The electric field of a magnet
  • Iv been thinking on what a magnetic field is and cant seem to grasp it, when in a coil it reminds me of a tear in space-time that the aether rushes in to fill the void, it creates and imbalance that needs to be filled.
    They say its chaotic but I think its very ordered and balanced and seeks balance and order all the time, it can be easily manipulated and this gives the impression of chaos.
    dave
    • Betterbakeā„¢ Non-Stick 2-Piece Angel Food Cake Pan | Cake & Pie Pans | Products | Chic
      I get them at thrift stores for a buck but you can buy them new
      • The electric field of a magnet
        Hi Dave
        I have followed this thread for a while now and i believe that you are on the right track we cannot hope to achieve OU if we don't understand how the electro magnetic field vs field of a magnet works.
        I am experimenting just on getting useful work out of a permanent magnet
        and hope to get something like almost a wind up clock working with magnet power in other words instead of a spring.
        Best Johan
        • Originally posted by African View Post
          Hi Dave
          Best Johan
          Hi Johan
          Thanks and good luck with your experiments.
          We will find the right question someday.
          dave
          • MM has brought this image up and I have studied it before here is my interpretation
            The swastika represents the fields if you notice it looks like a galaxy
            The four dots are a representation of the four fields
            south magnetic field
            north magnetic field
            cw electric field
            ccw electric field
            Something Don Smith says in one of his vids he said we are already using ambient energy just not in a efficient way,
            I agree the magnets we use in our generators pull energy from the ambient whether its a permanent magnet gen or a gen using coils we are pulling in the aether, but we aren't using both sides thats where the inefficiency comes into play in the form of heat and under unity,
            I read once cant remember where that overunity was the norm and not the exception and I believe this to be true we just havent touched on the problem yet, we are running one sided.
            • Dave check this out .... i definetely think this might provide some answers to ypur previous question .... indirectly ... especially around 1:00 min
              Amazing HD Video of Planets - Stitched Together from NASA Photos - YouTube
              found originally on ATS
              Signs and symbols -Confucius.
                At 1:00 min you have flows going CW and CCW around the centre.
                As so:
                o
                o = meddle/centre
                Regular service Signature:
                  Awesome magnetic field of a planet in action, too cool
                  thanx
                  • Why dont the planets crash into each other since they are essentially magnets, if the galactic plane is the divider and planetary body's on one side are pos and the body's on the other side would be neg, this keeps the planets from crashing into each other they have the same charge they repel as in the earth and moon.
                    The earth and moon are attracted to each other magnetically but repelled because of their charge.
                    • Don also stated in the vid that the larger the diameter of the coil the more amps and the length determines voltage, very interesting.
                      • now compare it to 1:11 min or if you prefer the surface of a gazeous planet
                        • Cold electricity does not seek ground it seeks to join with the earths magnetic field and travel to the opposite pole.
                          Hot electricity which is what we use seeks ground and moves to the opposite pole through the planets core.
                          The forces would be opposite in the southern hemisphere.
                          We have to take into account we live on a magnet and we are working within the confines of that magnet, we are manipulating the magnets fields and our devices are tied into the planets fields, there's no way to get around it.
                          Even if we build a device (ufo) that is strong enough to repel the planet the fields are still tied into the planets fields.
                          dave
                            dave
                            If we were to theoritically build an efficient UFO ... It would harmoniously use all the forces that Nature provides .... in other words it would not go against the grain but rather along the grain ( anisotropy ) of nature ... observe the votexes on the gazeous planet and compare it with the appearances of ufo on certain geographical areas on our planet more than others ( principle of correspondence )
                            now here is the loop hole for you :
                            Researchers have mathematically shown that particles charged in a magnetic field can escape into infinity without ever stopping. One of the conditions is that the field is generated by current loops situated on the same plane. At the moment this is a theoretical mathematical study, but researchers have recently demonstrated that, in certain conditions, magnetic fields can send particles to infinity.
                            • Looking at the picture of Jupiter, a picture of a Walter Russell coil overlaid on the planet appeared in my mind.
                              From either end you would see the CW and CCW of the coils. If the spacing of the coils is done right one will go with the CW and the other with the CCW, with the feilds.
                              What would happen if a round magnet (e.g. 1 cm diameter x 3 cm long - that type of round magnet), was placed in the middle?
                              • A coil whether it be the primary or the secondary produces both fields cw and ccw and we have to allow for this.
                                bucking coils
                                a coil wound ccw on the left and another coil wound cw on the right are not bucking coils. put power to the center on one and then the center on the other the magnetic field is the same it does not change.
                                and yes a magnet in the center will work if its orientation is the same as the coils,
