    Now thats what I call Top Dog-One cores.
    I haven't decided what you meant about the "JIG"? I guess there are mores ways than one to skin this job even though I have not yet comprehended your method.
    Meaning the four brackets and four pieces of all-thread to hold in place the little core half atop the large core half while I wind it.
    I'll those cores were a pretty penny. Looks like you cleaned the piggy bank for sure those things should produce real results compared to the cores I have.
    Are you going with 16awg?
    They weren't cheap, especially not the big one.
    I used my own concoction of Litz wire, but it all has to come back off--the enamel cracked and there are shorts everywhere. Soooo.... I'll have to find another source for wire since my large spool of 24 AWG Essex wire is junk.
    • Sweet
      Originally posted by Web000x View Post
      It seems that when I use large capacitance, my negative power factor starts to drop off. In other words, I see the best results in the higher frequency range as permitted by my audio amp. I would suggest high voltage cap ratings if you're looking for any decent power output, at least 5kv. This gives you a lot of wiggle room.
      I don't have a 20:1 ratio. If you take into account what happens during resonance, you will see that it is easy to get high voltages across the caps. My ratio, primary to secondary, is actually 1: phi^3.
      I've been running my secondaries in series, with not a whole lot of attention to parallel. I'll get there soon..
      When I speak of not running in full resonance, it's because at peak resonance nothing novel seems to happen. My primary current and voltage are in phase very much like a conventional xfmr. However, if I tune down just south of the peak resonance in the lower frequency side, I start to see my phase angle in the primary change so that I see a negative power factor while still powering a small load. I've calculated as much as a COP of 14 with this latest arrangement, about .25 watts in and 3.5 watts out. This doesn't take into consideration the heat being developed in my series resonating capacitor. If anybody knows how to calculate conductive losses in dielectric materials in a practical situation like this, please let me know.
      80:240 turns ratio sounds like a good place to start.
      I think these transformers when running can only 'give' back so much energy. For example, if I short my secondary windings with just the series resonating cap, I get the strongest negative power factor. But when I start adding a load to the secondaries, the negative power factor starts to diminish until I get to optimum tuning like Dog-One hypothesized, most power out while still maintaining a 90 degrees phase angle. If I add too much of a load, I start to get a phase angle of less than 90. You could use all of these in a practical setting. Theoretically the negative power factor mode of operation could add magnetism back to a generator giving it motive force to turn like a motor. You could find the sweet spot of a load and a 90 degree phase angle so that the generator wouldn't 'see' the load. Or you could add a fully impedance matched load and find that your transformer is probably operating a lot more efficiently than conventional transformer. It's all about what you want to do with it. I personally am thinking in terms of a combination of the first two so that maybe I can get a rotor that spins by itself while delivering real power.
      A little confused about this. If you short the output, you get maximum negative power factor, but when you add a load, it drops off. ???
      Wouldn't a direct short be a maximum load? Seems conflicting.
      I really wanted something I could connect to a generator and see the effect of a negative power factor, but at the kind of frequencies needed, it would have to be a pretty small, multi-pole generator running at very fast RPM. I'd be curious as to what you have in mind to tackle this one.
      Regardless Dave, a calculated COP of 14 is a place I've never been. This is great inspiration; definitely something worthy of full investigation. Even all the hype about Rossi's E-Cat... It was only showing a COP of 3.5 and it requires a bunch more hardware and tuning.
      It's going to get fun when we take raw DC power, drive an oscillator and amp, push it through the SFT, rectify back to DC and compare power in/out. Seems to me the chance of a looper is certainly on the table; well within reach.
      • 14:1 COP Possible
        Well now, thats not what you use to say you couldn't get it remember?
        Nice going Dave. Thanks for the great direction on this project. Looks like you are leading the way this time.
        Mike
        • Here below is a couple of vids showing a light globe powered from a resonant tank.
          I show a drop in supply power on powering the load and an increase in supply
          power when connecting a load and a no change in supply power when the load
          is connected. Also wave forms ect. The power resistors I used to sense the
          voltage drop and determine current were not good for that frequency but the
          inductance of the resistors would be a tiny fraction of the load inductance.
          I have new non inductive resistors but am too unwell to experiment for some time.
          Scope probe placement and inverting one channel when necessary are important so as not to get a reverse measurement.
          Might be something there of interest for some here.
          At about 5:40 in the second video I show the traces for the light bulb load,
          voltage, current and power traces.
          Part 1
          Part 2
          • FarmHand Man
            Hey FarmHand
            I sure will check it out. Hope you get better. I know it will be just like that. When you are well things are going to change. These experiments like you have posted are changing the face of excess energy producing circuitry.
            Here is a well known for your review.
            https://www.youtube.com/watch?v=6WPpRjSSnAw
            Don't give up, free energy is a myth but with a little input we can get more back and in time someone will have a free running garden light like John Bedini has.
            Mikey
            Part 1
            Part 2
            • Windmill BiTT
              BiTT Power Factor 2
              https://www.youtube.com/watch?v=kNVdVrny8s4
              Mike
              • Originally posted by Dog-One View Post
                When you look at impedance matching in terms of how much power actually makes it to the secondary load, then this starts to make a little more sense. Take a look at this page: Maximum Power Transfer Theorem : Dc Network Analysis - Electronics Textbook. Notice how a lower impedance load does make the system draw more power, but the load is still not seeing its maximum possible power dissipation. This means there is a disposition of this circuit to contain more stored magnetism than dielectricity, hence 'not impedance matched'. This is where my circuit likes to operate. We have to stay 90 degrees out of convention here so it makes sense that a shorted secondary (MAXIMUM STORED MAGNETIZATION) would produce better results. Something about the stored magnetism is returning more. Parameter variation as proposed by Dollard?
                  Mike
                  I didn't want to claim anything. I have been wrong before, but I keep throwing test after test at this circuit and I can't find any potential flaws. The only thing left to do is find some resonance or build a generator to find out as my audio amplifier will show me nothing..
                  • I was going to make a video for you all to see but it seems my audio amplifier has seen too much reactive power sent back to it. It doesn't seem to work right anymore.. I don't have the means to recover tonight. Maybe I'll scrounge up some parts for my tube amp.
                    • No Surprise
                      It is no surprise to me that all of our standard circuits are only designed to BURN power, not USE power effectively. Sending power back to a circuit pushing OUT power will cause stress.
                      The point is very revealing that you have in fact overloaded and burned out your amp using a 1/4 watt of it's power output capability.
                      Great results. A tube amp can take a lot more beating than those tin can digital boxes built these days from WAL-MART.
                      Can you imagine what these circuits will produce pushing 5000hz at 200volts?
                      This will require some doing. Right now we are only able to output a few volts from our puny little audio amplifiers.
                      Great experiment showing things that we wouldn't normally expect to see like smoking your circuits on a 1/4 watt.
                      Mike
                        Mike
                        Yeah, about that.. It might just be my signal generator... It may not have liked sharing a ground with my scope probe.
                        • The grounding is a good point to bring up, from what info I've got from some
                          engineering types on the other forum I need arrange the setup and the scope
                          so that the influence of a ground loop is minimized. Also for my high
                          frequency setup 420 kHz I need to make sure there is minimal influence of
                          the field of induction on the measurements, which might mean keeping the
                          voltages down.
                          With that setup the tuned tanks can see voltages of over 1.6 Kv p to p and
                          some amps of current. With only 12.3 or so volts and under 1 amp, my
                          power supply is limited to 1 amp and does not take a reverse current, but my
                          primary switching circuit is DC and has a reflecting capacitor across the mosfet
                          so it can run with no secondary and gets about a 40 volts DC lump which
                          excites the secondary tanks.
                          But I can load it down and tune the tanks to either side of resonance and even
                          down to the lower harmonic. Would work better with an AC switched primary
                          but as you can see I get perfect sine waves on the secondary tanks and I
                          can also power transformers from the tanks in a few ways, which is where
                          I will do my tests, the main arrangement is merely a generator of HF AC, which
                          will be a pseudo "grid" for me, reactive power cannot re-bury coal and undo
                          the work it took to generate the power in the first place. So my supply not
                          taking power back there is not a problem and it doesn't cause any problems
                          for me with my own switching circuit which turns the primary transients into
                          a higher primary voltage.
                          Attached is a shot of my mosfet drain (blue) and final output (yellow) some shots of Tank voltages
                          the 1.6 Kv and a shot of a lower voltage and current (blue) sensed across a 0.1 Ohm
                          resistor, HF so phase is off.
                          The composite picture kinda goes with the videos but is only the Tank shots,
                          • Originally posted by Web000x View Post
                            This analysis is crucial Dave. I need to let it sink in a bit more. On the surface it seems there is something about having a split flux path that is giving us gains here that would otherwise not be observable with a conventional transformer. I probably need to draw up the circuit and apply all the formulas--maybe we can peer into the math enough to determine where the sweet spots are.
                            BTW, I really appreciate you using the terms dielectricity and magnetism. This helps a lot in understanding, especially if we view this device as a transmission line; one that splits and creates two new transmission lines. We may even have to tap Eric on the shoulder for a few moments and see if he can enlighten us just enough so we can take this the rest of the way.
                            • Here is a less than awesome quality video showing my setup. I tried using the HD function but it wouldn't load so I had to settle for standard quality.
                              https://www.youtube.com/watch?v=7mCx...L6cdsupqwo9-Hg
                              Here is my schematic:
                              P.S. I made a mistake in a previous post saying that my turn ratio was 1: phi^3. I was mistaken. It is 1: phi^4, or 24:162. The schematic also wrong. It says 168 turns on the secondaries, but it should say 162 turns.
                              • Lesson in Grounding
                                Hey Farmhand
                                While the setup you have from the past does not exhibit a Bi-Toroid wave form we (or I) have much to learn about operating high frequency supplies so your comments really do help solve certain technical problems.
                                I for one am willing to admit that there is always something to learn from others such as yourself. Not that I don't know the basics about your entry, because I do. Yet I think experimenters need to be kind to one another and see what each man is able to offer.
                                Thank you for your kind regards to show what you DO know about the direction that we are going. There is much I do not know about the intricate details of various types of circuitry and I say this unashamedly. What am I going to do? Tell everyone I know it all? This makes me a fool. Not this kid.
                                I have forgotten more than I remember sometimes so please refresh my memory so I will focus once again on the subject matter.
                                The thing I see with shielding and grounding at high frequencies is separate battery sourcing especially in the presences of high voltages. I was watching Aaron do this in one of his ED GRAY TUBE video's, he is not the only one who i have watched do that, just the most recent in the video's I watched.
                                We need to first focus of getting the effect up and running at any freq and any voltage. It is inevitable that we are going to need some serious circuitry for running these simple windings to their resonant harmonic or wherever we end up.
                                I think you are right FarmHand to keep the voltage down when taking measurement yet the temptation to see the waveform at higher levels will always exist.
                                I will admit that I have been out of touch with what we have covered in most of this discussion so every little bit I can pick up again to sort out in the pile of facts is always welcome.
                                Working together for a common goal using each mans abilities is what a corporate manager does. He is the boss and HE tells everyone to jump and how high they can jump and when they all get their paycheck everyone is happy.
                                On the other hand many bosses are nothing but discussing heady jerks who make it difficult to work for a measly buck and get only nominal production from the collective work force.
                                The corporate world teaches us about competition so THAT part can be a good thing however the arrogance associated with destroying a work mates character in full view of the public eye in order to make themselves a position higher has always ended in a mess.
                                What we need is grace, this very important word should be mixed with all of out interactions with one another. I see each one of us doing just that. In the best settings I have worked in no one person is an island unto themselves.
                                They share what they know and playfully use a joking slapstick wording designed to get the other man thinking and back into the competition.
                                So with that said maybe each one could offer what he knows and when the other man falls far short and we see it, don't make a big mess.
                                This is the way for experimenters to work together without doing it for money.
                                For instance I need a simple circuit to generate ac sine waves powered by a 12vdc battery. This part is not so bad but I also need an oscillator that can run 100 volts at 10,000hz all the size of a lunch box.
                                Or even make it the size that fits into a flash light.
                                I know it sounds far fetched but I want a small battery running a sinewave or close as possible, an AC converter using the standard coil method to form what is known as a VFO. I don't want a huge rack mount signal producing generator hooked to some bulky audio amplifier that puts out a low voltage for the rest of my experimenter days.
                                So this is a big task for me. Not to big just sizable.
                                Yes this is the Bi-Toroid thread and in this field of invention it is going to take everything I have learned in radio work as well as switch mode to pull this job off, so I need every bit of help I can get.
                                I won't start a job unless I am sure it can be finished. I have deemed this device worth while a few years back so what you see me post has been something that has been brewing for quite some time now.
                                We have bit off a big chunk gentlemen and it will take all of us and then some. Our advantage is that Thane, Bill, Clean and many many more can be seen proving some aspect of the invention.
                                If anyone can help me get or find circuits that are small to build a VFO at 100volts I am all ears.
                                Beyond that the high frequencies and high voltages do not have many amps to accompany, may be lethal to the inexperienced Joe Experimenter so I advise caution.
                                I see guys taking a modified sinewave INVERTER to make the frequency adjustable but this form of change does not give a broad enough range for testing purposes. In time a set frequency will become known for a specific Bi-Toroid coil set and at that point it will be interesting to see if this approach can be utilized.
                                Kind Regards
                                Mike
                                voltages down.
