This is a sticky topic.
  • timer power resistance
    Originally posted by FuzzyTomCat View Post
    3) The added 4,000 ohms was only on the Ainslie - Murakami Negitive Dominant Waveform Generator Circuit for more resistance .... why we needed it, changing to the new 10 ohm prototype resistor "ONLY" .... Aaron and I both were surprised and I don't know why, but in order to lower the 555 timer voltage that is what we had to do. The other Rosemary Ainslie COP>17 Heater Circuit leave it the same but maybe change only the 1N4007 diode out to a 1N914 or a 1N4148 the 555 circuit works much better.
    This was interesting. My timer will flatline if I crank the pot to max resistance with 1k of resistance. Glen's ran with several thousand ohms of resistance at the positive rail to battery.
    • Resonance
      Guys - just a general question here. Did anyone notice the fact that Fuzzy's waveform shows a negative cycle apparently preceding a positive? Aaron went to some trouble to show that this is replicable.
      The fact that net negative voltage values are shown at all is rather extraordinary. But that this new waveform is evident? It seems to point to the fact that during resonance - the supply of energy somehow can get transferred to the inductor/resistor. This is the more so as the ringing effect seems to also transfer to the positive cycle - the precise reverse of what is usually evident from these collapsing fields.
      I'm not sure how this effect would stand as it relates to 'stored energy' - as is assumed by classical physics - nor if the positive part of that waveform then comes from the battery or purely from the resistor. Just so many questions. I'd be glad of some input here. Perhaps Harvey? or Jibbguy?
      • Crazy idea : maybe resonance poll electrons from 12V battery which is connected through ground wire...
        • Everyone - MORE GOOD NEWS. Lisa has extended the loan of the TEKTRONIX TDS 3054C DIGITAL PHOSPHOR OSCILLOSCOPE until the end of November.
          Many, many thanks Lisa. This is much appreciated by all of us.
            Hi Bogus. You're proposal is not as crazy as my own thesis - but its close. In all seriousness I'm inclined to a certain optimism here. But the frustration is that these negative effects are so, so small. How much error needs to be realistically factored into the results?
            But truth is that if we could get this shown with a little more wattage to measure then it would definitely argue to a breach of unity - rather than an improved efficiency. I might add, that having said that I'm now braced for a barrage of obections from our classicists - and the trolls from across the great divide.
            • Stop The Spamming
              Hi folks, it looks like as im typing this his recent spam effort has been removed, good job. I think he is trying to move some thread that probably has hit a high chord of truth and is trying to bury it. oh the user is shubhamforme
              thanks
              peace love light
              Tyson
                thanks
                peace love light
                Tyson
                Hi Tyson. You spelled his name wrong. It's subhumanform.
                  Glad you clarified that - I was trying to figure out why it resolved to:
                  Should B Ham For Me
                  • @Rosemary & Lisa
                    Great News!
                    @Glen,
                    I'm sure it spelled out somewhere in a prior post, but can you refresh our memory as to what your last waveforms relate to? I cannot recall if you were looking at the sensing resistor, load or some FET pin. Thanx
                    @Aaron,
                    Still looking over the data dump - check your Skype
                    @ .99,
                    Thanx for the PM - Can you poynt me to a protel specific declaration to that effect? I recall reading somewhere that protel modeled a 0.04 Ohm impedance in the VSRC object, but I may be mistaken here. This exercise has not been to argue the validity of the various spice object models, but rather to draw you into an admission that the entire tool is only as accurate as the care put into ensuring each aspect is modeled as closely to reality as possible. Your use of the added arbitrary impedance resistor begged for specific attention as did the complete omission of any internal capacitance for the load resistor. If we expect to simulate what is really happening, we need to include the correct values for these things, not just picking something that 'closely resembles' the effects observed in a you-tube video with no real validation as to the values involved. I can twist the cal knob on my scope input and make 1V look like 5V and even a close up of the dials won't tell you what it is. Then you have to trust me when I tell you its 5V - and that will never fly. You put too much faith in TK's shows, and unfortunately, that is part of his tuition package - misleading those that are willing to believe what he tells them. Put your hands on the circuit and you will win the respect of your peers as well as those you believe you are trying to educate.
                      @Rosemary & Lisa
                      Great News!
                      @Glen,
                      Open Source Experimentalist
                      • Thank you!
                        WOW! Thanks Rosemary and thanks Lisa & Tektronix!
                        It is amazing what this TDS3054C has allowed us to see!
                        • I'm having trouble finding the hexfet heatsink.
                          Also I have most of the PCB soldered except for the 1k resistor. The diagram shows as part of the 555 timer circuit but on the PCB there is extra hole in the middle that goes to the middle pin on the hexfet. Looks almost like a 1kOhm mcb potentiometer would go there instead of a 1k resistor.
                          David
                          • Originally posted by eternalightwithin View Post
                            David
                            Hi David,
                            Do you have this Groundloops Assembled PCB Image
                            Groundloop made the board so him or gotoluc would know where to get the heat sink maybe another member that got one ..... but the Mosfet seems not to get over 140 degrees F ever that I've seen with a heat sink like I have.
                            Glen
                              This is great !!! This is what open source is all about !!! Thanks Rosemary and Lisa at Tektronix the TDS 3054C is a incredible Oscilloscope, a product to be proud of !!!
                              Glen
                              • @shubhamforme
                                shubhamforme,
                                you are reading this thread now. please read your private message immedately.
                                Click this for private messages:
                                I started a thread for you, ONLY post your circuit there please.
                                I will delete this post after you acknowledge my private message.
