next information
                    Keep in mind that with plasma you obtain UV and heat .. if you use copper wire you remove also oxygen from air forming copper oxide around the wire .. maybe is the same method used from meyer.. can be possible that EEC is in fact EOC (extraction oxygen circuit) formed only from copper wire resistor?
                    Al
                    • cold start
                      Fabrication and testing of an enhanced ignition system to reduce cold-start emissions in an ethanol (E85) light-duty truck engine: G.P. Gardiner
                      14 mb document including plug modification for plasma with tungsten.
                      Information Bridge: DOE Scientific and Technical Information - Sponsored by OSTI
                      Hi all,
                      We've almost made it to 100 pages YEAH ........... !
                      Anyway, when I was doing my bug testing, one thing I thought was of significant value was that I was able to start the Bug COLD & WITHOUT a need for the choke. The exhaust smell was clean and the engine performed as well as if it was warmed up. When you consider the mass of metal that has to be heated up to achieve any reasonable performance otherwise, this was a significant spin-off of the research.
                      Greg
                      • plasma in ethanol engines?
                        Hello, guys!
                        What about using the plasma spark in engines converted to run on ethanol?
                        As ethanol is burning at a slower rate than gasoline, the plasma spark could have an improving efect here, speeding up the process...
                        Has somebody tryied this?
                        Thank you.
                        • Hv diode vs series diodes
                          Hi all. Finally finishing my plasma oscillator. Its working. But I wondering that which one is better. Is it hv diodes in parellel or series of diodes.
                          • diodes
                            Hi,
                            I don't know if you ever followed my stuff when I worked on this, but I ONLY chose the HV's in parallel (I used 4) because of the compactness AND I didn't like the added voltage drop the Series setup created. But, I think the Series setup is less expensive, more forgiving and maybe has a couple of other attributes.
                            I just liked the compactness of the Parallel setup. If I was using anything more than about 3uF for the storage cap, then I needed to start putting HV's in parallel to handle the current or they'd get really hot ... and that would lead to failure.
                            Hope this helped,
                            Greg
                            • Keep in mind that with plasma you obtain UV and heat .. if you use copper wire you remove also oxygen from air forming copper oxide around the wire .. maybe is the same method used from meyer.. can be possible that EEC is in fact EOC (extraction oxygen circuit) formed only from copper wire resistor?
                              Al
                              Hello guys,
                              I am new on this forum and I have read all of this very interesting post.
                              I agree with you Al, I think the HV ionize and boost themal explosive energy with uv, the LV make electrolysis instantly.
                              HV and LV may need to be just a little delayed, first HV, then LV piggyback on the HV channel.
                              Have you check the ATHAL goob job on yahoo groups about making Water injector with dual anode ?
                              Sorry for my poor english, I am french man.
                              I plan to buy a 4 stroke motor 100 cc to begin
                              I hesitate between make a waste spark removal system or use the Jetjis circuit with a magneto swith.
                              I will join too to the research !
                              Keep going on the good stuff mans runing ICE with water is possible !!
                              See you
                              Joko
                              • Hi everyone,
                                it has been a while since I have shared new information.
                                I have been contacted by a YouTube user: theWIKWIPmaker of a new spark plug design that he has invented. He claims this would greatly help at solving the missing puzzle to make an engine work on water.
                                It looks promising to me
                                Here is his video demo: YouTube - The Birth of the WIK-WIP
                                Please share your thoughts and or replication attempts.
                                Luc
