The mysterious technology of Stanley Meyer
  • The mysterious technology of Stanley Meyer
    If you think that Meyer burn water you are wrong.
    If you think that gas processor ionize the oxygen you are wrong.
    Meyer technology is based on air .. air for Stanley Meyer is the real fuel .. Meyer process the air not just oxygen ..
    He has hidden in his patent the truth and have explained only in part to his brother Stephen
    Stanley Meyer do not produce much hydrogen and oxygen, but is able to run an engine. How is it possible?
    During its Research Department has accidentally found that air is the main source for its reaction and its injector optimizes all the reaction with few components simplifying the reaction
    I'm creating an DVD/Book that step by step explain how the Stanley Meyer technology really work
    Reading this you can understand simply how easy it is to replicate the Stanley Meyer technology
    You can use this technology to make burners, heaters, generators .. and anything that suggests your mind and that concerns the heat
    For more information contact the website http://www.air4gas.com from the next 12 november 2012.
    working device.
    Before you sell something proof it.
    Although I want to believe you.
      Originally posted by Cherryman View Post
      working device.
      SURE!!! everything will be online from the next 12 november 2012
        I've been checking this site for a couple months....since last time you posted that you would sell a gas processor!!!!
          new here
          Who is selling a unit..??
            Does anyone really want this explained..??
            It is a death sentence..
            Anyone know what fire tested means..???
              Sorry.. little delay for other works.. actually we are working on at 100%
                STANLEY MEYER IS REALLY DECRYPTED!!
                  No units available at this time because anyone can build the Meyer unit and add what want
                    stan meyer resonance circuit is an fake..
                    Please save your time and moneys
                    Do not buy any meyer circuit or transformer from the online stores, none of them is telling the truth. NO electrolyte must be added inside pure water
                    The stan meyer resonance circuit (that you can buy or just find on some Meyer patents) is just an fake.
                    With this circuit there will be no resonance also if you use water cap.
                    The capacitor will be charged till the pick voltage of the pulse transformer and all operation will stop.
                    The diode block current back, only removing the diode make resonance possible.
                    The serie choke limit just current and do not amplify output voltage.
                    As I have written some time ago in that forum the Meyer patents are all modified in part for confuse peoples.
                    For reach real results you need to build different circuit and you can found this only on dvd/book available from 12 november 2012 on http://www.air4gas.com
                      Stan Meyer resonance..
                      This is the real Stan Meyer resonance.. NO DIODE must be used. Diode cut resonance..
                        Alessandro, are you using this resonance in your process?,
                        Can you give a rough explanation of your process?. No details if you want.
                        I cant wait till next week.
                        Thanks.
                        PS: are you going to sell an e-book?
                          Thanks.
                          Resonance is part of the process and we can call this "resonance cold plasma".
                          • #14
                            Thanks.
                            No Plans are present inside the e-book just methods used from Meyer .. inside there are present only indications. Anyone can use these and build an own system.
                            • #15
                              Are there complex electronis involved in this?
                              The pure in heart will see the light.
