  • This is extremely interresting but how can we incorporate this knowldege into our idea? And what gave him the idea that this could be an engine for flight?
    • I'm going to focus a bit on Atomic structure recognition and modification method and apparatus Inventor: LETOVSKY HOWARD
      i posted the patent in the previous post; as i read through it, i'll post the interesting info (you are welcome to give me a hand )
      patent has been updated in 2011 here: Self tuning frequency generator - Google Patents
      The present invention provides an apparatus which uses electromagnetic waves to identify and then quantifiably affect matter at the atomic and/or molecular level. The present invention generates frequencies (note the plural used ) that may range from DC to light waves and above, and then analyzes the transmitted, reflected, and absorbed interactions of said frequencies on any form of matter. The invention then defines and generates optimized combinations of said frequencies to create specific effects on said matter with a minimum of energy input and output.
      Electromagnetic Egg (formed by overlapping waves of various frequencies )
      if you read my previous posts, you'll recognize some of the info
      hint:
      Piezoelectricity ( /piˌeɪzoʊˌilɛkˈtrɪsɪti/) is the charge which accumulates in certain solid materials (notably crystals, certain ceramics, and biological matter such as bone, DNA and various proteins
      FIELD OF INVENTION
      [0002] The present invention relates to frequency generators, spectrum analyzers, frequency amplifiers, lasers, microwave generators, transducers, spectrometers and other frequency generating and analyzing equipment. [0003] Description of Prior Art
      [0004] various devices are used to determine the atomic and molecular makeup of organic and inorganic substances. Gas chromatographs, gauss meters, emf meters, spectrum analyzers, magnetic resonance imaging systems, frequency counters, and thermal imaging systems, all fall into this field of prior art. It has also long been understood that frequencies in ranges from subsonic, ultrasonic, microwave, lasers, and all other segments of the audio and electromagnetic spectrum can have profound effects on matter. Wind moving over bridges at specific speeds and oscillations can cause the bridges to come apart. Atomic explosions have shown that the radiated electromagnetic waves can shut down electrical devices from great distances. Microwave ovens, magnetic resonance imaging, laser beam effects on biological tissues, and the classic example of a high "C" note shattering a glass are examples of other frequency effects can have on matter. [0005] In the animal kingdom, dolphins use ultrasonic "sonar" senses to find hidden prey in the sea floor, as well as allegedly penetrate human bodies with healing frequencies. Recent evidence suggests that dogs may have the ability to "smell" cancer in humans.
      Signs and symbols -Confucius.
      • ....follow up
        FIELD OF INVENTION
        • a mine of info :
          SUMMARY OF THE INVENTION
          • Bingo
            Crystal can be shattered with the application of a "high C" audio tone. But if the goal were to melt or vaporize the crystal, the present invention may be used to activate and transmit a base frequency other than "high C", combined with an assortment of multi-order harmonics, frequency inversions, and dissonant frequencies relative to said base frequency....
            ...Said receiving and transmitting transducers 6, 8, and 10 are mechanically coupled to the interior of material analysis chamber 2, and are well known in prior art as magnetic, piezo-electric, photo sensitive, acoustic, or mechanical vibration sensing devices, so there is no need to go into specific detail of their makeup herein.
            [0035]
            (see also: Leon Sprink)
            basically create a 3d electromagnetic fractal construct (think of a 3d spiderweb ); and its properties are as any fractal construct:
            they carry a load of information ....
            Because such Construct have an 'efficient function', they have, a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
            An Egg Shaped Enhydro Quartz placed within An Electromagnetic Egg to excite an "Egg shaped" Molecule ( Tetrahedron :Water, Methane, Ammonia )
            about the water molecule see post
            http://www.energeticforum.com/153341-post175.html
            from the patent
            ... Additionally, many matter transformation effects may also be achieved including negative or positive electrostatic or electromagnetic polarization in a solid, liquid, or gaseous specimen
            see post: http://www.energeticforum.com/149183-post147.html
              If you may allow me to propose a simple exercise of visualisation, to show you that these ingredients we propose to use played a major part in most of the OU experiments realized until this day:
              Water is ""As Above so below, from within so without "
              Quartz/Silicate are all around you in the form of dust/around stars/in the core of the earth
              and High Intensity that comes from the Sun /cosmic rays/ your power plant/underneath your feet
              and these are your 3 6 9
              that can be turned into:
              same ingredient different type combination
              nano silicate with high frequency sound break water up ( Huifang XU, PiezoElectroChemical Effect )
              high frequency applied to quartz and water present in the air and the experimenter ( KOWSKY & FROST Gravity Nullification)
              UV light with water and quartz container to obtain genetic transfer of information ( MONTAGNIER : DNA Teleportation /S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, living cells transmit information through photons )
              Why does blood taste salty?
              A sodium test checks how much sodium (an electrolyte and a mineral) is in the blood. Sodium is both an electrolyte and mineral. It helps keep the water (the amount of fluid inside and outside the body's cells) and electrolyte balance of the body. Sodium is also important in how nerves and muscles work.
              Most of the sodium in the body (about 85% this number keeps popping up remember your brain has about 85% of water) is found in blood and lymph fluid. Sodium levels in the body are partly controlled by a hormone called aldosterone, which is made by the adrenal glands. Aldosterone levels tell the kidneys when to hold sodium in the body instead of passing it in the urine. (See a picture of the adrenal glands or the kidneys .) Small amounts of sodium are also lost through the skin when you sweat.
              The sun is our primary natural source of UV radiation
              I hope this makes it more apparent for the principle of 3 6 9
              ------a complement of information
              NASA - NASA Researchers: DNA Building Blocks Can Be Made in Space
              08.08.11
              NASA-funded researchers have evidence that some building blocks of DNA, the molecule that carries the genetic instructions for life, found in meteorites were likely created in space. The research gives support to the theory that a "kit" of ready-made parts created in space and delivered to Earth by meteorite and comet impacts assisted the origin of life.
              "People have been discovering components of DNA in meteorites since the 1960's, but researchers were unsure whether they were really created in space or if instead they came from contamination by terrestrial life," said Dr. Michael Callahan of NASA's Goddard Space Flight Center, Greenbelt, Md. "For the first time, we have three lines of evidence that together give us confidence these DNA building blocks actually were created in space." Callahan is lead author of a paper on the discovery appearing in Proceedings of the National Academy of Sciences of the United States of America.
              ------and
              DNA could act as an antenna in electromagnetic communications
              A theoretical physicist has presented research that shows bacteria might transmit electromagnetic signals to produce species-specific wavelengths.
              According to research presented by Northeastern University physicist Allan Widom, based on existing knowledge of DNA and electrons, bacteria can indeed communicate.
              Luc MONTAGNIER DNA Teleportation
              A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
              According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
              Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
              --------which leads us back to:
              principle of Correspondence:
              Imagine a medical tool where you take a UV laser pointer and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
              • Guys, i don't know if you listened to this Coast to coast show, very intriguing
                Elenin, Meteorites, & Alien Encounters
                3Coast To Coast AM - 25.8.2011 - 3/4 - Elenin, Meteorites, & Alien Encounters - YouTube
                keep this in mind when you listen to it:
                In the version of the Ogdoad creation myth used by the Thoth cult, Thoth created Ra-Herakhty, via an egg, and so was said to be the father of Neferhor.
                (Both Thoth and Hermes were gods of writing and of magic in their respective cultures. )
                  08.08.11
                  ------and
                  Great minds think alike. It just shows that you, my friend, are on
                  • Thank you Shawn, i would rather call it Gaea's mind, since i'm not the only one working on this thread
                    just a complement info on the coast to coast show, which i would really like you to listen to
                    Isn't he describing this:
                    Just wanted to post this info because its representation is nothing more than a Fractal representation:
                    Multiverse = Many Worlds, Say Physicists - Technology Review
                    Enjoy
                    • here is the written report on the alien description
                      Earthfiles.com Environment | Part 1: New Zealand Abductee Describes Alien Pyramids and Symbols, Time Travel and Sound/Color Communication
                        I have longed beleived that heaven and hell are both interdimensional and connected physically with an area on earth that is most attuned to their frequency. Which is why hell when described as fire and brimstone is often described as being in the middle of the earth, which we both know is molten iron and nickel. It is not that hell is literally in the center of the earth but that interdimensionally is is most like that dimesnion and therfore the only place that can connect with that dimesion as physical / interdimensional doorway. Much the same way Heaven is also another dimension or percieved reality in which there once was a place on earth made so that it could connect to it. This place was referred to as the garden of Eden which has obviously long been destroyed. But if we could find the exact location of the orignial garden and rebuild it we could possibly reopen that interdimensional doorway between heaven and earth. We might find their half guarded by an angel with a flaing sword, which would not allow us to enter, especially in our degraded state but it would be interresting non-the-less to have a re-established open forum with a higher intelligence that could at least cross through to / on our side. Yet this is just what I beleive their ir really not much to support this assumption other than belief. And probably a really dangerous thing knowing that we could connect with a higher plane of more devious consequences such as hell. I'm not really sure we are ready for either.
                        ,Shawn
                        ,Shawn
                        • Originally posted by shawnnweed View Post
                          ,Shawn
                          ,Shawn
                          It is not up to us to decide....
                          "Everything flows, out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right is the measure of the swing to the left; rhythm compensates."
                          read this page, insightful
                          Gnostic.Org: The Kybalion
                          the Hermetic Philosophy considers that the Universe may be divided into three great classes of phenomena, known as the Three Great Planes, namely:
                          I. The Great Physical Plane. II. The Great Mental Plane. III. The Great Spiritual Plane.
                          These divisions are more or less artificial and arbitrary, for the truth is that all of the three divisions are but ascending degrees of the great scale of Life, the lowest point of which is undifferentiated Matter, and the highest point that of Spirit. And, moreover, the different Planes shade into each other, so that no hard and fast division may be made between the higher phenomena of the Physical and the lower of the Mental; or between the higher of the Mental and the lower of the Physical.
                            Bingo
                            from the patent
                            sounds interresting but how could we tell what was going on within. And wouldn't a microwave have a similar effect.
                            • as you said we already have a successful experiment in (thanks IndianaBoys ):
                              Dr. John V. Milewski: Growing Gold from Glass in a Microwave (principle of correspondence )- Part 1
                              ‪Dr. John V. Milewski: Growing Gold from Glass in a Microwave - Part 1‬‏ - YouTube[/QUOTE]
                                sounds interesting but how could we tell what was going on within. And wouldn't a microwave have a similar effect.
                                I think there are computer simulator software that could do the work for us to visualize what is going on and get the right frequencies
                                papers on Simulating Microwave Oven:
                                Simulation and Experimental Method for Microwave Oven
                                3D Electromagnetic Field Simulation in Microwave Ovens:
