Originally posted by jehdds
Bedini Earth Light
Yes it was a liquid Sodium silicate with Epsom salt added to it, turned it into a paste and then I heated it till it stop bubbling and then inserted magnesium electrode.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
if you add carbon it will improve tremendously. You will get around 1.7v and above 10ma. The epson salts will suck water from the air though as time passes.Originally posted by ibpointless2 View PostI just combined Sodium Silicate and Epsom salt into one mix, cooked it till it stop bubbling and stuck my electrodes in. After letting the cell cool for 15 minutes I getting a whooping 1.662v @ 5.50mA!
Combining Sodium silicate and Epsom salt together makes a new material that looks and feels like my crystal glue cells. Timing did seem important, too much and the cell was useless and too little and the cell was hard to work with. I think i should have cooked it for a little longer though, but it being my first one I consider it good enough. I'll have a picture below to show you what it looks like.
[ATTACH]10102[/ATTACH]
Fausto.
yeah i was think the same thing about the Epsom salt will absorb water from the air but something else is happening. The cell keeps loosing power. If the cell was using water as the median than the amps would stay the same or go up. So if the Epsom salt was absorbing water from the air than the cell would still be holding its amps or going up in amps but its not. Since the cell is going down in power then I would assume its loosing its water content. The cell is still above 1.5 volts @ ~3mA.Originally posted by plengo View Postif you add carbon it will improve tremendously. You will get around 1.7v and above 10ma. The epson salts will suck water from the air though as time passes.
Fausto.
You also must keep in mind that when I combine the Epsom salt with the sodium silicate it became some very different now. Its a magnesium-silicate-sulfate compound now.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
It has mimicked a rock
Ibpointless,
What do think the compound is? to get magnesium silicate you would need to cook this over time dissolving the magnesium grains and it would start the reaction all by itself.
After you have that compound you can re-melt it with the Epsom Salts by adding a little water to form a Magnesium Hydrate and then fill the cell.
You need to find out what you have made, if you look at it under a microscope you will see just what material it is. It has mimicked a rock that is mined and used everywhere. I'm not going to say what it is at this time as I want to see if the group can tell me what it is.
John BJohn Bedini
www.johnbedini.net
Alex,Originally posted by John_Bedini View PostIbpointless,
After you have that compound you can re-melt it with the Epsom Salts by adding a little water to form a Magnesium Hydrate and the fill the cell.
John B
I'll take building materials for 1000.....
What is gypsum?
Jim
Series and parallel
@ jehdds and all:
Yes impedance is the issue in series. In parallel the current is additive in the sealed cells. The lamp in my last post has a cell that John built in one box that is actually 2 cells in 1 unit in parallel. The oscillator circuit makes up the voltage. If you series/ parallel 4 cells then you will get the voltage and current. The new sealed cells are at 2 volts and under the load of the oscillator they hold .92 volts.
@ all: Sorry if i don't get to every question and answer it.
if you put that cell inside a bottle (like I did on my videos) you will see the water condensation on the walls of the bottle which means that indeed you have absorption of water by the cell and evaporation all at the same time.Originally posted by ibpointless2 View Postyeah i was think the same thing about the Epsom salt will absorb water from the air but something else is happening. The cell keeps loosing power. If the cell was using water as the median than the amps would stay the same or go up. So if the Epsom salt was absorbing water from the air than the cell would still be holding its amps or going up in amps but its not. Since the cell is going down in power then I would assume its loosing its water content. The cell is still above 1.5 volts @ ~3mA.
You will also notice something very strange if you use a LED. The water will condensate AROUND the area where the LED is shinning. Very strange!!!
THat's why I am testing cells inside the plastic bottle. They all stand much longer in time running. That does not mean the Mg is not consume though.
Fausto.Last edited by plengo; 01-22-2012, 01:39 AM.
Run time
Originally posted by plengo View Postif you put that cell inside a bottle (like I did on my videos) you will see the water condensation on the walls of the bottle which means that indeed you have absorption of water by the cell and evaporation all at the same time.
Fausto.
@ plengo and all:
Very good!
