Now ,the problem is : how to tune this ring to 400Hz (in my case of 50Hz AC) ? If that crazy 0.2mm thickness is correct that means ring is acting like tuning force generating this 400Hz , and can resonance at 50Hz is only for kicking ring into oscillation.Interesting....
How the can should be mounted on outside container ? Beer can has concave bottom , does it have to be punched in the center and mounted on SS rod without edges of bottom contacting outer container ? The more stable way would be using SS rod but also with edges of bottom supported on outside container wall (of course using some rubber insulator between).
