Collector Coils Alone (Bedini)
  • #16
    Spitting the positive
    After reading a post by JB at the Bedini Ferris Wheel. I went back and looked at the basic SSG circuit. I had not this noticed before, but the circuit is splitting the positive. I could not wrap my mind around this concept when E.V Gray spoke about it with his Gray motor. But John Bedini is doing exactly that. The #23 coil wire, coming from the positive of the primary to the positive of the charging battery, with the a wire tap going to the negative of the charging battery. It helps to see the circuit actually working to see this. I think I might
    be off topic here, but it has become clearer to me. There still is a lot of mystery to me as to how it all works. I just know that it does. I have seen very
    good evidence of this in the way my batteries are charging.
    FRC
    • #17
      karring if you watch "Energy From The Vacuum 07 - Tesla's Impulse Technology", it will explain how once you get the bicycle wheel to trigger the correct pulse you can add an unlimited number of coils to the system and extract energy from each one and then send it to a capacitor or battery. The small amount of current is to trigger the transistor and get the radiant effect. Bedini also says that normal current destroys the radiant energy.
      The energy coming off the unlimited amount of coils is negative, and to charge the primary battery you have to run one of the unlimited output sources through an inverter back to the primary battery..bam, self-sustaining power machine.
      Also some more info: Once you get all the negative energy in a battery or capacitor you can then produce anti-gravity which is even more awesome.
      Not sure if you know this already but I figured a little explanation couldn't hurt. If you watch the video he explains it very very well, i highly recommend you watch it.
      • #18
        Antigravity
        I was just watching John Bedini in Radiant Energy 06 or 08 EFTV. I guess I will
        have to go back and watch the other one too.
        My question is: How do you produce the antigravity ? John Searl is supposed to
        get antigravity with his motor device also.
        FRC
        • #19
          FRC
          I lack knowledge in that area but I do know you can produce anti-gravity using the negative energy from the device.
          Im pretty sure once you send enough power at a certain frequency rate for the specified object it will counter gravity and float. I know its possible though.
          • #20
            Don't know anything about antigravity, too busy trying to keep my feet on the ground
            I got my SSG running. Seems to work. Now exploring the next step. I'll tie my unit down
            • #21
              I'm sticking to two circuits for now. The SSG, and Farmhands solar circuit. On different experiments. The way I see it, John Bedini put a lot of time into this SSG, I'll let it mature down John's path (that particular experiment). Farmhand's charging circuit for solar will be a totally different project. I figure any guy who put 25 years or more into variants of the same circuit must have had a reason to stay close to what he fealt works. Or maybe I should say, what works, but could become amazing? Anyway, you know what I mean. It's always good to try to learn the heck out of something then move on.
              - this month was gracious - got me another 200 watts solar - yayyy That's 1300 now!
              People say solar isn't the answer yet day after day it gets cheaper and cheaper. Most people spend more in an unneeded second vehicle than required to free themselves from the grid. At the end of the day, when's the last time you thought of something better than solar or wind, to do on your roof? hehe
