Why perpetual motion machines do not exist
  • #31
    Aether exists and what is called virtual particles is the aether.
    Ohh ok, then explain why experiments show that virtual particles exist, actual particles like electrons and positrons coming into existence just like real particles?
    Perpetual motion is an object in perpetual motion because it overcomes
    or has no resistance to its movement. Perpetual motion has nothing to do with
    electricity, heat or any other system. It is a myth that these "laws of
    motion" carry over to other systems - you need to keep things in context.
    Keep in mind that perpetual motion is actually a requirement according to .
    First law: The velocity of a body remains constant unless the body is acted upon by an external force.
    It says the body remains in perpetual motion unless an external force acts upon the body. Unless is not a requirement; it is a condition. It does not say that a body must have external force acted up on; it says unless there is.
    Newton's first law only gives good approximation. This is because Newton's first law only holds true in an inertial frame of reference without wave-particle duality. Newton's first law is not absolutely true, in fact Newton's first law is NEVER true in this universe. This is because of things such as the uncertainty principle, time dilation, and quantum entanglement.
    It is irrelevant whether or not the probability is extremely high that an external force will act up on the body. So although that perpetual motion is a
    requirement that precedes any possible resistance, perpetual motion has
    NOTHING to do with an "overunity" electrical, heat or other system that
    doesn't involve a mass moving in some mechanical motion without resistance. And claiming that anyone that believes that a heat, electrical,
    or other system can output more than is input is perpetual motion, well,
    you only show that you have no idea about any of the differences or
    distinctions that separate these systems from each other.
    It is as ridiculous to claim these are perpetual motion claims as it is to
    claim these systems are perpetual motion. Both are ignorant.
    And furthermore, Newton believed in the aether too so don't quote someone that believes in the aether to disprove something when you are only selectively taking
    parts of his argument to benefit your belief while discarding the others. You have
    to take everything in context.
    1. And first I suppose that there is diffused through all places an aethereal substance capable of contraction & dilatation, strongly elastick, & in a word, much like air in all respects, but far more subtile.
    2. I suppose this aether pervades all gross bodies, but yet so as to stand rarer in their pores then in free spaces, & so much ye rarer as their pores are less ...
    3. I suppose ye rarer aether within bodies & ye denser without them, not to be terminated in a mathematical superficies, but to grow gradually into one another.
    - Sir Isaac Newton
    Ok, where is the evidence that this "aether" exists? Show me one experiment showing it's existence.
    • #32
      @replaced
      I'll ignore your selective arguments and will just post this as one of many
      experiments. Aether is real and e=mc2 is junk science.
      Spinning Ball Experiment – Rotating Objects, Dr. Harold Edgerton, Force Machine
      Spinning Ball Experimenthttp://depalma.pair.com/SpinningBall(Understanding).html
      The conclusions are organized:
      1. Rotating objects falling in a gravitational field are accelerated at a rate greater that G,
        the commonly accepted rate for non-rotating objects falling in a vacuum.
      2. Pendula utilizing bob weights which are rotating, swing non-sinusoidally with time
        periods increased over pendula with non-rotating bobs.
      3. A precessing gyroscope has a measurable anomalous inertial mass, greater than its stationary mass.
      4. An anomalous field phenomenon has been discovered, the OD field, which confers inertia on objects immersed within it. This field is generated by the constrained forced precession of a rotating gyroscope.
      Generation of a Unidirectional ForceOn the Nature of Electrical Induction
      • #33
        Your claim about not being perpetual motion is ridiculous - on a solar panel?
        No it is not but to say it isn't perpetual motion means you think it is a perpetual motion
        claim, which is ridiculous.
        It says the body remains in perpetual motion unless an external force acts upon the body. Unless is not a requirement; it is a condition. It does not say that a body must have external force acted up on; it says unless there is. It is irrelevant whether or not the probability is extremely high that an external force will act up on the body. So although that perpetual motion is a
        - Sir Isaac Newton
        nuff said
        Thanks for the sanity
        • #34
          If e=mc2 is junk, then why does nuclear power produce electricity and what causes the sun to produce photons?
          1. Or rotating objects are accelerated at a rate greater than G because of the effects of time dilation. Thanks for proving Einstein once more.
          More proof that general relativity exists.
        • A precessing gyroscope has a measurable anomalous inertial mass, greater than its stationary mass.
        This is EXACTLY what Einstein said would happen! The faster an object's velocity, the more it will be effected by the curvature of spacetime. An object approaching the speed of light will approach infinite mass.
      • An anomalous field phenomenon has been discovered, the OD field, which confers inertia on objects immersed within it. This field is generated by the constrained forced precession of a rotating gyroscope.
        The archetypical gravitational engine or Force machine is a combination of two counter-rotating gyroscopes with axles parallel and rotors co-planer. Constructed in 1971, the machine weighed 276 pounds. The assembly was suspended from a spring scale and the gyroscopes driven counter rotating to each other at 7600 rpm. Under these circumstances, the support cylinder was then rotated itself at 4 rpm to precess the two gyros.
        Precisely accurate measurements, consistently demonstrated 4-6 pounds of weight loss.
        RPM doesn't tell me anything, I need the velocity.
        What's this?
        Alternate View Column AV-41
        Originally posted by http://www.npl.washington.edu/av/altvw41.html
        Alternate View Column AV-41]
        At a small number of laboratories, experiments were set up to test whether the Hayasaka-Takeuchi effect could be reproduced. There was less of a "gold-rush" atmosphere about these experiments than had been the case with the cold fusion furor of the previous year. Perhaps this is because there was more skepticism that the effect was real. Or perhaps the expensive money and manpower investment in cold fusion negative results last year has made the scientific community more cautious about "table-top" experiments with spectacular results.
        In any case, the results from a few follow up experiments to test the Hayasaka-Takeuchi effect have now began to appear. A group at the University of Colorado in Boulder and the National Institute for Science and Technology (formerly the National Bureau of Standards) has reported in a paper that has just been accepted by Physical Review Letters. To within their observed error of +/-0.5 milligrams, the Boulder group observed no weight loss of the gyro and no dependence on whether its vertical rotation was clockwise or counter-clockwise. They used a brass rotor with a hardened steel shaft rotated at speeds between 1,000 and 9 ,000 RPM. The rotor turned on jeweled bearings. It had about three times the mass of the rotors used by Hayasaka and Takeuchi and an overall sensitivity to the reported effects that was about 10 times greater. There were, of course, other differences in method. The Boulder experiment had very little magnetic material in the gyro, placed it in a lucite chamber, spun it up with a jet of compressed nitrogen blown tangentially on a nylon gear, and did not evacuate the chamber. Hayasaka and Takeuchi used an integral electric motor to drive their rotor (which included magnetic material). The gyro rotated on ball bearings and was enclosed in an evacuated steel container. In a related paper that has just appeared in the journal Nature, Dr. S. H. Salter, a mechanical engineer at the University of Edinburgh, presents calculations showing that the Hayasaka-Takeuchi observations might be explained by the action of vibrations from the rotating gyro on the ball bearings of the apparatus.
        Now what you're going to do since you are obviously unaware of these
        types of experiments is to take a cursory glance at this, decide you know
        what it is without even trying the experiment, you will post your comments
        on why this doesn't prove anything and why this doesn't disprove
        Einstein, etc... all based on a couple minute response.
        After that, the only thing you succeeded in is to prove that you believe
        the world is flat and even when a trip in orbit around the world proves
        otherwise, you are still in denial.
        Your method of operation is akin to James Randi's style.
        Now I've just shown you that the gyro experiment could not be reproduced. It is wrong. People lie, "scientists" lie, and the board of Enron lied. Any real scientists knows gyros will not reduce weight when spinning. There is no reason why they would. Anyone who tries to reproduce the weightless gyro experiment fails, anyone who tries to reproduce a perpetual motion machine from a blueprint fails as well.
        Anti-gravity - Wikipedia, the free encyclopedia
        Originally posted by http://en.wikipedia.org/wiki/Anti-gravity
        Hayasaka and Takeuchi had reported weight decreases along the axis of a right spinning gyroscope.[16] Tests of their claims by Nitschke and Wilmath yielded null results.[17]
        17^ Nitschke, J. M., and Wilmath, P. A. (1990). Phys. Rev. Lett., 64(18), 2115-2116
        • #35
          [/url]
          I always laugh at people who claim to know what the sun is. Have you been there? Has anyone? Any knowledge we have on the sun is based on theories and observations (from incredible distances), not facts. This is the case for so many things in science.
          You summed it up nicely, "people lie, Scientists LIE" (but every thing youve been taught by these "scientists" is true?)
          Have you ever bothered to study for yourself or are you just recalling what you have been told?
          You seem to have some knowledge in "mans science" so Im sure you are aware of the recent results from the Hadron Collider measuring particles traveling at speeds faster than light. Are you aware that this is at least the 3rd time this has happened, the first over 100 yrs ago. What does that mean for precious E=mc2? Oh lets just write it off as a measurement error.....again.....
          The greatest minds of our time (or who I consider to be anyway) laugh at Einsteins plagarized works....and with good reason. E=mc2 is a farce, it is not all encompassing nor is it absolute.
          In regards to perpetual motion.
          I believe there to be only one source of perpetual anything in this world and HE cant be measured with a meter. Science and spirituality (religion is mans institution) have never mixed from the start, I take it on faith that my Creator is the only infinite thing in this universe. Funnily enough, you are kind of doing the same thing, by regurgitating what you have been fed by mainstream science.
          • #36
            Theory of relativity
            is being used to calculate the time in GPS satellites. If relativity was not used then GPS would give you incorrect coordinates in just 2 minutes. This is a very well known documented fact.
            GPS and Relativity
            To achieve this level of precision, the clock ticks from the GPS satellites must be known to an accuracy of 20-30 nanoseconds. However, because the satellites are constantly moving relative to observers on the Earth, effects predicted by the Special and General theories of Relativity must be taken into account to achieve the desired 20-30 nanosecond accuracy.
            Because an observer on the ground sees the satellites in motion relative to them, Special Relativity predicts that we should see their clocks ticking more slowly (see the Special Relativity lecture). Special Relativity predicts that the on-board atomic clocks on the satellites should fall behind clocks on the ground by about 7 microseconds per day because of the slower ticking rate due to the time dilation effect of their relative motion.
            Further, the satellites are in orbits high above the Earth, where the curvature of spacetime due to the Earth's mass is less than it is at the Earth's surface. A prediction of General Relativity is that clocks closer to a massive object will seem to tick more slowly than those located further away (see the Black Holes lecture). As such, when viewed from the surface of the Earth, the clocks on the satellites appear to be ticking faster than identical clocks on the ground. A calculation using General Relativity predicts that the clocks in each GPS satellite should get ahead of ground-based clocks by 45 microseconds per day.
            The combination of these two relativitic effects means that the clocks on-board each satellite should tick faster than identical clocks on the ground by about 38 microseconds per day (45-7=38)! This sounds small, but the high-precision required of the GPS system requires nanosecond accuracy, and 38 microseconds is 38,000 nanoseconds. If these effects were not properly taken into account, a navigational fix based on the GPS constellation would be false after only 2 minutes, and errors in global positions would continue to accumulate at a rate of about 10 kilometers each day!
            ...Relativity is not just some abstract mathematical theory: understanding it is absolutely essential for our global navigation system to work properly!
            Now please tell me which law or theory of science is wrong. I've just shown to you proof of time dilation. Without adjusting the clocks on satellites, they would be off by 10KM a day. This is a huge effect.
            • #37
              Sagnac effect - Wikipedia, the free encyclopedia
              • #38
                a gyro
                the feilds of a gyro ...
                a gyro makes what is called a torri ...
                a torry makes its own gravational feild .. witch is a dirrect effect from motion
                this is why a spinning item looses weight .. and at the right speed it will repell gravity .. as its gravational feild is more concentrated than mother earths .. is in that given space and time ..
                onece something is set in motion it tends to stay in motion .. with little effort!
                just like planet earth... then the birds sing .. and feed back into the system ...
                STOP KILLING THE ANIMALS .. PROBALLY WHY THE PLANET IS LOOSEING ITS ENERGY !
                STUPID HUMAN!
                THE SUN SETS UP THE STAGE ... the planets sit in there seats .. and the feedback on the planets sustains there spinn ...
                basic ALIEN where ya been?
                W
                if it gets going to fast it discharges via spark gap in my vaccumme tube ..
                humans call it a lightning strike ...
                the aether is the medium that the feedback propagates through ... the entire multiverse is aether and in the multi verse are many sheilded spheres .. that sit in seats .. there seats are made by there stage holders ..
                for earth and my stones and sheild .. and other items .. they compleate a god ! allowing them access to the devine ..
                W
                CARVED IN STONE!
                see who i am ....
                Sumerians and the Anunnaki. Presentation By Zecharia Sitchin (FULL) - YouTube
                • #39
                  @ replaced
                  i am so glad you post about the GPS as a point for your side and basic E=mc^2 and how if it was not so GPS systems would not be accurate or even possible.
                  several years ago there was an article written by a NASA engineer for the Scientific American about this exact topic and how Einstien's mathmatics were proven wrong and had to be dismissed the article was well written and should be found and read by all.
                  the second thing that keeps coming up is this speed of light and particle mass becoming infinite at the speed of light particle lasers do just this and at the speed they excellerate particles to every time this would crush the solar system out of existance.
                  please generate real facts for your arguments people.
                  Martin
                  • #40
                    @aaron
                    I've always been a pretty big fan of the way your "energy mind" works, and have learned quite a bit, and have formed how I choose to think, based on your rationale. I've also noticed your fondness for devices that employ certain techniques, over others. And, I will also say, that, you.. like myself, are quick to observe when a device seems to the lack the ability to scale up, or compete with other devices capable of a similar, but greater COP.
                    So..
                    Having said that, I wonder what your opinion on this matter is:
                    Take for example your average, newer, high efficiency heat pump - say - a variable speed Mitsubishi. I have stood beside these units, read their literature, observed their performance, heard the sales pitches, etc.. put in a bit of time, let's say.
                    Now in some cases you have a perceived COP of 3 or greater. So, for the energy in, you gain 2 additional units of heat energy out, given it's extraction of ambient heat into the loop.
                    First of all, when you talk about closed versus open systems, thermodynamics, I think it is agreed this is not a closed loop?
                    If so, .. let's look at ammonia for a second. It is a fairly narrow temperature differential that need be created to change the state of this gas, allowing for some interesting latent heat energy exchange systems, i.e. the heat pump, the RV fridge etc.
                    Traditionally we take that effect, and we transfer heat back and forth, for the sake of heating or cooling. Given. It works, and it works well, to the point of being marketable, and successful. No argument there.
                    Can we though ...
                    Operate a turbine right at the point state change. Can we employ the energy "burst" that is that latent heat being given off... to run some sort of turbine. Perhaps an adaption of the Tesla turbine... I don't know, I've only begun thinking about it... and I'm no turbine expert.
                    But I do know that the 45 degrees needed, is not a tall order, and while we traditionally use an electrical compressor, or propane flame... it's not a huge energy requirement here... not something that couldn't be accomplished with a solar heat collection device. On the cool side of the equation, the earth itself, at a depth... remains fairly constant (in a lot of areas anyhow). For example if you dig down 8 feet in the ground, despite it being possibly very hot or very cold at ground level; the temperature down below does not vary a bunch. I proved this to myself by make a refigerator that is essentially a bunker of ice 8 ft below ground surface, encased in blue foam and dirt. It stayed cold to the point of keeping food unspoiled until July 12 th.
                    Just a thought,...
                    I haven't seen anyone doing or designing such a thing and I'd love to hear your initial thoughts; given that I like how you think... I just wonder if you think this concept could possibly be worthy of further investigation.
                    Cheers & Happy Holidays
                    • #41
                      no conservation of energy - there is aether
                      My last post from early this morning is not here.
                      Anyway, why is it that believers in Einstein's relativity selectively
                      ignore all the examples of where it completely falls apart? It is
                      either right or it is wrong. If it applies only sometimes in some situations,
                      but not in others,
                      the theory is WRONG and can't even stand up as a theory anymore.
                      It doesn't even go back to a hypothesis or postulation, it becomes a
                      mistake.
                      There are many assumed "laws" or theories that are taken to be correct
                      but in reality, they are only conditions that hold true sometimes.
                      If you have a solid sphere of silver and a solid sphere of iron and drop
                      them from the same height, they do not fall at the same rate. But I
                      would guess you believe they do.
                      And the DePalma experiment does not prove Einstein is right. That is silly
                      to claim that.
                      Dayton Miller's Ether-Drift Experiments
                      That is another experiment showing the existence of the aether and
                      showing Einstein's lack of intellectual honesty by passing off the results
                      as being caused by temperature differences. When looking at the
                      evidence, it shows Einstein is really an establishment sock puppet helping
                      to maintain the status quo rather than a scientist.
                      "The effect [of ether-drift] has persisted throughout. After considering all the possible sources of error, there always remained a positive effect."Dayton Miller (1928, p.399)
                      "My opinion about Miller's experiments is the following. ... Should the positive result be confirmed, then the special theory of relativity and with it the general theory of relativity, in its current form, would be invalid. Experimentum summus judex. Only the equivalence of inertia and gravitation would remain, however, they would have to lead to a significantly different theory."
                      "I believe that I have really found the relationship between gravitation and electricity, assuming that the Miller experiments are based on a fundamental error. Otherwise, the whole relativity theory collapses like a house of cards."
                      "You imagine that I look back on my life's work with calm satisfaction. But from nearby it looks quite different. There is not a single concept of which I am convinced that it will stand firm, and I feel uncertain whether I am in general on the right track."
                      Albert Einstein: Creator and Rebel 1972, p.328)
                      Einstein says he thinks he found a relationship between gravity
                      and electricity...
                      Well, being that the aether exists when looking at the evidence
                      without Einstein's agendas intertwined in it...
                      The popular space grid with an Earth depressed in it showing space
                      is "curved" is magical pixie dust. The Earth displaces an amount of
                      Aether - that aether rebounds back to where it was displaced from
                      imparting a push on the matter of the Earth pushing objects in
                      the direction of the center of the mass. If you put a ball in water
                      you displace water (aether) and the water pushes back on the ball
                      from all sides. Rolling a ball in a dish that represents Earth floating
                      in space and showing the ball goes towards the Earth because
                      space is "curved" is completely laughable.
                      A battery or generator, etc... makes a dipole that polarizes the
                      aether, the different polarities of the aether go to different poles
                      on the dipole. Battery connected to light bulb - positive aether
                      moves from positive terminal towards negative and that positive
                      aether (positive voltage potential) attracts electrons from the
                      copper of the copper wire towards the positive terminal. That is
                      where the "current" comes from. The battery or generator isn't
                      supplying current, it just makes a potential difference inside of
                      space that polarizes the aether and the aether causes a current
                      to arise. When a battery goes dead, it doesn't have less electrons
                      than it did when it was charged. The charges in a battery are
                      simply separated to make the potential difference at the terminals
                      to polarize the aether.
                      There is the connection between gravity and electricity that in
                      my opinion makes a lot more common sense than curved space
                      nonsense as it makes sense of a whole lot more including the
                      operation of "overunity" machines and even bouncing balls. As
                      the aether is constantly streaming downward to the center of
                      the Earth - there are various dissipations and manifestations
                      happening in the center of Earth that never let the downward
                      push equalize and stop otherwise there would be no gravity -
                      some of these manifestations rise to the surface of the earth
                      like "electrons" etc...
                      That downward STREAMING dynamic potential that causes
                      the effect of gravity is what is pushing on the rubber ball and when
                      the ball bounces back up, that is where the NEW potential enters
                      the ball to push it down, etc... not because there is any potential
                      being stored by lifting it up. And is why there is no conservation
                      of energy because the work put in to lift the ball is all dissipated
                      when the peak is reached. When the new gravitational potential
                      enters the ball, that is completely different and disconnected
                      from the original input - there was no transformation of energy
                      from one form to another.
                      There is work, dissipation and an
                      establishment of a new dipole or potential difference to allow
                      new potential to come in, more work will be done, dissipation,
                      then establishment of a new dipole or potential difference,
                      new potential comes in, work, dissipation, new dipole, new potential,
                      work, dissipation, etc... of course the ball bounces less and less
                      each time because of the dissipation on impact and even if we
                      don't discuss how much work is done comparing input to output,
                      it should be obvious to a child by simple observation that
                      there is no conservation of energy.
                      dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>dipole>new potential>work/dissipation>
                      That is what happens when you pulse a coil, bounce a ball, operate
                      Newton's cradle, run Velijko's oscillator, etc... No conservation
                      of energy. All the work done is disconnected from the original
                      input work to get it going - no conservation of energy.
                      • #42
                        • #43
                          The best I've seen as something that could be perpetual motion is
                          the Finsrud machine.
                          • #44
                            Johann Bessler is one of the earliest ones I've heard of.
                            Johann Bessler - Orffyreus
                            Isn't a water wheel a perpetual motion generator?
                            How far back do they go?
                            • #45
                              The waterwheel will suffer mechanical failure eventually. Any man made material construct I can think of will eventually break down, or need repairs. Anything that mechanically rotates will suffer from friction, no matter how robust. It might work for 10,000 years but if it is not infinite it is not perpetual.
                              The phrase is baited. True Perpetual motion requires and understanding of the infinite IMO, something man has sought to understand from the very beginning, and probably will until the end of time, if there is such a thing. I guess we wont know unless it happens.
                              This is a dead end anyway. What to do with the time given to you is much more important. Yes ponder the wonders of the universe, ponder infinity and omnipresence. They say imitation is the highest form of flattery, and to strive for perfection in your designs and creations is praise to your maker in my book. Challenging mans preconceived concepts is a good starting point.
                              Peter on the Parametric transformer he built with Michael Knox:
                              "This machine was a second generation design, developed by Michael Knox and I in 1983. For years, we struggled to understand how to test it properly. Finally, in 1987, Eric showed us EXACTLY how to test it properly. From day one, Eric's equipment and methods have been impeccable. No errors in the testing procedure were made. The $25,000 valuation represented the actual cost in materials plus the estimated cost of Michael Knox's time to draw the blue-prints, fabricate the parts, and assemble the prototype. By the time the machine was fully operational, hundreds of hours of work were involved.
                              The machine operated, into a properly impedance matched load, at 108% efficiency! The machine PROVED to those of us who were there, that the "Law of Conservation of Energy" is not correct. It represented the first, hard evidence we had produced for ourselves that energy COULD be accessed in unconventional ways.
                              And Eric on the measurement procedures:
                              "The instrumental error of the Navy switchboard instruments was tested with waveform insensitive thermo electric calibrating meters to ensure no harmonic error and then accuracy was determined to be + - 2%. So we took 5 percent just to be safe. The hard work and the 25 grand was not to make a free energy fuse box, but it was a designed experiment to disprove the Law Of Conservation of Energy as we understand."
                              Kinda puts a hole right through the middle of everything we supposedly understand doesnt it?
                              • Working...
