Multiple LCR resonance Circuits
  • #46
    • #47
      The conclusive 4 Tuning Fork Experiments (part 1)
      Lead-out/Bring-in Energy - kinetic energy of air molecules The First Divine Revelation is once more confirmed. The experiment is definitely scientific and can be repeated at all teaching Universities with 4 or more identical tuning forks on resonance boxes, a microphone and a computer program that can display the sound waveforms.
      • #48
        Resonance Experiment - YouTubekinetic energy of air molecules can be brought-in at resonance. That fact does not violate the Law of Conservation of Energy. If this NEW concept is correct, we may be able to use a similar technique to bring-in gravitational energy or magnetic energy. In particular, we may be able to bring-in the electron motion energy with multiple LCR circuits in resonance.
        Thanks to the Almighty for such a Divine Revelation.
        • #49
          Using a guitar as a resonance box
          We all know that a tuning fork held by hand will not sound very loud. The loudness increases greatly when the end of the tuning fork is pressed on a flat surface.
          One very good surface is the resonance box.
          I decided to try to use a normal guitar as a resonance box. I placed the vibrating tuning fork firmly on the guitar. As expected, the sound was much louder.
          The previously accepted explanation was that a larger surface was caused to vibrate and hence the louder sound. Can a different explanaton be correct - more kinetic energy of air molecules are brought-in to create the louder sound?
          What is scientific dogma (sticking to established teaching and object to all alternative explanations)? How should a true scientist approach such a challenge?
          • #50
            more efficient use of the striking force
            • #51
              Longest sound on Aug 20, 2011
              Reply 14.
              That configuration produced the longest sound so far as of Aug 20, 2011.
              Further confirmation that kinetic energy of air molecules can be brought-in???
              • #52
                Divine Revelation 1 cannot be wrong. Both theory and experimental evidence confirm that.
                If kinetic energy of air molecules can be brought-in at resonance, can electron motion energy be brought-in at multiple LCR resonance?
                • #53
                  You'll then be creating a wave (like the ocean wave )
                  Signs and symbols -Confucius.
                  • #54
                    Absolute confirmation of Divine Revelation 1
                    I now have the signal generator from China. I can produce a constant sound with given frequency and amplitude.
                    Please see the above link for the waveform comparisons.
                    I cannot strike the tuning fork with the same force every time. However, I can adjust the signal generator to provide the same sound every time!
                    Thank you to the Hong Kong Government for the HK$6,000. It is being spent wisely. The oscilloscope arrived yesterday too. Fun time begins.
                    • #55
                      Shock wave
                      The plan is to send a shock wave to the scientific community.
                      A new understanding of resonance and bring-in energy is here.
                      • #56
                        The Michael Prototype in USA
                        Lead-out/Bring-in Energy - Flux Change Systems
                        Please follow what happens via the above link.
                        The systematic approach may lead us to the Steven Mark TPU logically.
                        Multiple LCR resonance circuits are definitely worth investigating.
                        • #57
                          More discussion with Prof J
                          The four tuning fork video would still have its scientific and historic value
                          • #58
                            The first oscilloscope measurement on Michael prototype 005
                            Please follow the measurements from above link.
                            Need to add the electronic components to turn them into LCR circuits.
                            • #59
                              Testing the Tseung prototype from Hong Kong
                              See reply 26 and 27.
                              I used the oscilloscope to repeat and double check the prototype performance. I still have my best prototype from Hong Kong. With the wires spread well apart, I managed to get a Tseung FLEET Comparison Index (COP?) of 89. THe best figure from Hong Kong was over 200.
                              I then played with the wire spacing - placing them closer. One of the results was definitely over 100. However, in the playing around, my poor soldered joints fell apart. I decided to put the prototype on breadboard and achieved a result of around 89 again.
                              The most interesting curves are the power curves. The Output Power Curve was much larger in the area covered - both positive and negative. Overunity was confirmed beyond any shadow of doubt. Please check the diagrams for yourselves.
                              Multiple LCR circuits in resonance is the right direction to go.
                              • #60
                                Ordered another Atten Oscilloscope
                                The Hong Kong set up with 2 oscilloscopes will be repeated in USA.
                                Tuning will be much easier. Comparing the Input and Output power and other waveforms directly is easier with two oscilloscopes.
                                The tuning forks, the signal generator, the electronic snap kit 303 and the two oscilloscopes may be good investment for any group interested in multiple LCR research.
