  • Sounds Great
    Wow Chet, that sounds great.
    Mr S
    I have a secret weapon for bringing the Ring into tolerance!
    One of the things I do to pay the bills is I make a Brush plating kit!
    Add metal wherever you need it for crankshafts machine parts etc....
    Once you get your can tuned, Put a caliper on the out side and I will make
    The Ring part to spec ,And then I will; send you a plating"Kit" with a Grafite Slug[fits in the ring]
    so you can ADD dimension with a copper or nickel [silver or Gold if you like] solution.
    We can build the Tolerance with metal solution then Hone till just right.
    if we go to far with the Hone??
    So what ................ we put the metal back on a molecule at a time!!
    Tune till perfection and perhaps????????????
    Wallah!!
    Chet
    PS
    I will extend this Tech/ offer to any serious replicator No charge!!
    • Resonance @ 60 Hz
      I can't get my 3.5" can to resonate today. I had it resonating like crazy yesterday and then tried some other cans. I can't seem to get my hanging nail located in the right place to ring against the can. It's getting frustrating.
      • Ask Mr "C"
        Can you describe how you have done it before?
        Does the nail hang in Front[of opening] ,you say it Touches??
        IMNSHO once the can is resonating it will "Transmit" a wave out the front
        which should ring a hanging nail at a specific distance [focus]from the opening?
        You see I feel the Nail could also be an optimal size [tune]?
        Perhaps someone can offer an opinion here?
        Or ask mr."C' [contact]
        Chet
        BE that change !!
        • Position of Nail
          The contact was not specific when I asked him several time, so I started experimenting on my own. I could only get the can to ring when the nail was placed against the inside edge of the can. I have my nail suspended from the ceiling via nylon fish line. The nail didn't work for me, so I replaced the nail with a small solid detachable phillips screwdriver head. It works much better for me than the nail did. I position the screwdriver head about a quarter of an inch down from the top opening on the inside of the can. I have the can pushed up against the screwdriver head. When I blasted the can yesterday from two different sides simultaneously, it resonated well. Today, I can't get the can to resonate and I've messed with it for over an hour and something.
          I have several questions in to my contact but haven't heard from him since yesterday.
          Chet
          • Trued Up
            The edge of the can is very important too. I found that once I had cut the can, I had to make sure the edge of the can was trued up and smoothed out. When you use tin snips to cut the can, it leaves a rigid edge which needs to be smoothed out so it will resonate. You do need to take care not to deform the can edge while trying to smooth it out. I've screwed up several cans so far. That thin aluminum is a pain to work with.
            • Good Job!!
              Good job!! Nice Core.
              • shhnazzy cup you have there Core
                Very nice!!
                I see you are going for a truer replication on "Davey" ! [ as you said]
                Perhaps the Tuning will be similar to the Cans? I'm hoping the can will be easier to tune?
                My take on the "Tune"
                If you look at parabolic antennae/transmitter and the placement of the "Driver"
                [out front] there is a given distance[from the front] that the "focus" takes place!
                I think the nail needs to hang/work at this focus point ?do we have any antenna men here?
                Chet
                PS
                Mr.S can you post a pic of your tuning rig?? You say you hang the nail "inside" from the ceiling?is the can vertical ?
                BE that change !!
                • Tuning Rig for Can
                  Tuning Rig for Can
                  I tune the can vertically.
                  • felt under can?
                    Is the can floating [HHMMM just had a thought]
                    I mean do you have it Hard to the ground or is a piece of "soft"[felt or??] underneath?
                    Thanks for the pix most helpful!!
                    Chet
                    Ps
                    I like you have the nail Inside[speakers can't shake the nail directly] ,IMO super lightweight brittle and straight wire would work better? [I suspect]
                    I have asked EM at the other forum [O.U.R.] for tuning suggestions using the nail and the can/cup
                    BE that change !!
                    • Surface Under Can Scenario
                      My can is on a raised hard surface to allow for proper allignment of the nail, but I don't have felt and/or any other insulator material in use between the can and the hard surface.
                      I have felt available. I'll try utilizing it and see what happens.
                      Great Idea!!
                      Chet
                      Ps
                      • Resonating Can
                        I can't get my 3.5" can to resonate today and my 5" can won't even try to resonate. I just can't get it to work today and it's so frustrating.
                        • Tuning Anodized Aluminum with Alternating Electromagnetic Fields
                          I stumbled onto this site today:
                          Nikola Tesla Plates and Tuning Anodized Aluminum with Alternating Electromagnetic Fields | Helpfulwaves.com
                          • This is some juicy info Slovenia
                            you always have some great info to offer
                            Signs and symbols -Confucius.
                            • Your Welcome!!
                              Happy to share with like minded individuals. Your welcome!!
                              • And it actually makes sense (to me )
                                COHERENCE AT ANY LEVEL IS COHERENCE AT AL LEVELS. (same for INCOHERENCE)
                                An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. This harmonic cascade of inter-connected-ness is the structure of our hologramic universe
