Measuring
Hi Dave thanks for the notation.
The 6 light bulbs I use are 5 volts each and so I have 3 of these 5 volt lights in series. Then I have 2 sets in parallel. The lights not glowing very brightly on 7volts but just in case I measure the resistance after it ran awhile as quickly as possible.
Both measurements came to 12.2 ohms. Just for your information
See the bulbs are not being pushed to their limit so they are not hot, maybe mildly warm so the resistance is stable.
As far as the meter goes, I put it all around the back end and the amp clamp shows the same as these new meters wired directly in.
Yeah their is a slight difference on one side of the cap or the coil that is 10 feet longer. I am still testing yet I will tell you all something right now.
Every point in the secondary side does not read as expected sometimes.
It is like most of the current goes one way so maybe I need an amplifier to do this right.
For now I am glad to see what i have shown you above.
Next I will do some scope shots in the days ahead. I do things very slow and I do give up. One thing younger people do is, everything fast and are done before I ever get started.
This is going to be a project that will take at least a year to even get small amounts of excess. I say it this way because once I can determine that a device can give me what I want, I lock in and think about it, day after day.
I will be doing Pulse DC as well as zero crossing type pulsing in the days ahead. So far from my experiments, it is my personal belief that any bi-toroid/sft2 can be tuned for any frequency at a certain voltage accompanied by the current.
Once it is tuned close on both ends at that voltage adjusting the voltage up and down can reveal even higher efficiencies for that load. All of this to show a proof of a certain concept.
I will be pulling down a few standard transformers off the shelf to compare.
Keep up the good work Dave
Mike
Mike
Originally posted by Web000x
