Originally posted by gmeast
Hi Greg,
I was able to get into the barn today and build the VexUs circuit.
Everything ran great ! 6 plugs, distributor, points, all firing consistantly at an engine equivelant of 5000 rpm. I haven't gotten any feedback to my call for alternate spark plug geometrys, so I assume noone is working in this area. I thinking I'll throw this in my vehicle and see how it performs.
From your experiences with the bug, can you offer a starting point as to spark gaps ?. Did you go large, stock, middle ?
Timm
So, if I can get better results (which I have witnessed) with lower capacitence and higher voltage, I could use 4 caps of 11uf, fast cycle, rated for 500V, (if I can order that) wired series and then parallel, and have a handling capability of 1000 volts? I would probably be safe then to use the voltage doubler circuit which actually takes the measurable voltage close to 300V. OBVIOUSLY we don't need amperage here anyway, just the voltage potential. Maybe I could also fashion a little box with a couple heat sinks and a small fan to mount the caps, resistor, and the diodes into.
Thanks for the part # of your FWB too, I need to order some of those today along with a couple isolation transformers. Do you have a part # for the variable resistor you are using? Would that one still function the same if I charge to 300V? Thanks for everything, later....................................Mike
