The electric field of a magnet
  • Dave45
    Its hard to find a good glue, I ran across this I havent tried it so I cant say for sure how it works, but Im going to give it a shot.
    Aluminum Adhesive-"This Glue Works" - YouTube
    Extreme Adhesives - Shop Methyl Methacrylates
  • Dave45
    Its not the angle of propagation but their spin direction that determines polarity,either cw or ccw, the angle of propagation would determine their frequency-power level.
    hmmmmmmmmmm
    gotta work
    later
    dave
  • Dave45
    I use the term ions for lack of a better term I think neutrinos would be a better description, they seem to be a neutral particle that can take on either charge and when exposed to a magnetic field they take on either a pos or neg charge, I think its their angle of propagation that determines charge polarity.
    They remind me of micro gyroscopes, we live in a sea of them, everything is a magnet, these micro particles power everything form micro to macro from the smallest cell to the planet, sun, galaxy to our universe.
    I think this energy comes from our Creator, when He spoke the physical world into existence.
  • Dave45
    this solves the problem of high voltage with no amps
  • Dave45
    this solves the problem I was having here
  • Dave45
  • Dave45
    We are working with action reaction
    the secondary's capture the primary's reaction, but the voltage surging through the secondary's will cause a reaction as well and if we dont allow for it it will oppose our system.
    We can use capacitors or a shorted coils both have interesting quality's
  • Savvypro
    The attached image is from: http://www.free-energy-info.co.uk/VladimirUtkin.pdf
    It's of the images from pages: 3, 4 and 5 - with them aligned correctly.
    Compare it to:
    Originally posted by Dave45
  • boguslaw
    yeah, they support each other
  • Dave45
  • MonsieurM
    Vesica Piscis :
    Vesica piscis - Wikipedia, the free encyclopedia
    The vesica piscis is a shape that is the intersection of two circles
    and within that shape .... you have as Walter Russell Showed us
    from Secrets hidden in plain Sight vid:
  • MonsieurM
    vesica Pisces
  • MonsieurM
    I forgot to add that there is one element we tend to forget or overlook (take it for granted )
    but all the planets ( and other elements of the Universe ) evolve in a " Vacuum" ... so if you were to replicate Russell's Coils as Savvypro mentioned:
    Looking at the picture of Jupiter, a picture of a Walter Russell coil overlaid on the planet appeared in my mind.
    testing it in a Vacuum ... think of it as a larger version of a Vacuum Tubes which coincidently Tesla worked with as well
    How to make a vacuum tube - Hack a Day
    PowerPedia:Walter Russell - PESWiki
    Nature's first principle of power prdouction and the construction of matter is to produce heat from the cold of space.
  • MonsieurM
    From either end you would see the CW and CCW of the coils. If the spacing of the coils is done right one will go with the CW and the other with the CCW, with the feilds.
    What would happen if a round magnet (e.g. 1 cm diameter x 3 cm long - that type of round magnet), was placed in the middle?
    when these two opposing ( male ( larger ) / Female (smaller) ) coils are in the right resonance .... a perpendicular vortex gets created pointing towards the center were the magnet would be just like a tornado would
    see example below:
  • Dave45
    A coil whether it be the primary or the secondary produces both fields cw and ccw and we have to allow for this.
    bucking coils
    a coil wound ccw on the left and another coil wound cw on the right are not bucking coils. put power to the center on one and then the center on the other the magnetic field is the same it does not change.
    and yes a magnet in the center will work if its orientation is the same as the coils,
