WFC Electron Extraction Circuit (EEC)
  • WFC Electron Extraction Circuit (EEC)
    This thread for EEC discussion.
    When water is pulled apart, electron is freed and if not removed can be used to help gases recombine to water preventing abundance of gas production.
    EEC according to the later diagrams and explantion is turned ON when the trigger power pulse is turned OFF. Therefore they are 180 out of phase flip flopping. On off pulse, EEC is switched on to conduct the electrons from water, to positive plate, to be burned by filament and connected back to power input.
    Any Ideas?
    Have you came up with any designs for this? I wonder how beneficial this would be to experiment with, I mean if it can increase gas yield by 30% more than I think this might be a very important area for us to start looking into.
    RedMeanie
      EEC diagram
      Hi Redmeanie,
      Here is a diagram from Meyer's tech brief:
      The red is the EEC path. It is triggered by a flip/flop so that when the power pulse is on, eec is off and when power pulse is off, eec turns on.
      I think it is a brilliant concept if it really works as claimed. It seems that Meyer only used it later for further gas production but not as a necessity for the wfc to work.
      I heard that Dave Lawton had great results with the EEC but I don't know if that is actually confirmed.
        simple eec
        Is there any reason this can't work? Seems a simple way to do it.
          If you look at fig. 3.2 in the tech breif it shows the EEC on the gas processor.
            you are working on a small injector. the EEC circuit does not use a electrolysis cell from my understanding. it makes HOD from a water mist, "under compression with outside air."
              eec
              Yes, but through the H2Earth's chatroom etc,... they're saying Dave Lawton used it with his water cell to light the 40watt bulb. Did Dave not really do this or did he only have it hooked up above the water through another tube setup that only the gases were going through?
              It has been said pretty clearly by them that it is connected to the tubes submerged in water. Conceptually, it seems it would work on submerged tubes as well. Under an electron cascade effect, the EEC should conceptually pull a lot of those electrons to the pos plate and to the bulb to be burned. Then there is even more separation in the water itself.
              If it doesn't work in water then I don't have to waste time with it at this point but if simple enough to try, would be interesting to see results.
                  Working Electron Extraction Circuit
                  Hi Redmeanie,
                  Lamp powered entirely by the Free Electron Current drawn from solution by the EECL
                  It works according to this website: Making a Hydrogen Generator
                  What I would like to know is why couldn't you store the electrical energy from the Electron Extraction Circuit and then re-use that stored electrical energy to power the Water Fuel Cell to produce more HHO gas?
                  VIDBID
                    Electron Extraction Circuit is an simple method for create hollow atoms. The only problem is that using that method don't have OU system, instead consume electrons you can use these for increase ionization field as appear inside e-beam reactor.
                      Request for Clarification
                      Would you please clarify what you mean? And would would you please clarify and define these terms?
                      • hollow atoms
                      • consume electrons
                      • increase ionization field
                      • e-beam reactor
                      VIDBID
                        Or to a series of cells, and when enough electrons are extracted, to a battery bank to power your home. I wonder if there's a limit?
                          Method of Meyer and Latwon is "consume" electrons, that method increase the gas production but what appear if energy extracted from cell can be resend inside circuit? That surely increase X times gas production with low amperage.
                          • #14
                            • hollow atoms
                            • consume electrons
                            • e-beam reactor
                            Hollow atoms is what Stan Meyer want.. Hollow Atoms: LCL Pulses Make Electrons Strip
                            • #15
                              Electricity From Electrolysis - Electron Extraction Circuit
                              Electricity From Electrolysis by way of WFC Electron Extraction Circuit (EEC).
                              I had this thread on my brain last night.
                              It's like energy recovery for electrolysis.
                              Stan Meyer's Electron Extraction Circuit - YouTube
                              S_Meyer_Electron_Extraction - YouTube
                              Ravi RAJU REPLICAS of MEYER Electrolyzer - WATER as FUEL - MDG 2007
                              Recovering some of the electrical energy.
                              VIDBID
                              PS: Who's this guy? How Meyer Circuits Work, EXACTLY - YouTube
                              VIDBID
