The mysterious technology of Stanley Meyer
  • #76
    would not it be better to use nitrogen instead dirty exhaust fumes? Therefore I wanted to use copper. so instead of Pantone Reactor I could use VN ozone generator and exhaust fumes? it is complicated to do and starts the engine. I wanted to avoid using oil and engine theory bazijev. thank you
    • #77
      well I hear many people are running their diesel engines on burnt oils.. cooking oils e.t.c. I even read it on an article of a magazine ..
      Combustion of fat and vegetable oil derived fuels in diesel engines
      The potential of using vegetable oil fuels as fuel for diesel engines
      The pure in heart will see the light.
      • #78
        Originally posted by tutanka View Post
        Yes.. this is called normally electron beam and I agree with you photons or electrini crack molecules and .. you need also temperature.
        But for run an engine properly using water you need also an little amount of carbon .. all togheter..
        thanks for read me
        Can carbon come from trace amounts sodium carbonate, oaxalic acid, or CO2, mixed with water?
        I know we were looking at oil, but what of other sources.
        • #79
          an answer for all..
          An mixture of water and oil (or other hydrocarbon) is what you need and is the simple way for make an low cost and working reactor saving some
          moneys using an small amount of hydrocarbon..
          Please...
          Study with attention the PMC naudin diagram and you understand that simply you can modify this reactor tube (adding an new metal catalyst inside) reaching the success without using complicated electronic circuits and do not use an large amount of electrical energy as the Bingofuel The BingoFuel Reactor v1.0 by JL Naudin obtaining every COH2 as final fuel.
          If you check better this diagram is very similar (or the same) of the Stanley Meyer concept.. water, exaust gas, air (and an small amount of hydrocarbon).
          • #80
            Baziev and electrino works at the same mode.. air plasma an water are needed for obtain the free electrons but don't forget that this system use compression of piston (heat) and an catalyst.
            All is connected..
            The PMC diagram is the semplicity and how with an smaller amount of hydrocarbon (also vegetable oil can be useful) you can power an engine..
            • #81
              thank you I will work on the project. few grams of Catalysts
              temperature, and high-voltage variable-on tubes. hho
              • #82
                My personal suggestion is.. that you don't need hho.
                What is the real function of smaller amount of oil?
                All reactions are based on chemical..
                What is for you the real chemical process that appear inside the reactor??
                Only if you answer correctly you can build the properly device..
                • #83
                  Analyze better..
                  You must to analyze better the PMC diagram for understand the right chemical process and you can understand also the function of the exaust gasses.
                  FORGET ALL THAT IS WRITTEN INTO THE STANLEY MEYER PATENTS BECAUSE THE TRUTH IS DIFFERENT AND MUCH SIMPLER IF YOU WANT AN WORKING DEVICE!!
                  • #84
                    • #85
                      Ok some generic informations (yours?) ...but what is the function of smaller amount of hydrocarbons (oil,gasoline, diesel,etcc)??
                      You write about electric field. . Make plasma isnt simply as make electricity.
                      Please explain chemically what appear inside the reactor and what type of fuel is produced because we are talking to Power an engine ..
                      • #86
                        hello. Some of my certain general. Tube can be graphite. might think that the oil of the electron donor. discharge gives off positively electrino - neutrino. or are at cracking release electrons from the molecular decay - gas is bingofuel. possible electron avalanche as stated. It's almost not using dirty but also works urea fuel probably not move
                        • #87
                          Answer to this question..
                          oil is tranformed in other molecule or is burned inside the reactor tube?
                          • #88
                            Adding HHO probably unnecessarily. oil is decomposed to carbon monoxide - water to hydrogen helped by induction heating and fogger would not it be better to use the air intake from the heating positiv ionizer, 1 l of HHO gas, plasma ignition?
                            • #89
                              Sorry but .. is an wrong answer.. this is because you have not looked properly the PMC diagram.. as fuel you obtain COH2 but you must understand properly the reaction for make an working device.
                              • #90
                                too mysterious technology. I'll wait for your book
