  • Now the fun part, where i ask you to visualize a triangle
    You guys use this type of triangle everyday but don't see it...the volume triangle in your music player...so the apex has a 0 value and the base a max value...follow me so far
    now let's take
    6 Dielectric component
    3 Dipolar
    9 Diamagnetic component
    if you look at the respective properties of a dielectric component and the diamagnetic component ; you 'll find that each will be the apex or the base of a triangle depending on the property you are looking at
    Signs and symbols -Confucius.
    • This is where you can use Rodin Math to visualize what i posted previously( just find their numerical value and reduce )....to find the right match for the components ..and end up with the image above the Star of David
      , the pole star that indicates the birth of the child destined to be ritually sacrificed (like Christ) and turned into gold.
      a very good example of this was explained by Romo and did a very good job at it...please read it starting with post#68
      • Wow, this thread is looking very colourful! I love it, nature is amazing!
        Well I have been reading Walter Russell, MonsieurM, those laws you state above... they are in Universal One too:
        Cold generates. (Cold is Electricity, the possitive, centripetal, attractive force)
        Generation contracts.
        Contraction integrates.
        Integration heats.
        Heat radiates. (Heat is Magnetism, the negative, centrifugal, repellent force)
        Radiation expands.
        Expansion disintegrates.
        Disintegration cools.
        And the cycle repeats.
        ‎"It's all in the MIND"
        • Originally posted by Haan
          Hi StweenyA,
          Zilano has been elucidating similar ideas regarding hot and cold on another thread:
          I can't say I understand the concepts yet, but I feel they are important.
          Shot As for external sources, I recommend reading Walter Russell's works (The Universal One is what I'm reading now, and I can't get enough of it, it's like music to the soul)
          So, (from my understanding so far) if electricity is cold, possitive, and attractive.... then if we can stop it from radiating heat, aka current (magnetism), then it can attract more electricity, and when it has got a sufficient amount, then we can make use of it! (think shuttling circuits)
            from: http://www.energeticforum.com/renewa...tml#post169354
            don't forget that the e field and magnetic field are codependent
            if the dielectric restricts e field (ie a small 6 ) it will compensate on the 3 and 9...think of a balloon when squeezed ...the system will always compensate to find equilibrium
            you can even see that in the properties the materials we use...such as copper...glass...etc
            glass used as capacitor...copper as conductor....you just have to find what corresponds to 6 ,3 and 9
            "Everything flows, out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right is the measure of the swing to the left; rhythm compensates."[/B]Kybalion
            "Every Cause has its Effect; every Effect has its Cause; everything happens according to Law; Chance is but a name for Law not recognized; there are many planes of causation, but nothing escapes the Law." kybalion
              Hi StweenyA,
              please read the following:
              The Principle of Polarity.
              "Everything is Dual; everything has poles; everything has its pair of opposites; like and unlike are the same; opposites are identical in nature, but different in degree; extremes meet; all truths are but half-truths; all paradoxes may be reconciled." - The Kybalion
              This Principle embodies the truth that "everything is dual"; "everything has two poles"; "everything has its pair of opposites," all of which were old Hermetic axioms. It explains the old paradoxes, that have perplexed so many, which have been stated as follows: "Thesis and antithesis are identical in nature, but different in degree"; "opposites are the same, differing only in degree"; "the pairs of opposites may be reconciles"; "extremes meet"; "everything is and isn't, at the same time"; "all truths are but half-truths"; "every truth is half-false"; "there are two sides to everything," etc., etc., etc. It explains that in everything there are two poles, or opposite aspects, and that "opposites" are really only the two extremes of the same thing, with many varying degrees between them. To illustrate: Heat and Cold, although "opposites," are really the same thing, the differences consisting merely of degrees of the same thing. Look at your thermometer and see if you can discover where "heat" terminates and "cold" begins! There is no such thing as "absolute heat" or "absolute cold"-the two terms "heat" and "cold" simply indicate varying degrees of the same thing, and that "same thing" which manifests as "heat" and "cold" is merely a form, variety, and rate of Vibration. So ''heat'' and ''cold" are simply the ''two poles'' of that which we call "Heat" -and the phenomena attendant thereupon are manifestations of the Principle of Polarity. The same Principle manifests in the case of "Light and Darkness," which are the same thing, the difference consisting of varying degrees between the two poles of the phenomena. Where does "darkness" leave off, and "light" begin? What is the difference between "Large and Small"?
              6 Dielectric
              3 Dipolar
              9 Diamagnetic
              • similar ideas regarding hot and cold
                adapt the perspective to help you understand:
                Think of magnetism and electricity as two poles of the same system
                North and South...
                ...or Male and Female
                The Principle of Gender.
                "Gender is in everything; everything has its Masculine and Feminine Principles; Gender manifests on all planes." - The Kybalion.
                This Principle embodies the truth that there is GENDER manifested in everything-the Masculine and Feminine Principles ever at work. This is true not only of the Physical Plane, but of the Mental and even the Spiritual Planes. On the Physical Plane, the Principle manifests as SEX, on the higher planes it takes higher forms, but the Principle is ever the same. No creation, physical, mental or spiritual, is possible without this Principle. An understanding of its laws will throw light on many a subject that has perplexed the minds of men. The Principle of Gender works ever in the direction of generation, regeneration, and creation.
                Everything, and every person, contains the two Elements or Principles, or this great Principle, within it, him or her. Every Male thing has the Female Element also; every Female contains also the Male Principle. If you would understand the philosophy of Mental and Spiritual Creation, Generation, and Re-generation, you must understand and study this Hermetic Principle. It contains the solution of many mysteries of Life. We caution you that this Principle has no reference to the many base, pernicious and degrading lustful theories, teachings and practices, which are taught under fanciful titles, and which are a prostitution of the great natural principle of Gender. Such base revivals of the ancient infamous forms of Phallicism tend to ruin mind, body and soul, and the Hermetic Philosophy has ever sounded the warning note against these degraded teachings which tend toward lust, licentiousness, and perversion of Nature's principles. If you seek such teachings, you must go elsewhere for them- Hermeticism contains nothing for you along these lines. To the pure, all things are pure; to the base, all things are base.
                6 Dielectric
                3 Dipolar
                9 Diamagnetic
                • To the pure, all things are pure; to the base, all things are base
                  Learn about Water and you'll understand this statement
                  • If you want to make a Russell/Bashar Coil I would Suggest using Iron and Copper..and a Cobalt nested in the center.
                    Nowadays, some cobalt is produced specifically from various metallic-lustered ores, for example cobaltite (CoAsS), but the main source of the element is as a by-product of copper and nickel mining.
                    Cobalt is used in the preparation of magnetic, wear-resistant and high-strength alloys. Cobalt silicate and cobalt(II) aluminate (CoAl2O4, cobalt blue) give a distinctive deep blue color to glass, smalt, ceramics, inks, paints and varnishes. Cobalt occurs naturally as only one stable isotope, cobalt-59. Cobalt-60 is a commercially important radioisotope, used as a radioactive tracer and in the production of gamma rays.
                    ps: for the cobalt silicate try egg shaped
                    ps: Cobalt infused quartz also exist
                      egg shaped
                      And you'll have recreated a RLC Circuit...if you prefer a RLC Triangle
                        http://www.energeticforum.com/renewa...-magnet-3.html
                        here are the various possible numerical combination :
                        from (i love this site ) The Philosopher Stoned
                        • Originally posted by Dave45
                          Lets look at what happens when the two coils are perpendicular to each other
                          I found the following which reminded me of your drawing: FREE ENERGY # 27 ELECTRICITY GENERATOR USING SINGLE MAGNETIC FLUX PATH (MOTIONLESS) - YouTube
                          the reason it also caught my attention is that the next picture also looks similar from a Russian engineer-electrician Alexander Kushelevwe previously talked about here: http://www.energeticforum.com/153539-post454.html
                          Btw: link to patent mentioned in the vid:
                          ELECTRICITY GENERATING APPARATUS ... - Google Patents
                          russian link
                          • Related to the previous post:
                            Principle of Correspondence:
                            In a world made only of waves, there would be just two geometric forms, the torus, or vortex, and the golden mean spiral. the donut, torus, form is the only structure in a world of waves that can become coherent, that is, retain a regular shape like a smoke ring. As more of these smoke rings are created and they want to relate to the first smoke ring, they must "nest" in the right pattern so that they can remember their form and still share structure. the best pathway for doing this is the ratio we call the golden mean.
                            • Scientists Link Diamonds In Strange Quantum Entanglement | Fox News
                              Scientists have linked two diamonds in a mysterious process called entanglement that is normally only seen on the quantum scale.
                              Entanglement is so weird that Einstein dubbed it "spooky action at a distance." It's a strange effect where one object gets connected to another so that even if they are separated by large distances, an action performed on one will affect the other. Entanglement usually occurs with subatomic particles, and was predicted by the theory of quantum mechanics, which governs the realm of the very small.
                              But now physicists have succeeded in entangling two macroscopic diamonds, demonstrating that quantum mechanical effects are not limited to the microscopic scale.
                              Walmsley, along with a team of physicists led by Oxford graduate student Ka Chung Lee, accomplished this feat by entangling the vibration of two diamond crystals
                              John W. Keely
                              ...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
                              "All matter is crystalic in nature" -- W.Russell.
                              • The following is a long post: John W. Keely's Forty Laws of Harmony
                                Forty Laws of
                                Sympathetic Vibratory Physics
                                (1) Law of Matter and Force
                                "Coextensive and coeternal with space and duration, there exists an infinite and unchangeable quantity of atomoles, the base of all matter; these are in a state of constant vibratory motion, infinite in extent, unchangeable in quantity, the initial of all forms of energy." (see FAQ for discussion of this law)
                                (2) Law of Corporeal Vibrations
                                "All coherent aggregates when isolated from like bodies, or when immersed or confined in media composed of matter in a different state, vibrate at a given ascertainable pitch." (see FAQ for discussion of this law)
                                (3) Law of Corporeal Oscillations
                                "All coherent aggregates not isolated from like bodies, oscillate at a period-frequency varying with the tensions that augment and diminish the state of equilibrium." (see FAQ for discussion of this law)
                                (4) Law of Harmonic Vibrations
                                "All coherent aggregates are perpetually vibrating at a period-frequency corresponding to some harmonic ratio of the fundamental pitch of the vibrating body; this pitch is a multiple of the pitch of the atomole." (see FAQ for discussion of this law)
                                (5) Law of Transmissive Vibraic Energy
                                "All oscillating and vibrating coherent aggregates create, in the media in which they are immersed, outwardly propagated concentric waves of alternate condensation and rarefaction, having a period-frequency identical with the pitch of the aggregate.
                                Scholium: All forms of transmissive energy can be focussed, reflected, refracted, diffracted, transformed, and diminished in intensity inversely as the square of the distance from the originating source." (see FAQ for discussion of this law)
                                (6) Law of Sympathetic Oscillation
                                "Coherent aggregates immersed in a medium pulsating at their natural pitch simultaneously oscillate with the same frequency, whether the pitch of the medium be a unison, or any harmonic of the fundamental pitch of the creative aggregate." (see FAQ for discussion of this law)
                                (7) Law of Attraction
                                "Juxtaposed coherent aggregates vibrating in unison, or harmonic ration, are mutually attracted."
                                (8) Law of Repulsion
                                "Juxtaposed coherent aggregates vibrating in discord are mutually repelled."
                                (9) Law of Cycles
                                "Coherent aggregates harmonically united constitute centers of vibration bearing relation to the fundamental pitch not multiples of the harmonic pitch, and the production of secondary unions between themselves generate pitches that are discords, either in their unisons, or overtones with the original pitch; from harmony is generated discord, the inevitable cause of perpetual transformation." (see FAQ for discussion of this law)
                                (10) Law of Harmonic Pitch
                                "Any aggregate in a state of vibration develops in addition to its fundamental pitch a series of vibration in symmetrical sub-multiple portions of itself, bearing ratios of one, two, three, or more times its fundamental pitch."
                                (11) Law of Force
                                "Energy manifests itself in three forms: Creative, the vibrating aggregate; Transmissive, being the propagation of isochronous waves through the media in which it is immersed; Attractive, being its action upon other aggregates capable of vibrating in unisons or harmony." (see FAQ for discussion of this law)
                                (12) Law of Oscillating Atomic Substances
                                "Coherent atomic substances are capable of oscillating at a pitch varying directly as the density, and inversely as the linear dimensions from one period of frequency per unit of time to the 21st octave above, producing the creative force of Sonity, whose transmissive force (Sound) is propagated through the media of solids, liquids, and gases, and whose static effect (Sonism) produces attractions and repulsions between sympathetically vibrating bodies according to the Law of Harmonic Attraction and Repulsion."
                                (13) Law of Sono-thermity
                                "Internal vibrations of atomic substances and atomic molecules are capable of vibrating at a period-frequency directly as their density, inversely as their linear dimensions, directly as the coefficient of their tension from the 21st to the 42nd octaves, producing the creative force (Sono-thermity), whose transmissive force (Sono-therm) is propagated in solid, liquid, gaseous, and ultra-gaseous media, statically producing adhesions and molecular unions, or disintegration, according to the Law of Harmonic Attraction and Repulsion."
                                (14) Law of Oscillating Atoms
                                "All atoms when in a state of tension are capable of oscillating at a pitch inversely as the cube of their atomic weights, and directly as their tension from 42 to 63 octaves per second, producing the creative forcce (Thermism), whose transmissive force (Rad-energy) propagated in solid, liquid, and gaseous ether, produces the static effects (Cohesion and Chemism) on other atoms of association, or dissociation, according to the Law of Harmonic Attraction and Repulsion.
                                Scholium: Dark radiant heat begins at absolute zero temperature, and extends through light, chemical rays, actinic rays, and infra-violet rays, up to the dissociation of all molecules to the 63rd octave."
                                (15) Law of Vibrating Atomolic Substances
                                "Atoms are capable of vibrating within themselves at a pitch inversely as the Dyne (the local coefficient of Gravity), and as the atomic volume, directly as the atomic weight, producing the creative force (Electricity), whose transmissive force is propagated through atomolic solids, liquids, and gases, producing induction and the static effect of magnetism upon other atoms of attraction or repulsion, according to the Law of Harmonic Attraction and Repulsion.
                                Scholium: The phenomenon of Dynamic Electricity through a metallic conductor and of induction are identical. In a metallic conductor, the transmission is from atom to atom, through homologous interstices, filled with ether, presenting small areas in close proximity. In crystalline structures, heat, which expands the atoms, by twisting them produces striae, increases the resistance, etc. Between parallel wires and through air the induction takes place from large areas through a rarefied medium composed of a mixture of substances, whose atoms are separated by waves of repulsion of various pitches, discordant to electric vibrations; the said atoms sympathetically absorb the vibrations and dissipate from themselves, as centers, concentric waves of electric energy which produces heat and gravism."
                                (16) Law of Oscillating Atomoles
                                "Atomoles oscillating at a uniform pitch (determined by their uniform size and weight) produce the creative force Atomolity, whose transmissive form, Gravism, is propagated through more rarefied media, producing the static effect upon all other atomoles, denominated Gravity."
                                (17) Law of Transformation of Forces
                                "All forces are different forms of Universal Energy unlike in their period- frequency, merging into each other by imperceptible increments; each form representing the compass of 21 octaves. Each form or pitch may be transformed into an equivalent quantity of another pitch above or below it in the scale of 105 octaves. The transformation can occur only through its static effect, developing vibrations of harmonic pitches above or below their fundamental vibration, or developing with juxtaposed aggregates, resultant and difference, or third order, as the case may be.
                                Scholium: A table of the intervals and harmonics of the normal harmonic scale will indicate the ratios in which the transformation of forces will occur."
                                (18) Law of Atomic Pitch
                                "Atoms have each a different and definite pitch, at which they naturally vibrate.
                                Scholium: Atomic pitch is determined directly
                                from its simple spectrum.
                                Scholium: Atomic pitch is determined by computations from its associate spectrum with all other atoms, as in known spectra.
                                Scholium: Atomic pitches are more important working data than atomic weights; tables of atomic pitches must be precise."
                                (19) Law of Variation of Atomic Pitch by Rad-energy
                                "The higher harmonics and overtones of projected rad-energy are of a pitch sufficiently high to cause the atom to expand; by causing the atomoles to vibrate systematically the same influence will cause the atom to contract, and thus by changing the volume, atomic pitch is varied."
                                (20) Law of Variation of Atomic Pitch by Electricity and Magnetism
                                "Electricity and Magnetism produce internal vibrations in the atom, which are followed by proportional changes in volume and, therefore, pitch."
                                ...continued
