  • MonsieurM
    Originally posted by StweenyA View Post
    Sorry, I meant about the water boiling or exploding.
    in a way since all is vibration...but less efficient...think of it as one being a brute force and the other more like a swing using small push to increase vibration of water
  • MonsieurM
    I love it when patterns appear to connect like minded Discoverers
    Meet the Tube for producing multiple Wavelength ....Or the Caduceus Tube
  • StweenyA
    what do you mean
  • MonsieurM
    found the original...did not know it was his design:
  • MonsieurM
    Would that work kind of how a microwave works?
    what do you mean
  • StweenyA
  • MonsieurM
    and this one looks a bit...
    this one:
    and the angle maybe taken from one end of the sphere to the end of the second sphere ....you can trace two lines with both sphere of each ring within those two lines
    the last set up reminds you of anyone
  • MonsieurM
    and Lakhovsky held the same belief as Tesla On the matter of Cosmic rays
  • MonsieurM
    this comes from an interesting article , applicable to Peter Davey's Sonic Boiler
    KeelyNet: Joel McClain: Measurement of Resonant frequencies and Harmonics | MERLib.org
    April 25, 1994
    Thanks to information supplied by Gerald O'Doucharty, as compared with waveform analyses as determined by the late Mr. Les Brown, we can begin to make some progress in the understanding of resonance. I believe that these conclusions are in accordance with the discoveries of both Walter Russell, in his resonance based chart of the elements, as well as those of John Keely.
    Les Brown dropped a pebble in a bowl of water, and measured the rings which resulted. From this, he was able to determine the mathematical relationships, which he found to be factors of PI. There is no random pattern to the rings.
    The first ring is equal to the diameter of the pebble. The second ring is equal to the diameter of the first ring, times the cube root of PI, or 1.3313. The third ring is equal to the second ring, also times 1.3313. Each ring is a NATURAL HARMONIC of the previous ring. Comparing this with the information supplied by Gerald, we can see that in the diatonic scale, the following relationships exist:
    Whole
    Note Frequency (Hz) 1st Harmonic (UPPER ORDER)
    C 262 F 349.33 Hz
    D 294.75 G 393.00
    F 349.33 A' 465.06
    G 393.80 C 524 (262 X 2)
    A 436.66 D 581.33 (294.75 X 2)
    C' 524 F 698.66 (349.33 X 2)
    Semi- Notes
    E 327.50 A 436.66
    B 491.25 E 654.00 (327.50 X 2)
    Energies, including radio waves, propagate according to the same ratios, based upon the cube root of PI. To an energy researcher, this means:
    1. Energies are based upon the atomic model. Therefore, the rings which surround each atom are based upon the size of the nucleus (pebble), and this is the base frequency of the atom. Each ring diameter will be determined by the cube root of PI, times the nucleus, and then times each ring in succession.
    2. Once you find the resonant frequency of the nucleus, to resonate the atom, you will need to determine the number of rings, and apply the correct number of harmonics at the correct frequency. This is true for an element, whereas compounds will require each of the fundamental frequencies, plus the harmonics.
    Let's say, for example, that a hydrogen nucleus resonates at G, or 393 Hz.
    To resonate the aggregate hydrogen atom, you must apply G as well as C, the first harmonic, or 524 Hz. If oxygen has a fundamental frequency of A, or 436 Hz, then you must also apply D, or 589.5 Hz.
    To resonate water, you would apply 393, 436, 524, and 589.5. However, this may not be a "hard and fast" rule, because we know that the highest frequency will contain all of the lower frequencies at harmonic intervals, but at lower amplitude.
    Therefore, if a single resonating frequency is used, it will have to be of high enough amplitude so that the harmonics are "felt" by the element or compound.
    The frequencies in the above example are based upon the arbitrary values assigned in 1939, because they "sound" the best. However, the multiplier of the cube root of PI is a constant. So, when you find the fundamental frequency of an atom, you can apply this constant to resonate the aggregate mass, including the rings.
    Just multiply the constant times the fundamental freq for the first ring, and multiply the constant times the first ring for the second ring, etc. As Gerald pointed out, there are inconsistencies in the man-made chart, so experimentation is required. However, Les Brown's constant will apply regardless, ONCE THE FUNDAMENTAL FREQUENCY has been determined.
    Referring to Russell's chart of the elements, we find that the number of elements per octave corresponds to the number of whole notes per octave on the diatonic scale. Isotopes consist of semi-notes and harmonics. As such, once we begin to analyze elements, we can quantify Russell's chart, and determine the exact combination of frequencies for each element, isotope and inert gas.
    Russell obviously knew these correlations, or he would not have been able to create the chart in the first place. We have to "reverse engineer" the chart to determine the frequencies. Using the cube root of PI, combined with experimentation, I believe that that is possible to do.
  • MonsieurM
    and those familiar with Rodin Math:
    Exploding water with 42712.2Hz
    4 + 2 + 7 + 1 + 2 + 2 = 18 = 1 + 8 = 9
  • MonsieurM
    I don't know if i posted this version of the 3 6 9
    SVPwiki : 15.18 - Keelys Process for Liberating Ether from Water
    SVPwiki : Mass Chord
    "The mass chord of any mass is that lowest or fundamental vibration to which that mass is resonant.
    "As every mass consists of vibrations in thirds, balanced in harmonic? equilibrium, it stands in harmonic relation to every other mass. All forms of matter and motion are thus interrelated and mutually convertible, one into the other, and through resonance, increasing or diminishing this sympathy, we can control the states of matter." (Keely)
    "In his researches Keely discovered a system of obtaining the "chord of mass" or keynote of all substances, whether mineral, vegetable or animal. He does not give or even hint at the method by which this was obtained, and it is supposed this is the "one detail" which he kept secret until his one patentable invention was to have been completed.
    but what you have to realize is that he left us a clue....Exploding water with 42712.2Hz...and Harmonic Math will definitely allow you to find the frequency to boil water
    from the link on water
    Water is a ready and fit subject for vibratory research on account of its "differential volume" and gravity of its gases. Even on simple thirds the differential action between hydrogen and oxygen causes antagonism and dissociation. The differential of mass is such that the hydrogen and oxygen become thoroughly repellant and thereby exhibit thousands of times more force than could be induced by heat on the same amount of water. Vibration of antagonistic thirds, sixths and ninths on the mass chord will compel progressive subdivisions and to get the best effect on water, the instrument is set on all of these. First, the focalizing chord of sixths induces perfect harmony to the mass chord.
  • Dave45
    Dave, got a little challenge for you...Remember the first vid in http://www.energeticforum.com/renewa...-crystals.html
    4-22 In Search Of... The Bimini Wall (Part 3 of 3) - YouTube
    guess who is talking in the doc ...Dr Vogel
    ...Have a look at the crystal pushing the magnet ...and if you can give me an explanation based on what we have learned...Electric field and Magnetic Field
    You got me on that one bro, thats pretty wierd.
  • MonsieurM
  • MonsieurM
    Some of you may have found this confusing:
    FYI
    Electromagnetic Wave Localization in Photonic Fractals[/U][/B]
    Fractal structures have no periodicity and no translational symmetry like crystal structures.
    remember Walter Russell's Law of Crystallization
    Let me put it this way:
    Fractal is 6 and Crystal is 9
    a Crystal will emit a Fractal and a Fractal will create a Crystal (ie you )
  • MonsieurM
    did some research on Keely found this:
    PowerPedia:John Keely - PESWiki
    Some believe that the research of Nathan Stubblefield and his Earth battery system utilizing copper rods and iron rods. One could sink them in, probably, even at best, utilize Stephan Reiss's method for water-production by drilling very deep into the rock to hit fresh water - so Keely connected with Stubblefield, and Reiss hinted at equals battery-power from the earth's magnetic field using the earth-battery or magnetic induction amplifier of stubblefield, then this can be used for voice transmission over long distances, and also then a specific shape vibrated and driven into the ground, for water-receival.
    Water disassociation
    SVPVRIL Water Disassociation page - Keely's Dissociation of Water - General Description of Apparatus and Demonstrations
    (from Keely's physics):
    The Dissociation of Water.
    Frequency of Hydrogen- 42,800 / 6562.79 (Hydrogen) = 6.5216.
    Frequency of Oxygen- 42,800 / 7775.43 (Oxygen) = 5.5045.
    (Note: Dissociation occurs at about 5.5 and 6.5 times the frequency of hydrogen and oxygen).
    "He (Keely) discovered that it is impossible to use the (A)ether in any way other that as a medium for other forces. These forces have to do with the polar stream of the earth and are tuned to by Keely's system of "sympathetic vibration" (i.e. by resonance of certain harmonic chords). In following a course of research in resonance phenomena, Keely achieved a very advanced understanding of the Universe"...
    Post From JoesCell2 (this is the opinion of a private person):
    Keely found that water will explode at a frequency of 42,712.2 Hz. ... did it with a Quartz Bowl....Think Quartz and how symmetry applies to magnets because that is how quartz crystals are formed, via symmetry. The 42,712.2Hz was applied to a quartz bowl with distilled water at which time it EXPLODED and disappeared. After this experiment Keely began studing geometric shapes that hold these specialized frequencies which can manipulate matter and the mind. So the power of the mind possibly can be realized by the special shapes that Keely discovered from special frequencies. if you know how this works you wouldnt even need a Joe Cell to make power and after a while not even the special shapes because you could use your voice. i will add that if you want your joe cells to work better place it on a 10 or 12 point tesseract made on copper foil. You can get it at lowes home improvement in their building materials section.
