This topic is closed.
This is a sticky topic.
  • @eternalightwithin,
    The heat sink is made by:
    Fischer Elektronik
    Type: SK 129/ 50,8/ STS
    Country: Germany
    f.cool
    The "extra hole" you are referring to is a plated through hole. Sometimes
    (when designing pcbs) one need to cross from the top layer on the board
    and to the bottom layer. (Or the opposite.)
    This is done to get an short wire from point a to point b.
    One also want to hide as many of those plated through hole as possible.
    So the usually way to do that is to hide the holes under components so that
    the holes is not visible when the components are soldered. If you look at the
    pcb you will see where that plated through hole goes.
    Also look at the design files found here: Index of /ufoufoufoufo
    (The Cadsoft Eagle CAD program is free and can be found on
    the Cadsoft site found here: CadSoft Online: EAGLE Layout Editor )
    On my site you can also find a very good temperature logger (TRS.rar).
    It handles -40 C to +85 C. There is also some other 555 timer projects there.
    If you have further questions, please ask, and I will try to answer them as
    best as I can.
    Oh, almost forgot, You must NOT use the parts values as shown on the
    pcb layout text. To get the correct duty cycle and frequency please use the
    parts described in the updated circuit drawing (http://home.no/ufoufoufoufo/anc_revB_sch.gif) found on my site.
    Groundloop.
    • yes, that's it.
      Groundloop, Yes I know. Using Aaron's August 26 circuit. Also, why did you put 1N4004 in instead of just all 1n4148's ?
      And where did you get those awesome PCB mounts for wire attaching?
      Originally posted by FuzzyTomCat View Post
      Hi David,
      Do you have this Groundloops Assembled PCB Image
      Groundloop made the board so him or gotoluc would know where to get the heat sink maybe another member that got one ..... but the Mosfet seems not to get over 140 degrees F ever that I've seen with a heat sink like I have.
      Glen
      • Originally posted by eternalightwithin View Post
        yes, that's it.
        They look like Keystone Style Terminals
        Possibly available from Digi-key or Newark
          The 1N4004 is there to block the power to the 555 in case the operator
          connects the polarity the wrong way around. I was not sure how much
          power (read milli amps) the 555 was to use, so I played for safety and
          used a 1N4004 since this is an 1 ampere type. The 1N4148 is a low 200mA
          type. But if the 555 circuit uses less than 200mA then it is safe to use
          the 1N4148 all around.
          The pcb edge connectors are made by Phoenix. See this link:
          PHOENIX CONTACT | 1725656 MPT 0,5/ 2-2,54
          The small one are 2,54mm raster and the big one are 5mm raster.
          BTW: Did change the parts on my board to new values. Now the circuit
          perform OK. I can get the correct low duty cycle at the correct freq.
          Did a test today where I connected a HUGE 500 Watt transformer
          to the switch. I then connected the transformer (230VAC) output via
          a BY255 and back to the battery in a looped self powered configuration.
          The battery did loose charge at a linear manner so the circuit was
          not >COP 1. But it was a fun test. :-)
          Groundloop.
          • Hi everyone,
            I thought I would post a interesting development that poynt99 had accomplished a actual spice close simulation of my wave form from the latest test. I must say that this phenomenon the "Negative Dominate" I've been looking at since the beginning of my postings of wave forms, from all my prior testing and only a few were actually aware of the significance. The wave forms shown are all from the standard 555 Power Adjustment potentiometer resistance rating of 1k to the last test having to use a additional 4K resistor because possibly of the usage of my 10 ohm "Quantum" prototype load resistor. ( see test data for actual 555 potentiometer resistance settings )
            Claimed OU circuit of Rosemary Ainslie
            All my four tests posted wave forms from the newest testing to the oldest -
            Thanks .99 for you hard work on this simulation ....
            Glen
            Last edited by FuzzyTomCat; 09-27-2009, 04:22 PM. Reason: additional information - 1K pot - .99 additions
            Open Source Experimentalist
            • This is somewhat out of sequence - and a bit off topic, but I feel there is a relationship between the RF cooling effects claimed by Aaron and these experiments.
              1047 & 1048 are the most dramatic:
              Experimental Physicist John Hutchison Freezes Water Using RF:
              1045
              1046
              1047
              1048
              1049
              1050
              1051
              1052
              FWIW
              • Fuzzy, .99 - good teamwork on the negative pulse stuff
                Correct me if I'm wrong, but are we not looking at the Source pin of the FET there? If so, isn't that negative spike related to the FET turning off? There is nothing to prohibit a negative potential on the drain from being transferred to the source. We would not see the initial positive there because it is blocked by the body diode and low off-state transconductance of the FET.
                Essentially, during this period, your reference, B(-), is in a positive position relative to the source of the FET. Therefore a negative current is flowing into the source pin. This gives you a negative voltage drop across the measurement resistor - aka 'shunt'.
                Can we see this waveform superimposed with the drain waveform for timing comparison?
                Cheers,
                • Hi Harvey - thanks for the JH clips. Strange man - and weird videos. He's got to be a magus. Can't help feeling he needs to do some serious housekeeping. What a trip.
                  Not that happy with the easy dismissal of the negative preceding the positive - but nor do I know enough to argue. To me the initial positive should be evident - somewhere. Are you seriously suggesting that it was 'snubbed' out by the body diode? Surely the body diode would have been bypassed? in that first discharge from the battery?
                  • Originally posted by witsend View Post
                    • Thanks Harvey.
                      • Originally posted by Harvey View Post
                        Hi Harvey,
                        Thanks for your continued input .... Yes your correct that all scope images do show a probe connection between the mosfet source pin and the .25 ohm shunt ...... with slight differences between tests ...
                        Tektronix 2445A
                        Channel 1 (A1) ground is on battery negative side of shunt and probe is at 555 negative rail side of shunt. [20mV] [x10]
                        Channel 2 (A2) ground is on battery negative side of shunt and probe is at mosfet source side of shunt. [50mV] [x10]
                        Tektronix TDS 3054C
                        Channel 1 ground is on battery negative side of shunt and probe is at 555 negative rail side of shunt.
                        Channel 2 ground is on battery negative side of shunt and probe is at mosfet source side of shunt.
                        POST #2238
                        Ainslie - Murakami Negitive Dominant Waveform Generator (revised 08-26-09) POST #2542
                        Ainslie - Murakami Negitive Dominant Waveform Generator (revised 09-11-09) POST #2606
                        Ainslie - Murakami Negitive Dominant Waveform Generator (revised 09-11-09) POST #2764
                        Ainslie - Murakami Negitive Dominant Waveform Generator (revised 09-11-09) 2us Original (CSV file)
                        2us Crunched (CSV file)
                        (50 mV Div, 2us)
                        POST #2766
                        Ainslie - Murakami Negitive Dominant Waveform Generator (revised 09-11-09) 20us Original (CSV file)
                        20us Crunched (CSV file)
                        Hope this clarify's all the "posted" testing that I have done and the changes between them.
                        Glen
                        Last edited by FuzzyTomCat; 09-27-2009, 04:25 AM. Reason: general correction info - Post #2542
                          Hi Harvey,
                          Sorry I missed this the first time was kinda busy at the time ..... I'll see what I can do .... I'm still in the process of trying to make a replacement "Quantum" prototype resistor for testing and only have my 10 ohm 100 watt "Memcor" plus not a TDS 3054C for any trick stuff just my Tek 2445A .....
                          Glen
                          • winding direction
                            Hi Glen,
                            Do you plan on making a couple resistors that are wound in both directions? Might be interesting to see if that shows any difference on the scope. The one you left with me is wound for South at the end where the positive is.
                            Hard to tell what all these ceramic ones are - can't make out the direction of the winding where they come out to the tab.
                            I guess I could stick an iron core in them, charge it up and see which polarity the core charges at and that should tell me.
                            • Larger Pic
                              Larger Pic
                              It was determined that there is an unknown component in the Radio-Location Bands above 3GHz present in the 'noise' and sufficient to intrude on the data. This signal was present even with the power stage inoperable. The source of this signal is yet to be determined. It may be finding its way into the circuit from the scope ground system.
                              The test configuration used is presented above and organized in such a way so as to reveal any breakdown in KCL. The operation was Aperiodic. The resistor used was Glen's, documented elsewhere. I was not concerned with the circuit timing or the components used for the timer, as this test was aimed at the aperiodic operation and its effects on the current flow in the circuit. The CSR (current sensing resistors) are all 0.25 Ohm 5%. Therefore I charted a minimum and a maximum value for the current in each leg of the circuit.
                              The instantaneous voltage at CH1 was used for power calculations for each leg based on the Max current (min tolerance resistance value). The absolute value of that current was used. Thus all of the power values are above zero for all three legs.
                              The sum of the timer leg and load leg were compared to the B(+) leg and the 'missing' value was charted. The 'missing' instantaneous current ranged from +285mA to -305mA and may be directly related to the unknown signal. However, there is a clear indication of positive current flow through the B(+) leg at that point in time that a negative current flow exists in the load leg. The value of this event appears to be greater than the maximum recorded amplitude of the noise present, but we must realize the the scope used and the samples taken may be inadequate for GHz signals - although it did register that frequency according to Aaron.
                              Because of the very aperiodic data, I did calculate the average power for each leg to get a better overall picture using the technique mentioned above. The average timer power was 316mW. The average power for the load was 410mW. The average power for the B(+) leg was 3.5W. The instantaneous power is charted above. Note that the timer and load show the bursts while the B(+) is constant.
                              I did try to look for inductive delays and shifted current, but the data makes this almost impossible.
                              I would like to revisit this test when the unknown energy component is discovered and dealt with. We cannot overlook the possibility that it may be coming from the battery or 'noisy' sensing resistors, or an interaction between the two.
                              At first glance, it appears that this circuit is taking power from the B(+) leg and returning it to the B(-) leg by some other path. This path can be RF, thermal or some other form of energy exchange otherwise undocumented as of yet. Or it could be and exchange with another energy pool. It definitely warrants deeper analysis and study.
                              • Not sure how appropriate this is - but was wondering if the initial phase of Fuzzy's waveform went positive. Then the resonating frequency gradually transferred to the resistor?
                                Alternatively, could it be that silicone - glass crystals - being pure - also have more latent energy than is conventionally assumed. Therefore, in terms of the model? - perhaps the glass will get cloudy - over time. Just a thought.
                                EDIT - Harvey - many thanks for the report. Have just read it. This is really interesting.
