  • shawnnweed
    Here is a thought. I do not how 'out to lunch' it may be but it worth pondering. When you study ionic propulsion it is said that due to the electrons rate of speed, due to higher voltages, over the surface of a given metal that it actually grabs the air around it and forces the air in the direction that it is flowing. At least this is how I understood it.
    I also watched a video where a scientist built a capacitor from two copper cups and a glass flask. They showed how the metal cups could be charged with electrons, positive in the top copper cup and negative in the bottom copper cup. These two copper cups had a glass flask separating them because we know what happens when a positively charged metal meets a negatively charged metal, the sparks begin to fly. However they removed the charging leads and then removed the two copper cups, from the glass flask, and touched them together and guess what...no spark. Yet when they reassembled them with the glass container the electricity was still there and it discharged when they shorted them. It was said that the electricity must have been stored on the surface of the glass. We all know that capacitors are for storing high amounts of electrical voltage. And once again the voltage being on the exterior.
    What if the voltage, as we know it flows along the exterior of metal while amperage flows in the interior? Just a thought through observation. Would this make a difference when it comes to superconducting?
    ,Shawn
  • shawnnweed
    I would have to agree with this assessment. We know that according to the first law of thermodynamics that all energy in an enclosed system, such as the universe, will remain the same but will inevitably change forms from solid to liquid to gas or to plasma. There obviously has to be a base element and that element would be the one of the highest frequency. Now for that element to change into another would depend on certain forces or combination of forces. Time, gravity, pressure, magnetism, heat, cold, polarity, etc. will cause all matter or its individual properties to change. But to learn what particular forces cause effectual change across the board of elements would be a massive undertaking that only God himself could figure out. After all we are still adding to the periodic table. It took us 6,000 years to split the atom. We still aren't sure exactly what light is and until recently thought that light was the fastest record-able speed. For the most part we are children fumbling in the dark and only discovering at the rate in which our imagination meets out intellect. But I love you train of thought; it's quiet logical.
    ,Shawn
  • MonsieurM
    slight correction: 6 is your target, 3 your control wave and nine the resulting wave (ie the new element)
    principle of correspondence:
  • MonsieurM
    You are quite correct...you have grasped the essence of the concept that Walter Russell And John W. Keely were trying to convey
    6 is your target and 9 your control wave
    John W. Keely
    ...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
  • electronicsounds
  • electronicsounds
    Never tell a man he's not free
    We must be very thankful for the internet because we can meet people with mutual interests, because you won't be able discuss teachings and concepts that are outlawed by the current indoctrinating system with everyone and as the title of this reply says, never tell a person he's not free. Whenever I try to discuss anything revolutionary I always get that ''you believe all the s**t you read on the internet'' reply. It is very difficult to get people to think, they prefer to follow like sheep do.
  • Dave45
    I may not have said this enough,
    Dave and the rest of you guys....
    I feel blessed to have met you ...knowing that a New Paradigm is about to be born...I want you all to know that we would not be here if it was not for you guys...so I am humbled and blessed to hold this discussion with Great Minds such as you guys...as my friend says may the Angels walk along side you
    The feeling is mutual my brother
    May God Bless you and keep you and protect you in all your en devours.
    your servant
    dave
  • MonsieurM
    Principle of Mentalism: Universe is all Waves
    One of the most subtle way found to control the Vox Populi is this
    and I am allergic to them ...truly
    think of the knot as a 3....long piece of cloth dangling as the 9.....
    if the 9 is long....and the system has be in equilibrium.....then the 6 will be very small (ie a restrictive effect on your brain development )
    Most of the free spirited inventors did not were ties.....
    Necktie - Wikipedia, the free encyclopedia
    The necktie traces back to the time of Thirty Years' War
  • MonsieurM
    I just wanted to mention this for the curious mind and important ...For most of the research done on medical use of electromagnetic waves; one aspect has been overlooked and that is to obtain optimal results such as in the use of Violet rays....the Antenna / the patient has to have followed an Alkaline Diet...In this research I have found that Alkaline Water and Diet enhances the healing aspect of the body.
    ---------------------from a previous post http://www.energeticforum.com/renewa...tml#post163380
    This structuring is best assayed with a UV spectro-photometer where one finds an increase in UV absorption due to an increase in the water bonding from the water forming chains on itself. The magnetic moment of this structured water is increased by 0.07 gauss and there is also an increase in the pH and dielectric conductivity.
    sorry for the repetition;
    key word quartz
    Edgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
    " Animated ash was a form of bamboo that was reduced to activated charcoal by means of a partial vacuum electrical carbon arc process. The resulting ash (alkaline ) pH in the system with
    a tendency towards alkalinity.
    Imagine a medical tool where you take a UV laser pointer or violet ray and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
    so to increase the UV effect, an Alkaline diet would be recommended
    Cancer Healing & Spirituality (4): Edgar Cayce on Cancer Causes and Treatment (2)
    sorry for the repeat wanted to post the rest of the paragraph
    from The Legacy of Marcel Vogel
  • MonsieurM
  • Dave45
    The frequency you would need frequency 528 Hz (DNA repair frequency ?) : NO MUSIC single tone - YouTube
    I believe it could be done, would be a worthwhile en devour, after we get FE I will go in this direction.
    Tesla found that the electric field healed the body, I probably read it in one of your posts
  • MonsieurM
    You know A vogel cut crystal is easily found on ebay, before you start experimenting using your own knowledge ...re-read the posts on crystal and health in this thread
    Now, hope you are ready for what follows....change of perspective:
    A Caduceus Coil is Helical like an Alpha Quartz...Obeying the Principle of Correspondence / Harmonic Math, I can therefore consirder A Caduceus Coil as a Crystal ....now this would make more sense when i say this
    Fractal is 6 and Crystal is 9
    a Crystal will emit a Fractal and a Fractal will create a Crystal
    you ponder on it
    good to read you Dave
    and remember:
    Believing is Seeing...........you are an Emitting Antenna as well
    you can start here http://www.energeticforum.com/renewa...tml#post156660
    reminder: this is all open source....so please share results...don't forget the 7 principles are always at play
  • Dave45
    You should guys re-read that article...you are informed now
    also The Legacy of Marcel Vogel
    Applicable to a Caduceus Coil and your DNA as well
    This needs to be put into practice, it would revolutionize the medical field,
  • MonsieurM
    Marcel witnessed and photographed the precipitation of Light into crystal The blue flash contained information which formed into a geometric form. This geometric form was the source of the crystallographic form from which the crystal grew and developed2
    The flash of blue light witnessed through the microscope was the transfer of information from the level of light-coding to the physical plane. This is discussed in metaphysical literature, but had never before been witnessed and photographed.
    to avoid any confusion, the following pictures are just a representation...it was originally posted here:
    The crystal is a quantum converter that is able to transmit energy in a form that has discreet biological effects. This is most likely a resonant effect
  • MonsieurM
    Discovery of a 'dark state' could increase maximum theoretical efficiency of solar cells from 31 to 44 percent
    The maximum theoretical efficiency of the silicon solar cell in use today is approximately 31 percent, because much of the sun's energy hitting the cell is too high to be turned into usable electricity. That energy, in the form of "hot electrons," is instead lost as heat. Capturing hot electrons could potentially increase the efficiency of solar-to-electric power conversion to as high as 66 percent.
    Zhu and his team previously demonstrated that those hot electrons could be captured using semiconductor nanocrystals. They published that research in Science in 2010, but Zhu says the actual implementation of a viable technology based on that research is very challenging.
    Chemists propose explanation for superconductivity at high temperatures
    , or cuprates, that conduct electricity without a shred of resistance at temperatures much higher than other superconducting metals. Yet no one has managed to explain why these cuprates are able to superconduct at all. Now, two Caltech chemists have developed a hypothesis to explain the strange behavior of these materials, while also pointing the way to a method for making even higher-temperature superconductors.
    All superconducting cuprates start as magnetic insulators and are transformed into superconductors through "doping," a process that involves removing electrons from the parent compound, either by substituting certain atoms for others or by adding or removing oxygen atoms. Still, no one knows what it is about doping that makes these cuprates superconduct.
    But the cuprates are different. They still operate well below freezing (the highest of the high-temperature superconductors, a cuprate created in 1993, has a maximum Tc of about -135˚C), but some can be cooled using liquid nitrogen. This makes them much more practical, since liquid nitrogen is plentiful and its cost is about a hundredth that of liquid helium.
    It took Goddard and Tahir-Kheli five years to figure that out. Their hypothesis is that when enough dopant atoms are added, the plaquettes are able to create a percolating (cascade ) pathway that allows electrons to flow all the way through the material. The magnetic electrons outside the plaquettes can interact with the electrons traveling through the plaquette pathway, and "it is this interaction that leads to the electron pairingthat in turn results in superconductivity," Tahir-Kheli says.
