  • you asked the question...for you to find the answer
    but i think this may give you the answer
    dave when you read the post, think of two ice tubes
    Signs and symbols -Confucius.
    • hey... no, I'm not sure what the answer is, that's why I'm still asking the question
      ‎"It's all in the MIND"
      • Originally posted by StweenyA View Post
        Genesis:
        "6 And God said, "Let there be a firmament in the midst of the waters, and let it separate the waters from the waters." 7 And God made the firmament and separated the waters which were under the firmament from the waters which were above the firmament. And it was so. 8 And God called the firmament Heaven."
        There are different way of looking at it, but i'll give you my take on it
        Let there be a firmament in the midst of the waters = Stanford researchers have developed a battery that takes advantage of the difference in salinity between freshwater and seawater (the waters ) to produce electricity. (see image above )...
        when you look at water on earth, in liquid state it comes in various form:
        fresh, salty, alkaline, acidic, distilled, quantum, ferroelectric etc....
        ------also
        Firmament - Wikipedia, the free encyclopedia
        The word "firmament" is meant to correspond with the word raqia, or raqiya` ( רקיע), as used in Biblical Hebrew.
        Firmamentum was used in the Vulgate, a 4th century Latin translation of the Christian bible. This term was consistent with the previous (circa 200 BC) Septuagint translation of the Old Testament which used the Greek stereoma, meaning solid structure, and with the notion of solidity advanced explicitly by other biblical passages.[3]
        The original word raqia is derived from the root raqa ( רקיע), meaning "to beat or spread out", e.g., the process of making a dish by hammering thin a lump of metal.[2][4] Raqa adopted the meaning "to make firm or solid" in Syriac, a major dialect of Aramaic (the vernacular of Jesus) and close cognate of Hebrew.[2] Language experts consider that the most accurate English translation for raqia in biblical Hebrew is "expanse" (i.e., that which was stretched out) and that "firmament" is a mistranslation (due to confusion with Syriac).[2] Among modern translations, NIV and ESV use the word "expanse", while the NRSV uses "dome".
        The choice of translation is controversial because it affects how prominent the discord with modern cosmology first appears. It is argued that liberal Christians (and nonbelievers) are biased toward accepting a translation that favours critical and nonliteral interpretation (e.g., "firmament") whilst conservatives and fundamentalists seek a translation by which the scripture may harmonise with scientific knowledge (e.g., "expanse" implying empty sky).
          MonsieurM,
          Of all the years observing SOHO (Solar And Heliospheric Observatory), never have seen an event such as what is happening today with the sun.
          Here is that database for researching the suns activity:
          Search and Download SOHO Near Realtime Data
          Select:
          Image Type = LASCOC3
          Resolution = 512
          Display = Movie
          Start and End Dates:
          Start = 2011-07-23
          End = 2011-07-23
          Then click search.
          You can also change the dates to see other time frames such as this Mercury in Retrograde event:
          Type in the date range of - 2001-01-01 to
          2002-01-31
          This will be 1,285 pictures for January 2001.
          IndianaBoys
          You are changing, and it is out of your control, welcome to a new era....enjoy the ride
          Piezoelectricity ( /piˌeɪzoʊˌilɛkˈtrɪsɪti/) is the charge which accumulates in certain solid materials (notably crystals, certain ceramics, and biological matter such as bone, DNA and various proteins
          from: http://www.energeticforum.com/renewa...llector-9.html
          DNA could act as an antenna in electromagnetic communications
          A theoretical physicist has presented research that shows bacteria might transmit electromagnetic signals to produce species-specific wavelengths.
          According to research presented by Northeastern University physicist Allan Widom, based on existing knowledge of DNA and electrons, bacteria can indeed communicate.
          As i said before, we are all "Fractal Antennas" amongst other things
          DNA could act as an antenna in electromagnetic communications | TG Daily
          The sun is our primary natural source of UV radiation
          Principle of Rythm:
          "Everything flows, out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right is the measure of the swing to the left; rhythm compensates."
          Puzzling Scientists; Earth's Upper Thermosphere Collapses
          Summary: "The thermosphere", the layer of Earth's atmosphere that meets space, recently collapsed and is now rebounding again...and we don't know why. The thermosphere is important because it shields us from the Sun's Extreme Ultraviolet Photons.
          Before It's News
          read this post if you want to understand : http://www.energeticforum.com/153076-post152.html
          -----the following image is quite useful to our research
          • In our earlier discussion, we talked about tetrahedron just as a visual aid i found this on water:
            a nugget which i found reading sonoluminescence: sonofusion explained[/B]....
            i found this info here: (the cosmic egg )
            Method & Apparatus for Splitting Water Molecules Dr. Andrija Puharich M.D
            Method and apparatus for splitting ... - Google Patents
            see how to grow a perfect ice
            http://www.energeticforum.com/renewa...gnetism-6.html Starting at #168
            hint
            : electromagnetic egg = Cosmic Egg
            • just to remind you that you can print the page in pdf....
              • Methane ice
                It seems methane bonds with ice, very interesting.
                LivePaths.com: Green Power from Burning Ice
                I wonder if its conductive
                  Methane ice
                  read the following posts on methane/methanol + water
                  • Ezekiel 1
                    16The appearance of the wheels and their work was like unto the colour of a beryl: and they four had one likeness: and their appearance and their work was as it were a wheel in the middle of a wheel.
                    the color beryl
                    Beryl - Wikipedia, the free encyclopedia
                    Notice the middle one looks like ice
                    the color beryl
                    fire waterfall Yosemite A rare sight - Yosemite National Park "fire" waterfall
                    • from the wikipedia link you posted:
                      The name beryl is derived (via Latin: beryllus, Old French: beryl, and Middle English: beril) from Greek βήρυλλος beryllos which referred to a "precious blue-green color-of-sea-water stone"[1] and originated from (india )Prakrit veruliya (वॆरुलिय*) and Pali veḷuriya (वेलुरिय); veḷiru (भेलिरु) or, viḷar (भिलर्), "to become pale";
                      remember this post: http://www.energeticforum.com/152464-post362.html
                      Beryl of various colors is found most commonly in granitic pegmatites, but also occurs in mica schists in the Ural Mountains, and limestone in Colombia. Beryl is often associated with tin and tungsten ore bodies. Beryl is found in Europe in Norway, Austria, Germany, Sweden (especially morganite), and Ireland, as well as Brazil, Colombia, Madagascar, Mozambique, Russia, South Africa, the United States, and Zambia. U.S. beryl locations are in California, Colorado, Connecticut, Idaho, Maine, New Hampshire, North Carolina, South Dakota and Utah....
                      In the United States, aquamarines can be found at the summit of Mt. Antero in the Sawatch Range in central Colorado. In Wyoming, aquamarine has been discovered in the Big Horn Mountains, near Powder River Pass.
                      now the fun part:
                      from: Sacred Places North America: 108 ... - Google Books
                      Even
                      Sangre de Cristo Mountains just a short drive from Colorado Springs, CO
                      • Ezekiel 1
                        So the color of the wheels were as the color of ice
                        Salt is conductive, it is expelled from ice over time but will leave the ice structured
                          now the fun part:
                          You dont think Tesla was using crystals naaaaaaaaaaaa
                          but hey he invented everthing else If he didnt put it into a mechanical apparatus he wrote about it.
                            Ezekiel 1
                            the color beryl
                            It almost looks like the one's Iv been freezing
                            Just needs a little salt
                              from http://www.energeticforum.com/153076-post152.html
                              even simpler http://rexresearch.com/rahn/rahn3.pdf on page 5
                              The same authors found that even the dissolution of NaCl
                              in water produces & growth-stimulating radiation (Table 14) This
                              energy emission occurs only during the act oI dissolving
                              ; it- ceases
                              completely when all the salt i8 in solution' No effect is noticeable
                              when sugar is dissolved in water, or when palmitic acid is dissolved
                              in alcohol. Wolff and Ras concluded therefore that the process
                              of dissociation of salt into ions is the source of ultraviolet'
                              truly this document is full of info that could be applied to the rest of the Electromagnetic Spectrum (principle of correspondence )
                              now salt water is Na+ Cl + H2O right and when it dissolves, the act of dissolving produces UV light...read what follows
                              John Kanzius: RF-Induced Hyperthermia vs Cancer -- RF Ignition of Salt Water: US Patent Application # 0060190063
                              John KANZIUS
                              Salt Water-Fuel
                              Filling a test tube with salt water from a canal in his back yard, Kanzius placed the tube and a paper towel in the machine and turned it on. Suddenly, the paper towel ignited, lighting up the tube like it was a wax candle.
                              "Pretty neat, huh?" Kanzius asked WPBF's Jon Shainman.
                              Kanzius performed the experiment without the paper towel and got the same result -- the saltwater was actually burning.
                              File:NaCl polyhedra.png - 维基百科,自由的百科全书
                              ------ principle of correspondence
                              @petar113507
                              So why does silicone become superconductive when doped with boron?
                              A neodymium magnet (also known as NdFeB, NIB, or Neo magnet), the most widely-used type of rare-earth magnet, is a permanent magnet made from an alloy of neodymium, iron, and boron to form the Nd2Fe14B tetragonal crystalline structure.
                              The magnet is an anisotropic ( see post: http://www.energeticforum.com/148190-post73.html and http://www.energeticforum.com/148982-post137.html Dave you should read this one if you did not already ) (sintered ceramic containing neodymium, iron and boron (NdFeB). The anisotropic nature of the material (meaning that it has properties that differ according to the direction of the measurement) is due to the tetragonal crystalline structure of the NdFeB molecule.
                              i'd recommend you check Walter Russell's periodic table/crystal table to check if you see a link
                              read page 6 of this thread you'll find some interesting info http://www.energeticforum.com/renewa...er-coil-6.html
                              [/QUOTE]
                              • Looks like salt is worth a try, will be in next experiment.
