center tap
Hi Top,
Well thanks but Jet has done more variations and iterations of the water spark plug than I can count and same on many other forums and topics and Aaron too, (^2), well this whole forum is his gig anyway (hi Aaron). If you look at the PDF I uploaded you see that this transformer can be configured many ways. One way is as a center tapped, step up transformer. I've seen posts in other forums (like Gotoluc's equiv. forum on the topic at 'overunity.com' & maybe here too) where two step down/step up transformers have been hooked in series to make a CT config. It will probably get you going but I don't think it's the same "inductively" but maybe close.
On the MPG thingy: I had to sell my Bug for $$ ... the economy and all, so I've been out of that part of the loop for about 9 months + now.
Good luck,
Greg
Hi Top,
Good luck,
Greg
Originally posted by topangler81
. in your video, i can see that u using some thing as current limiter. why u shuld have a current limiter
. today is quite busy day changing all parts and i do not have parts i needed. yes i also think that the output frequencies is too high. my 2n3055 gets warm when i switch on and transformer also making very little buzzing sound. i did attach the output to bridge rectifier, and i'm using DC voltmeter. i also switching to AC and still not get any result. but i did notice when i switch off the circuit the voltmeter will show 24+ volt for a second and then go back to 0v.
. i will tries using bigger cap but still need to buy it because i dont have any with me.
