The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • Originally posted by shawnnweed View Post
    all these talkings of eggs is makin me hungry. Seriously though, are you suggesting a ring in ring matrix(like in the movie 'contact') or an egg in egg matrix.
    not going that far, just observation
    here follows the definition of a fractal construct :
    A fractal is "a shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,"[1] a property called self-similarity.
    let's suppose that the Tesla Set up + Rodin coil + Tesla egg, too long to type, I'll just Call it Ankh Set up (we are still in the thread on Hermes )
    Let's suppose the Ankh Setup if fractal , if i slice up an egg, it should reflect one part of the set up (ie Rodin Coil;at least approximately )....
    a sliced egg also respects the above definition of a fractal (principle of correspondance )
    pay attention to the grain of the yolk
    EggMath: The Shape of an Egg
    Chickscope 1.5: Explore: EggMath: The Shape of an Egg
    London building
    Signs and symbols -Confucius.
    • side note: just posting this pic , it looks intriguing to me, it's called an Egg Tangram, with the Cut out of the pieces you make birds with it
      you can see the birds here: nrich.maths.org :: Mathematics Enrichment :: Making Maths: Birds from an Egg
      I do recall Egyptian having sacred birds and pyramids
      • just so you can visualize what happens in a magnet
        The golden ratio has been spotted in a magnetic compound.
        Access : Solid-state physics: Golden ratio seen in a magnet : Nature
        each is an image of the other (principle of correspondance, Tesla knew this )
        • Originally posted by IndianaBoys View Post
          MonsieurM,
          Reminded me of this:
          Left = cymaglyph of adult dolphin voice,
          Rigth = cymaglyph of a baby dolphin calling to its mother
          SpeakDolphin - Research Projects > PRESS RELEASE: Deciphering Dolphin Language with Picture Words
          Also, Dolphin Bubbles: An Amazing Behavior:
          Dolphin Bubbles: An Amazing Behavior - YouTube
          IndianaBoys
          the dolphin vid is amazing, watch at 1:15 , spot the infinity sign
            ...then the golden mean spiral can be used to calculate how wide the next torroid must be and the distance it needs to be from the next. Then all that has to be done is figuring out energy input to make them resonate.
            Yes The Golden mean is the key, but you'll have to recalibrate the next donut according to the previous in size of the donut but also the size of the copper wiring, etc...
            Tesla took this into account when building his coil (principle of Correspondence )
            how do you tune a musical instrument....
            It is always in relations to the previous key, and in the musical scale, the golden ratio is king
            "I consider this extremely important,. said Mr. Tesla. "Light cannot be anything else but a longitudinal disturbance in the ether, involving alternate compressions and rarefactions. In other words, light can be nothing else than a sound wave in the ether..
            Electronic tuner - Wikipedia, the free encyclopedia
            In the Discipline of music an electronic tuner is a device used by musicians to detect and display the pitch of notes played on musical instruments. The simplest tuners use LED lights to indicate approximately whether the pitch of the note played is lower, higher, or approximately equal to the desired pitch. More complex and expensive tuners indicate more precisely the difference between offered note and desired pitch.
            Tuners vary in size from units that can fit in a pocket, clip on an instrument, sit on a table-top, all the way up to 19" rack-mount units. The more complex and expensive units are used by instrument technicians, piano tuners and luthiers.[
            and the Ankh set up is a "musical instrument" of sort
            • Let's do some more slicing up, you won't be hungry this time around
              Take a vortex and do the same thing, horizontal slicing, you also get stacked up Rodin Coils
              the vortex
              A fractal is a geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,"[1] a property called self-similarity.
              sorry for the visual exercise...good for the brain
              side note: the study of hurricane and tornado are two field with data on vortex (principle of correspondance )
              • and the same applies to the emf egg (formed by the primary and secondary coils of the Tesla Coil )
                which makes me think that the secondary coil may be better if it looked like the lower part of the Ankh sign (to have correspondence of different sizes like the sliced egg)
                  MonsieurM,
                  Now plug this in:
                  Terence McKenna Timewave Zero Novelty Theory 1/3
                  Terence McKenna Timewave Zero Novelty Theory 1/3 - YouTube
                  Time 3 minute 48 ....second fractal pattern of the entire wave......
                  Worth listening to this in full.
                  IndianaBoys
                  in relations to the doc
                  have you watched the doc i posted here :
                  with what you know now (water, emf, etc...), it will make total sense (if you look closely, you can see in the doc, anisotropy at play )
                  before you watch it, I would like you to read this
                  The Foundation Series is a science fiction series by Isaac Asimov. There are seven volumes in the Foundation Series proper, which in its in-universe chronological order are: Prelude to Foundation, Forward the Foundation, Foundation, Foundation and Empire, Second Foundation, Foundation's Edge, and Foundation and Earth.
                  The premise of the series is that psychologist Hari Seldon spent his life developing a branch of mathematics known as psychohistory, a concept of mathematical sociology (analogous to mathematical physics). Using the laws of mass action, it can predict the future, but only on a large scale; it is error-prone on a small scale. It works on the principle that the behaviour of a mass of people is predictable if the quantity of this mass is very large (equal to the population of the galaxy, which has a population of quadrillions of humans, inhabiting millions of star systems). The larger the number, the more predictable is the future.
                  Foundation series - Wikipedia, the free encyclopedia
                  which is one of the first books I learned English on
                  For many years, Robert A. Heinlein, Isaac Asimov, and Arthur C. Clarke were known as the "Big Three" of science fiction.[6]
                  listen to Richard C. Hoagland, what he has to say about Sir Arthur C. Clarke here:
                  note the time wave theory seems to be compatible with Carl Calleman 9 Wave theory
                  The Mayan Calendar
                  • From : http://www.energeticforum.com/renewa...ex-tube-2.html
                    Originally posted by Stealth View Post
                    That is an interesting theory. I am not sure anyone knows what all happens in a vortex except maybe Schauberger. If you observe a fast moving river, where an obstacle partially blocks the flow of the river, it increases speed and pressure in that section. After it has exited the obstacle, it creates a vortex, where the increased speed and pressure start a spinning action where the exiting water is combining with the incoming water. This vortex whirlpool creates a vacuum of sorts and pulls all materials in close proximity into it. Any medium in a vortex is subjected to high speed and pressure and this rapid acceleration can very easily cause sound waves which could produce standing waves. A tornado has a whistling sound that can be heard for long distances. If we could harness and control a vortex in a machine of some type, it could produce more than enough power to accomodate any usage we might have. I have always considered the colder, denser air to be the key to self powering one. If we could reintroduce it into the vortex at the precise point, would it increase many times its present strength? Good Luck. stealth
                    thank you Stealth
                    • you should read this article found it on a thread (can't remember which one )
                      but here is the link the page for download
                      New Energy Technologies was a printed magazine published by Faraday Lab Ltd (The English version) in 2001-2005
                      new energy technologies, issue #1
                      just scroll down and press on download button
                      New Energy Technologies magazine
                      • Signature of Antimatter Detected in Lightning | Wired Science | Wired.com
                        During two recent lightning storms, Fermi recorded gamma-ray emissions of a particular energy that could only have been produced by the decay of energetic positrons, the antimatter equivalent of electrons. The observations are the first of their kind for lightning storms. Michael Briggs of the University of Alabama in Huntsville announced the puzzling findings Nov. 5 at the 2009 Fermi Symposium.
                        water cycle (sometimes you have to turn the picture around to see it )
                        • Principle of correspondence, if this phenomenon arrives in the atmospheric "egg" , we could suppose that it happens on a smaller scale, within the Copper egg or the emf egg which contains the exact same ingredients found in the atmosphere...
                          in different portions, but there nonetheless...transmutation anyone
                          see: http://www.energeticforum.com/154181-post287.html
                          • The following picture of the Ankh Set up with the Emf Egg included...Hieroglyphic Style
                            [IMG][/IMG]
                            overlap all three you end up with the infinity sign
                            • [QUOTE=shawnnweed;154263]
                              @slider
                              MonsieurM,
                              Then he showed how 'engineered' anisotropic movement could help to attain 'thrust' with absolutely no chemical reaction through the ascending sized stacked balls, and you grasped it immediately, I was sitting in the corner and going 'so what it's just a trick.'
                              Let's change a little bit of perspective (that's the beauty of a fractal construct, it takes the shape you desire it to be as long as it is fractal ; principle of mentalism also called analogy )
                              Now imagine the Universe is a tree...
                              How do you think trees get water from roots to leafs (pricinple of correspondence and polarity )
                              wood it anisotropic, Natural Antigravity Trees do it everyday
                              More on Why Tree Trunks Spiral
                              When I worked for NOM 's Environmental Research Labs in Boulder, we were once asked why lightning sometimes spirals down the trunk of a tree. While the answer was not proven, we observed that the path of least resistance might follow the spiral grain of the wood (anisotropy ). I eventually found a tree with a spiral lightning mark and it followed the spiral grain exactly. One tree, of course, proves nothing.
                              link:
                              More on Why Tree Trunks Spiral, Alaska Science Forum
                              Originally posted by morpher44 View Post
                              As Rodin has been saying, "everything is a coil".(Principle of mentalism )
                              That is a pretty profound statement.
                              which pretty much is the same think as saying everything is a fractal antenna (rodin's coil rated high in military test for antennas ).
                              If it is so, we should consider the whole universe as a cosmic antenna/coil, logic
                              now everything inside that cosmic coil is also a coil, so you have star coil, planet coil etc... and they all resonate to this "cosmic Schumann resonance"
                              or in other words we are all in direct harmonic relations with the rest of the universe, right?
                              now read this:
                              John W. Keely
                              ...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
                              i let you ponder on that...
                              hint: think of cosmic communication, or Tesla's mars transmission
                              it also shows you the role played by water
                              The Universe
                              water is present everywhere
                              WATER IN THE UNIVERSE
                              The Paper
                              - Ben Rich ( a colleague of Dr Boyd )
                              When Rich was asked how UFO propulsion worked, he said, The questioner responded with, Rich then said,
                              Extraterrestrial UFO Are Real : Ben Rich Lockheed Skunk Works Director Admitted In His Deathbed Confession |Latest UFO News| UFO 2011 Sightings|Alien Pictures|2011 Solar Flares|Disclosure Project|Web Bot
                              Isn't he describing this:
                              Just wanted to post this info because its representation is nothing more than a Fractal representation:
                              Multiverse = Many Worlds, Say Physicists - Technology Review
                              Enjoy
                              • hope you are liking this
                                a Different Universal Tree
                                "As above so Below, from within so without"
                                fyi: you are not different than a tree
                                Arterial tree - Wikipedia, the free encyclopedia
