    ...Thanks for being such a "Gentleman" with Our Lady!!...
    Yes, completely right...SHE does NOT likes Snubbers...Flywheelers nor Chokers...
    AGREE!
    My concern is to be a gentelemen to our electronic first in order to test the secure operation area. It does make no sense if we burn FETs after FETs in blind flight.
    i.e.:
    Start with snubbers and check what happens on every specific setup.
    Start with bulbs in series to load (i.e. car bulbs H4, H7) in order to detect failures prior to burning FETs.
    Once we have electronics secure and FETs fitting to the specific application we can get rid of bulbs and snubbers. Ready for takeoff!
    Then the appartment is ready in order to invite HER
      There you have it folks! You gotta give the lady what she likes! Then she's gonna do wonderful things for you!
      You're welcome UFO! My pleasure!
      • Hi ALL;
        my circuit diagram is the first draft.
        - I feel the exact type of optos is not essential because the 555 reconditions the signal. But the pullups at in and out (r1...R5) will be tuned for best performance.
        - Same the resistor (R6) between 555 and bases of transistors along 555 bein CMOS or NMOS.
        - Same the gate resistors (R7..R10).
        Those parameters can be tuned at real circuit only.
        I will supply the micro via a socket charger while using another one for 555s. So we are completely independent of the presence, value and spikes of load voltage.
        Everybody owns some socket chargers laying around and this is a simple chance to reuse them. You might need to add an additional voltage regulator. The LM317 is a good choice but needs additional resistors and many of you have problems with it. I prefer 7805 or 7812 fixed regulators. But please note the heat dissipation is minor to the LM317 - but still far suffitient at this specific application. We require no extra heat sink.
        • Absolutely Agree with You John!
          AGREE!
          i.e.:
          Hello My Dear Friend,
          Yes, absolutely agree with you here...We have to protect the "Tronics"...
          I love the Arduino Microprocessor as We are able to program it very accurate and seen it on our LCD Displays...awesome!
          Your concept with the Opto's is also great, they create a Space Barrier between low voltage signals and the Monster Load we are Pulsing at the other side...
          Using the 555 to enhance the Gate Drive Signals is a very smart and inexpensive way to achieve great results.
          Yes, a PC Display Interface...plus a Manual Pot would be great and enough for our testings for now...
          Let's wait for Nico...(I believe He should be busy having a great time...making excellent BBQ Meet and having some nice Argentinian Red Cabernet Sauvignon ...)...Just kidding Nico!!
          Warm Regards John,
          • Got contact to Nico -> discussing going on!
            • Hello fellow builders
              UFOPolitics, this is looking amazing. Much respect to your experience, ingenuity and patience ;+}
              I am on page 9 of this thread, fantastic reading but i just had to stop in order to express my amazement and thanks
              Amazing work !!!
              All the best,
              QV.
              • Comment
                • This is my PWM :
                  Power Pulse Modulator - OCX
                  Cheers.
                  • @ qvision
                    Just for (starting) on the small motors or neon experiments, any fet out of an old power supply or the like, or just one of the relative rating will work. I have used the IRF840 to the IRF540 for small setups to get my feet wet. Good luck and keep doing what you are doing. As you go, show us what you are up to and if any problems, let us know. All the answers are in the text but in pieces.
                    Nikola Tesla
                    • Thanks prochiro
                      Thanks very much prochiro, i can tsop being so anal about it now ;+}
                      All the best,
                      • Check the UF505...
                        Hello QVision,
                        Please check the UF505...That is exactly same thing as NTE576...
                        • Hello Prochiro
                          @ qvision
                          @UFO
                          The bearings that came with motor are rated for 12000 RPM and good static and dynamic levels. If we just set in a screw tightener as you suggested, with (no) wear in our bearing ports, do you think that is enough???
                          Dana
                          Hello Prochiro,
                          Yes, but they are Chinese...basically the rear one...I got the rear housing messed up...because of that, as also the play they come from factory...
                          I got a Japanese that would go 18,900...
                          That the locking bolt would be the final and best solution?...
                          Absolutely NOT!...It is just a Patch...
                          Now, those Housings have space to drill four holes/thread them for four locking bolts...I mean...what else could we do?...that would not become a big time project beyond the possibilities of many here making this replications?
                          If you have a better/easier/simple and cheaper idea in mind...please shut me with it, am ready... ...
                          By the way...do you have one or two Imperial Kits?
                          You should be waiting for epoxy to dry to run your motor right?
                          • @UFO thanks for the advice
                            I have ordered IRFP460 FETs.
                            I have this PWM :
                            I cannot get UF505 or NTE576/577 in the UK and cannot find anything similar on ebay or amazon.
                            Any UK builders here and what diodes are you using ?
                            All the best,
                            • Can someone in the US post me a couple of these diodes please ?
                              I will pay you via PayPal before you send.
                              Having a real hard time finding anything comparable, apart from this :
                              DIODE, ULTRAFAST, 16A, 1200V, Part # VS-HFA16PB120PBF | eBay
                              • I've ordered these :
                                HFA16PB120 Ultrafast Soft Recovery Diode, 16A IC | eBay
                                I will just have to be patient
                                All the best,
