WFC Electron Extraction Circuit (EEC)
  • #16
    electrons are not extracted
    Hi, this is typical of Meyer, electrons are not extracted, positive and negative charge has to balance.
    Think of a battery, the electrons move from the battery when a circuit is made such as a bulb, these electrons then move into the bulb, create light and heat and then move out of the bulb and back to the battery to maintain the same charge relation of posive and negative.
    The EEC was a change of the type of gas to a different molecular structure, but the same number of electrons are still there as in the "battery".
    Watch this
    Also watch the induction vid as well, I thought it was well explained.
    regards
    Mike
    • #17
      Mike
      My take: The WFC's pulsation of charge-discharge causes an imbalance in the surrounding dielectric (ambient). The dielectric rushes in to restore balance. But the dielectric causes a transmutation so that what is produced by the properly attuned WFC is, as Mike says, of "a different molecular structure." The dielectric is centripetal and counter-spatial in nature, and perhaps this is why the resultant gas is implosive in nature as well.
      Bob
      • #18
        Perhaps, the output going to the filament load could be sent to another electrolysis cell.
        VIDBID
        • #19
          Patent #4,798,661 Gas Generator Voltage Control Circuit
          Patent: https://patents.google.com/patent/US4798661A/en
          Originally posted by US4798661A
          Abstract
          A power supply in a system utilizing as a source of fuel a generator for separating hydrogen and oxygen gasses from natural water and having the capabilities to control the production of gasses by varying the amplitude of the voltage and/or the pulse repetition rate of the voltage pulses applied to a pair of plate exciters in a vessel of natural water, comprising a sequence of circuitry operative to limit the current of a d.c. potential to a minimum value relative to the magnitude of the voltage applied to the plate exciters. The circuits each function up to a given magnitude of voltage to inhibit and curtail the flow of electrons from the plate exciter having the negative voltage potential applied thereto. The first circuit operative from a first magnitude of voltage comprises converting the voltage potential applied to the plate exciters to a unipolar pulse voltage d.c. of a repetitive frequency. The next circuit varies the duty cycle of the unipolar pulse voltage d.c.; followed by rearranging the application of the voltage to the exciters to individual exciters each having the voltage applied thereto independently of the other plate exciters in the generator. The next circuit comprises an electron inhibitor that prevents the flow of electrons; the circuit being in the terminal line between the negative plate exciter and ground. In those applications of the generator wherein excessively high voltage is to be applied to the plate exciters for a very high yield of gasses, a second electron inhibitor of a unique structure is serially connected with the first electron inhibiter. The second named inhibiter having a relatively fixed value and the first inhibiter connected in series is variable to fine tune the circuits to eliminate current flow.
          Download Patent PDF: https://patentimages.storage.googlea.../US4798661.pdf
          VIDBID
          • #21
            EEC well explained
            EEC well explained https://youtu.be/EyVo38NLlr0
            The primary positive plate of the water capacitor is insulated.
            The electron recovery plate is not insulated, neither is the negative ground plate.
            VIDBID
