Well, I tried another Starship coil today. I made quad but only used 3 windings atm. in Litz fashion. I used the same circuit as per my last vid. except that I rectified output from the third, capped with 10 000uF and connected 12V/5W bulb to it. To my amazement input voltage remained the same but input current dropped from 1.45A to 1.36A. There was a slight difference in the waveform with additional ringing in the middle of horizontal part of "h". Spikes dropped from over 50v to about 46V. However, my amazement didn't last long when I discovered that charging became much slower. Oh well, nothing for free today I guess
Update: I used litzed coil in "normal" bifilar self oscillating configuration. Waveform is nicer than my other coil and spikes are at 55V. Circuit oscillates at 10kHz and is charging well.
Cheer's
Umm your input power would probably go up though, I guess.
the difference is dramatic the new one's burn so bright it hurts, I can't wait to show someone.
I got them cheaper by buying 30, I was taking them from old appliances to use, but I think they were made for 240 v and so they didn't protect some lower rated transistors at all.
If there is one thing i will not skimp on in future it is the neons.
After it was charging for five minutes on a solid state energiser when I check the voltage and wonder why it says negative 6 volts.
Still not sure I can fix it.
