The electric field of a magnet
  • Originally posted by Savvypro View Post
    Looking at the picture of Jupiter, a picture of a Walter Russell coil overlaid on the planet appeared in my mind.
    From either end you would see the CW and CCW of the coils. If the spacing of the coils is done right one will go with the CW and the other with the CCW, with the feilds.
    What would happen if a round magnet (e.g. 1 cm diameter x 3 cm long - that type of round magnet), was placed in the middle?
    when these two opposing ( male ( larger ) / Female (smaller) ) coils are in the right resonance .... a perpendicular vortex gets created pointing towards the center were the magnet would be just like a tornado would
    see example below:
    Signs and symbols -Confucius.
    • I forgot to add that there is one element we tend to forget or overlook (take it for granted )
      but all the planets ( and other elements of the Universe ) evolve in a " Vacuum" ... so if you were to replicate Russell's Coils as Savvypro mentioned:
      testing it in a Vacuum ... think of it as a larger version of a Vacuum Tubes which coincidently Tesla worked with as well
      How to make a vacuum tube - Hack a Day
      PowerPedia:Walter Russell - PESWiki
      Nature's first principle of power prdouction and the construction of matter is to produce heat from the cold of space.
      • vesica Pisces
        • Originally posted by Dave45
          Vesica Piscis :
          Vesica piscis - Wikipedia, the free encyclopedia
          The vesica piscis is a shape that is the intersection of two circles
          and within that shape .... you have as Walter Russell Showed us
          from Secrets hidden in plain Sight vid:
          • Half of the Answer is knowing the right Question
            • yeah, they support each other
              • The attached image is from: http://www.free-energy-info.co.uk/VladimirUtkin.pdf
                It's of the images from pages: 3, 4 and 5 - with them aligned correctly.
                Compare it to:
                Regular service Signature:
                • We are working with action reaction
                  the secondary's capture the primary's reaction, but the voltage surging through the secondary's will cause a reaction as well and if we dont allow for it it will oppose our system.
                  We can use capacitors or a shorted coils both have interesting quality's
                    • this solves the problem I was having here
                      • this solves the problem of high voltage with no amps
                        • I use the term ions for lack of a better term I think neutrinos would be a better description, they seem to be a neutral particle that can take on either charge and when exposed to a magnetic field they take on either a pos or neg charge, I think its their angle of propagation that determines charge polarity.
                          They remind me of micro gyroscopes, we live in a sea of them, everything is a magnet, these micro particles power everything form micro to macro from the smallest cell to the planet, sun, galaxy to our universe.
                          I think this energy comes from our Creator, when He spoke the physical world into existence.
                          • Its not the angle of propagation but their spin direction that determines polarity,either cw or ccw, the angle of propagation would determine their frequency-power level.
                            hmmmmmmmmmm
                            gotta work
                            later
                            dave
                            • Its hard to find a good glue, I ran across this I havent tried it so I cant say for sure how it works, but Im going to give it a shot.
                              Aluminum Adhesive-"This Glue Works" - YouTube
                              Extreme Adhesives - Shop Methyl Methacrylates
                              • Look at Faraday's generator
                                Faraday Disk Dynamo - YouTube
                                This is the basis on how energy runs through a system
                                We have to build our system to emulate this basic system weather a mechanical system or a pulsed coil system.
