Bedini Capacitive Discharge Chargers
  • #91
    Bedini with cap
    Hi guys did you find this cap discharge truly better?
    What type of uf/voltage found best?
    This is the capacitor in the scheamtic cause it's not clear looks like another battery?
    • #92
      Originally posted by blackchisel97 View Post
      totoalas I would use higher capacitance, such as 20000uF and close to the operating voltage of your source (panel) - 25 - 40V max.
      V
      @Minoly
      Thanks, 3 t o 4 hours still great will try to test my SSG 6 coiler , just placed my solar on the balcony but fog and whole day rain stopped me... the mono crystalline can also pick up up to 14 vdc pulsing on the charge controller from 9 am till 4 pm in this condition
      @BlackCHISEL97
      thanks for the cap size info m hope this woll speed up the charging process...
      HAS ANYONE TRIED TO PUT A N S SERVER HD DISC DRIVE NEODYNE MAGNET ROTOR 11 INCHES IN DIA ON TOP OF THE CRT FERRITE CORE 6 COILER ??/
      THANKS MATE
      totoalas
      • #93
        Originally posted by totoalas View Post
        @Minoly
        ... just placed my solar on the balcony but fog and whole day rain stopped me...
        totoalas
        That's where I like to use inverted trigger SS SSG instead. It will start charging in low light, even on cloudy day. Less powerful but better than nothing at all.
        Vtech
        General D.Eisenhower
        http://www.nvtronics.org
        • #94
          Besides the vast storage capacity of a 12V Lead battery, it does not seem
          apparent to me why these should be used as the source and destination of
          electrical charge when building these motors.
          With heavy capacitors in their place, it would seem this technology would
          not require a reconditioning and restructuring of the storage medium, yes?
          Then additionally, what about the alkaline energy storage cell developed by
          Thomas Edison?
          • #95
            Originally posted by minoly View Post
            try this one.
            I did, in a form and fashion. See image for the circuit I wound up using. This charges a 12V 7AH like a madman.
            "Anything the mind can conceive and believe, it CAN achieve." Napoleon Hill
            • #96
              Scr
              Thanks Twinbeard for sharing. Do you think if I use another SCR and zener will work too?
              Thanks.
              • #97
                Good job mate May I know the input current and maybe try with a solar as well???
                totoalas
                • #98
                  Thanks.
                  Just watch your voltage and power dissipation ratings on the components you choose.
                  I may wind up updating that circuit... not sure until I put the scope on the cap pulser to see if it is dumping properly. From what I see on the multimeter, it looks like the SCR is getting stuck open. Perhaps a larger cap bank, more closely matched to the voltage I am working with...
                  Enjoy
                  • #99
                    totoalas
                    Input current looks like about 200ma with the rheostat pegged at 500 ohms, 375ma at the tuning "sweetspot," and a little over an amp with the rheostat zeroed, so only 50 ohms to the base from the fixed resistor in that instance. The latter drives the fan FAST. The fan is rated with the factory circuit as drawing 2.3A @12V, btw.
                    Enjoy,
                    Twinbeard
                    • Negative and positive charge
                      Enjoy
                      This setup is giving negative and positive charge?
                      Zener Diode maybe should open at 18v to batteries what do yoy think?
                      • cap charging
                        Bedini Cap Charger discussion. The chargers with with bridge to cap setup. Can be with mechanical pulley switch setup, 555 timer switch, neon bulb switch, etc... With rotor or self-oscillating.
                        I am new to this site but i like what i have been reading, i have been working on cordless battery charger using a capacitor charging circuit of mine which charges really fast, the voltage input from the cap is controlled by the switch speed of a 555 pulse timer. My question is there a way to split the charge voltage and direct some of it back into the storage devise with greater output
                        at the same time.
                          It looks to me that while some of the spike may discharge into the charge battery positive terminal, most of it is going into the cap, which then gets discharged across the charging battery.
                          Probably closer to 20V I think, as the SCR needs 1.7V to begin conducting by itself.
                          Any opinions on these caps... say 4 in series for .25F @20VDC?
                          PB Series, Supercapacitors, Low ESR,
                          Enjoy
                          Twinbeard
                          • How might this perform? The recovery capacitor voltage would
                            likely be around normal 16V battery charging level.
                            • Hi geotron,
                              My experience with that kind of circuit is not too good. What happened for me was when the cap got charged high enough to turn on the zener the zener just starts to turn on. This turns on the transistor but not fully on. The transistor conducts just enough to keep the cap at a level that just keeps the zener barely turned on and thus you reach a stable condition which is just charging the battery the same as without the pulsing circuit. I have been meaning to order some diacs. The diac has full on or full off kinda snap action. I think with a diac in series with the zener this would be a good circuit. I haven't tried that yet so I could be wrong about how well that would work.
                              Later,
                              Carroll
                              • Cap
                                Originally posted by Jetijs View Post
                                In the dvd I saw him (Mr. Bedini) using those huge electrolytic capacitors with one of the models with mechanical comutator. These capacitors looked like those used for car audio systems. They are rated 1-3 farads and 24V max. If I recall it correctly, he used two of them in series. So we can assume he never went over the 48V at least with that small model.
                                I could have bought one of these 1 farad audio capacitors for $99.95 a couple
                                months back. Does anyone know if that is a good price for one of those ?
                                George
