    Les,
    I would change the center coil to adjust that figure. This is not that critical 1.82 ohms may be a little to low for the switch. but I'm going to check that out, I will get back with you. I have some test circuits here. I'm just one guy here and getting a break at work at this time is questionable as to when. I will do my best.
    John B
    John, I appreciate your situation. I saw your last post was at 1:30 am. I hesitated to ask knowing how much effort you are putting in.
    In other words take your time I am still a ways off waiting for parts.
    Also I just looked last week and Jameco had the 3120 halls now they are all gone...Wonder how that happened?
    Thanks again
    Les
    • Originally posted by Les_K View Post
      Thanks again
      Les
      ooops! I just realized what you were saying John. You answered the question; I can just raise the resistance of the center coil, no need to waste your time testing.
      Thanks Again
      Les
      • @ Les K
        I did the math on John Bs figures, and I also got a total resistance of 1.822 ohms. Please forgive me if I misinterpret your post John. I believe only one slave coil was added in the equation."Now if I add all the coils together for a total I get this." JB
        4.2, 1/x = .2348
        6.368 1/x = .1570
        So if that were the case,
        4.2, 1/x= .2348 main
        6.368, 1/x= .1570 slave 1
        6.368, 1/x= .1570 slave 2
        = 1/.5488 = 1.822
        Again forgive me if I am wrong
        Brian
        • Bedini GT3
          Wrench76,
          4.2 ohms is = to .2348
          6.3 Ohms is = to .1570
          Add them together you get .3918 1/ X= 2.55 Ohms
          DO IT WITH RESISTORS, DON'T BELIEVE ME, TEST YOURSELF.
          Two resistors
          4 ohms 1/X = .25
          6 ohms 1/X = 1.6
          add them together = 4.1, 1/X = 2.4 ohms
          ANSWER IS 2.4 OHMS
          Do it by putting two resistors together you will see.
          Do it simple 100 ohms 1/X = .01
          100 ohms 1/X = .01
          add them together = .02 1/X = 50 ohms.
          Again. 12 ohms 15 ohms 30 ohms
          12 Ohms 1/X = .08
          15 Ohms 1/X = .06
          30 Ohms 1/X = .03
          Add them together= .17 1/X = 5.8 Ohms
          Ok I goofed up I did Correct it.
          John B
          John Bedini
          www.johnbedini.net
          • Originally posted by John_K View Post
            Thanks all for your responses.
            The hall I was using was a 24V SS443A:
            SS443A pdf, SS443A description, SS443A datasheets, SS443A view ::: ALLDATASHEET :::
            The 15V Zener I am using is a 1N4744:
            The hall triggers a MJE2955, which then fires the MJL21193/94 pair.
            I will order the ATS137 as John B suggested, looks like they are the same one Rick sells. http://www.diodes.com/datasheets/ATS137.pdf
            John K.
            • Hi Patrick,
              Yes we can and that's what I was doing initially and it did work OK. I would like however to have all the circuitry on one board and in a box, same as John B.
              I tend to struggle with stuff I haven't done before, but it's the only way I learn. Even if I do blow a few components along the way. Everything I have learnt about John B's technology I have either read, seen on a DVD, or taken advice from people on forums on the Internet. I think I really learn when I let the smoke out of things.
              I'm also very fortunate to work closely with a few people who know a lot more about this stuff than I do, even if they're on the other side of the world from me.
              John K.
              http://teslagenx.com
              • Why not just put three small caps across the 36v input, and only pull off of one will that work ?
                William Reed
                • Bedini GT3
                  Wrench76,
                  I see what your saying yes I did forget Sorry for that.
                  yes it would be 1.88 ohms but that is ok as the switch will run fine I did check it today it seem to work fine. I also took the switch down to 1 Ohm and it did ok. Sorry for the mistake but it was late when I got done at work.
                  I will go back and correct that post as soon as I get time. Thanks for catching that.........
                  John B
                  Originally posted by wrench76 View Post
                  @ Les K
                  4.2, 1/x = .2348
                  6.368 1/x = .1570
                  = 1/.5488 = 1.822
                  Brian
                  John Bedini
                  www.johnbedini.net
                  • Comment
                    • Bedini GT3
                      R12003,
                      Just hook up all the coils in parallel and get it running, then decide what you want to do with the two trigger wires. you should be safe doing that . make sure the devices have a been mounted to something like a heat sink plate. You might move a little off TDC like 1/2 the pole piece to start.
                      John B
                      John Bedini
                      www.johnbedini.net
                      • Bedini GT3
                        John K
                        I did want to get back to you on the switch The MPS 8599 is good for low level circuits. But looking at the circuit I tried a MJE2955 TO220 package and it worked fine under all the tests. I would rather get everything working right now for you at this end of the world. Or use a BD 244
                        John B
                        John Bedini
                        www.johnbedini.net
                        • Thanks John,
                          I will connect it and run it as you say. I also backed the timing off a bit and will start there.
                          I aready see some things I would have changed in the winding of the coils, but
                          these will be a good starting place.
                          Mark P.
                          R12003,
                          John B
                          • Hi John B,
                            Thanks, that gives me confidence to stick with the MJE2955 TO220 that I am currently using.
                            As soon as I get some ATS137 halls from Rick I'll be back in action, no one in Australia seems to stock them that I can find. I'll send through an order when I get home from work.
                            John K.
                            John K
                            John B
                            • No Problem John B. I thought I was losing my mind for a moment though. Thank you and and all other contributors, for an informative tread. I am learning a lot.
                              Brian
                              Wrench76,
                              John B
                              • Bedini GT3
                                Wrench76,
                                Welcome, and thank you, it never hurts to have extra eyes. need anything just ask, thanks again.
                                John B
                                John Bedini
                                www.johnbedini.net
