The electric field of a magnet
  • Dave45
    Look at these pics, tell me the field isnt there and I'll shut up
    12 vdc
    12 vac
  • Dave45
    Something my pic isnt showing, Its because the image is not in 3d
  • Dave45
  • Dave45
  • Dave45
    Hi folks, in this thread you will find info found nowhere else on the net, I question everything, I make my own conclusions even if Im ridiculed over it, I take everything I read or am told by academia with a grain of salt,
    I havent resolved this issue yet but I will,
    I know,I know its a quantum or other dimensional effect that we cant comprehend or grasp..... thats bull%^%^.
    We can understand it
    I will find the answer
    dave
    what is the difference between ac and dc.... besides the effects
  • Dave45
    I drew this pic long before I seen SirZerp's vids
  • Dave45
    MM took this snapshot from one of SirZerp's vids thought you may find it interesting, check out his channel, this guy is doing some awesome work.
    dave
  • Dave45
    the model is correct now
  • Dave45
    I think this is why we have to use coax to get a clean signal otherwise we could not separate the fields with just one wire, I would really like to hear your thoughts on this.
    dave
  • soundiceuk
    Magnetism On and Off Switch - Order and Chaos - (See First 2 Links in the Video Description) - YouTube
  • boguslaw
    The saddest thing is that solution is already here in many places in the world. For example this Rusian fellow knows it : Superconductor for transformer, Power stations.wmv - YouTube
    but is really somebody interested ?
    No, everybody is looking for big $$$$
  • nueview
    jj and dave
    you put up allot of good information but it does not fit for what i saw depaqlme has made a mistake in assuming certain things.
    i can not say exactly yet but i had some ideas that i put in this thread and a few others some were from my classic education and they are wrong while some that seem a bit far oput seem to be correct.
    i need a good test and to sort this all out a bit first i found a russian video about field spins and the atom and how a spin field can be made of several charged particles moving but not with the same orbitbut creating a field loop i am seeing this as correct right now.
    Martin
  • myenergetic
    Static machine principle
    Originally posted by nueview View Post
    ok here goes
    how does a static machine develope no voltage even micro volts.
    if it is all about dielectric strength.
    then is the k factor varied and why
    if resistance can be made nothing by process then there is no real dielectric value
    how then does charge value multiply.
    i can demonstrate every effect of Dr Stiffler with my static machine.
    what then is actually going on within a coil of wire and why is it charge driven.
    why is the magnetic containment field for charge 90* out 0f phase with the charge.
    is it caused by a charge displacement on another charge path.
    ok you got it.
    Martin
    @ nueview
    Please read the following presentation special @ 7.50 and the Depalma N generator based on Faraday copper disk generator principles.
    DePalma N-machine 1/18 - YouTube
    And the following link for Violation of Law of Conservation of Charge in Space Power Generation Phenomenon
    Paramahansa Tewari: Space Energy Generator
    Dear Martin
    Thank you for running your static machine again and the enlightenment. Our concept of understanding of the classical mainstream physics have to change in order to understand what you are proposing, U made it simple but very hard to accept.
    Martin
    JJ
  • boguslaw
    Dave45
    Did you imagined that transformer with shorted coil inside by yourself only without reseaching various lost documents ?
  • Dave45
    Ed Leedskalnin said we arent using the positive, we are in some applications like radio broadcasting but not in our circuits and the positive builds up and causes heat or lenz.
