Originally posted by Turion
Bedini 1984 Generator - Page 2
Bearden in disguise as Bedini gives explanations re battery anomalies - some of which are encountered in the 3 BS here.
Originally Posted by John_Bedini
So you can resonate the ionic current, or the "coordinated" currents. Relatively speaking — that is a coordinated current dominated by massive ions with lots of inertia and overshoot when the current tries to change intensity or reverse direction, due to Lenz's law (an induced emf in a conductor is always polarized in a direction so as to oppose the change that causes the induced emf). In this case we have a multiplicity of Lenz's law effects induced when we try to change the ionic current. Some of the accompanying currents can be affected quite differently from the ion current. Because of this Lenz law complex dynamics, a simple "back pop" to oppose the ion current, or to accelerate it, is not a simple current and voltage matter at all. Indeed, the exact relationships in such are a quite worthy study for some exotic physical chemistry.
So we just grossly summarize, with rules-of-thumb, and delay the precision to future detailed studies by very fine laboratory teams.
Here's the rough secret: the chemistry of the battery is largely dominated and affected by the ion current in the absence of overriding electron current, while the external load is dominated and affected by the electron current alone. You can easily pick a point in the ion current resonance cycle (say, when the ionic current in resonance is in the battery-charging half cycle), and just instantly switch the electron current to oppose it.
That's a bit of an oversimplification; you actually must get the phasing correct to properly form new and increased overpotentials, precisely at the proper times so as to charge the battery and/or powering the load. Note that with currents moving in opposite directions, the intention is for one current to predominate in the battery in charging mode, while another current or group predominates in the load in discharging mode. If you powerfully oppose the ion current, Lenz's law is evoked powerfully, so that the ion current actually increases its charge capability for a moment, due to its massivity. The Lenz law emf and the back-popped emf also produce a tremendous stress potential (a scalar potential by another name), energetically lifting the ions and particles to a higher potential state.
That is, you momentarily increased the reaction cross section of those ions and electrons etc., and so you increased the collector systems' dipolarity. Thus they momentarily receive and collect excess energy from their increased asymmetry in their active vacuum exchange. In short, they momentarily asymmetrically self-regauge, which is taking on free excess energy from the vacuum. We note that the generation of the Lenz law emf effect actually comes from the atomic nuclei, but do not further explain it.
The point is, you just legitimately extracted excess energy from legitimate environmental sources. You converted the system into an open dissipative system, removing any necessity for it to conform to classical thermodynamics because it momentarily is far from equilibrium with its active vacuum environment.
Further, the inertia of the ions together with the Lenz law effects, causes the ions to continue in charging mode. This in turn "volumetrically squeezes" the opposing charges into a smaller volume, further increasing the charge density and thereby the potential magnitude (i. e. , further increasing the asymmetry of all those charges in the vacuum exchange, and thereby absorbing more energy from the vacuum). The production of that "charge density squeeze" produces a new kind of overpotential that we can use to power the load (i. e. , in electron discharge mode) at the same time that the ion current continues to charge the battery.
You've just got yourself a true free energy or negative resistor effect, if you can master it and use it with proper timing. Note that by simple switching (very sharply, in 5 nanoseconds or less) and phase relationships, you can take power electron current in the external circuit in the discharge mode, by simply letting this overpotential be connected to the external circuit to energize the Drude electrons. And you are momentarily doing that while you are still charging the battery.
Since you are going to be producing "discharge pulses of Poynting energy flow from the overpotentials" onto the external circuit in brief spurts, it is wise to use the "pulse discharging" to also charge a "current smoothing" capacitor of proper capacitance. Therefore you convert your "overpotential pulses" in the external circuit into smoothed rippling current through the load.
If you elaborate on these processes and play with them for awhile (like several months!), you can also see how to phase things in either "DC" through the load fashion, or "AC" through the load fashion.
But the point is, you really can induce one or more processes that allow simultaneously charging the battery (changing the chemistry in the charging mode) while discharging energy onto the Drude electron gas in the external circuit, powering them up and thereby powering the load.
And you have not violated any laws of physics or thermodynamics, and the conservation of energy law is enforced at all times.
Presently I know of no other book or paper that has such as its stated goal. The books and current research seem to all try to "coherently organize and synchronize" the various battery processes and currents to maximize charging and maximize discharging efficiency, while keeping the two completely separate. On the other hand, our purpose is to "decoherently organize and synchronize" the various battery processes and currents, to accomplish charging of the battery and discharging through the load to power it, simultaneously. In short, we seek to convert the battery and its processes into an open dissipative system capable of overunity operation, and all the way to self-powering operation while powering a load also.
The ion current can only sluggishly slow to a stop for its reversal; it requires it a finite amount of time to do that. So it continues right on charging the battery for awhile. During that ion current hysteresis or overshoot time, you have a tremendous "charge density squeeze" occurring. This gives you an overpotential to use, and you can use it in dramatically different manners, simultaneously, on differing current types.
Take the wisdom even from the mouths of the insane
stupifymeow
