  • Harvesting Energy From the Sun Using Crystals
    I have read on several place on the web that the atlanteans used sunlight harvesting crystal has a power source. Big metalic domes were used in combination with crystals. Does anyone know where to find info on that?
    Atlantis and Crystal Technology (article) by John P Johnston on AuthorsDen
    You might be interested in this video.
    YouTube - ‪4-22 In Search Of... The Bimini Wall (Part 3 of 3)‬‏
      Solar power without solar cells: A hidden magnetic effect of light could make it possible
      Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
      Quartz
      Although quartz is not conductive (meaning it doesn't carry electricity like most metals such as copper), it has certain electrical properties that make it very useful for certain electronics. In particular, it is piezoelectric. "Piezoelectricity" is a word derived from the Greek word "piez" or "piezein", meaning "to press"; Piezoelectric materials are non-conductive materials which generate electricity when you subject them to pressure, and vice-versa: They undergo physical deformation when you run electricity through them. If you compressed a pice of quartz using a pair of pliers or a vise, it would generate a very small electrical charge, and if you connected a piece of quartz to either end of a battery, the crystal would bend or warp slightly. These effects are too small to be visible to the human eye; You won't actually see the crystal bending or shaking, and you won't notice sparks coming from it, but there will be very tiny effects, and these can be detected and used by electronic circuits.
      Information on electronic quartz crystals
      Quartz resonators consist of a piece of piezoelectric material precisely dimensioned
      and orientated with respect to the crystallographic axes. This wafer has one or more
      pairs of conductive electrodes, formed by vacuum evaporation. When an electric field is
      applied between the electrodes the piezoelectric effect excites the wafer into mechanical
      vibration. Many different substances have been investigated as possible resonators, but
      for many years quartz has been the preferred medium for satisfying the needs for
      precise frequency generation. Compared to other resonators e.g. LC circuits, mechanical
      resonators, ceramic resonators and single crystal materials, the quartz resonator has
      proved to be superior by having a unique combination of properties. The material
      properties of quartz crystal are both extremely stable and highly repeatable. The
      acoustic loss or internal fraction of quartz is particularly low, which results in a quartz
      resonator having an extremely high Q-factor.
      The intrinsic Q of quartz is 107 at 1 MHz.
      Mounted resonators typically have Q factors ranging from tens of thousands to several
      hundred thousands, orders of magnitude better than the best LC circuits
      . The second key
      property is its frequency stability with respect to temperature variations....
      ...Modes of vibration, cuts and
      frequency ranges
      The AT-cut resonator uses the thickness shear mode of vibration (fig.3). A standing
      wave is set up in the crystal blank by the reflection at both major surfaces of traverse
      waves travelling in the thickness direction. The major mechanical displacement is in the
      plane of the crystal at right angles to the direction of wave propagation. At resonance
      an odd number of half wave lengths are contained in the thickness plane of the crystal
      blank
      . Therefore the thickness is the primary frequency determining dimension.
      Signs and symbols -Confucius.
        just FYI:
        the Law of Crystallization provided by Walter Russell in his magnum opus The Universal One
        for the piezoelectric property see also : Radiation pressure
        Radiation pressure - Wikipedia, the free encyclopedia
          one more think i would like to add and i think it is very important
          If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.
          want to know more check out this post:
          also
          Quartz Crystals
          Electron Tubes by John Morecroft, 1933 starting page 334...
          Fixing Frequency by Piezo-electric Crystal
          Quartz Crystals
            "You cannot invent, you can only discover" - Gordon Plummer
            This is wisdom!
            /Peter
              This is wisdom!
              /Peter
              Thank you
              here is a person who did create a circuit that is quite interesting:
              Steven GIBBS Hyper Dimensional Resonator
              Basically, I use an HDR with a double terminated quartz crystal and a barium oxide bar magnet. The bar magnet is attached to the end of the HDR electromagnet and the quartz crystal is placed inside the witness well. Before I place the quartz crystal in the witness well, it will be charged up inside a crystal pyramid.
              These energies are what boost the frequency of my astral body and allow me to jump to the future. If my jump is only a month I am OK, but if I need to do a long jump, like a hundred years into the future, then I use a Tesla Coil alongside the HDR. The Tesla coil provides the zero vector that I use to tunnel into the future. You need more energy to travel further.
              Steven Gibbs -- Hyper Dimensional Resonator -- astral time travel
              type in google: rexresearch (or keely net) and quartz, then just select any link you'd like to explore...Maybe you'll notice a pattern in the use of crystal...
                To all those who already built resonators to capture/amplify ambient energy and get a few microvolt, maybe Quartz resonators is the way to go....
                from what i have read, it is the perfect tool for coupling and amplifying
                  also
                  Gravity Nullified
                  Quartz Crystals Charged by High frequency Currents Lose Their Weight
                  those willing to do some further research, here is a trick:
                  Although some remarkable achievements have been made with shortwave low power transmitters, radio experts and amateurs have recently decided that shortwave transmission had reached its ultimate and hat no vital improvement would be made in this line. A short time ago, however, two young European experimenters working with ultra-short waves, have made a discovery that promises to be of primary importance to the scientific world.
                  The discovery was made about six weeks ago in a newly established central laboratory of the Neuuartadline-Werke in Darreskein, Poland, by Dr Kowsky and Engineer Frost. While experimenting with the constants of very short waves, carried on by means of quartz resonators, a piece of quartz which was used, showed a clearly altered appearance. It was easily seen that in the center of the crystal, especially when a constant temperature not exceeding 10 C / 50 F was maintained, milky cloudiness appeared which gradually developed to complete opacity. The experiments of Dr Meissner, of the Telefunken Co,, along similar lines, according to which quartz crystals, subjected to high frequency currents clearly showed air currents which ld to the construction of little motor based on this principle. A week of eager experimenting finally led Dr Kowsky and Engineer Frost to the explanation of the phenomenon, and further experiments showed the unexpected possibilities for technical uses of the discovery.
                  Kowsky & Frost -- Gravity Nullification -- Science & Invention, Sept. 1927
                  remember this article i posted
                  doesn't it sound similar
                  Joel McCLAIN & Norman WOOTAN
                  The Magnetic Resonance Amplifier
                  With low-level ultrasonic input signals, the Magnetic Resonance Amplifier (MRA) produces usable direct current power at levels above unity. This circuit is based upon the work and theories of John Ernst Worrell Keely, and is offered into the public domain in his memory.
                  Introduction ~
                  Without lengthy discussion about the aether, tetrahedral geometric aggregate resonance or the Rule of Nines, it is possible to understand this circuit as basically a tuned magnetic and quartz amplifier..
                  Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
                  What is an ultrasound?
                  Ultrasound is a safe, painless diagnostic procedure that uses high-frequency sound waves to create images of organs and body structures.
                  now you get the idea
                    About this:
                    use this
                    Parabolic to fiberoptic (open source project)
                    Parabolic to fiberoptic - Open Source Ecology
                    Jeffery Gordon has proposed and constructed prototypes for arrays of small parabolic dishes concentrating sunlight into fiberoptic cables. a 1 mm diameter cable can carry about 16 watts (due to the limits of concentrating ability) of sunlight into a nearby lab where it may be used for various processes. The advantage of this setup is that the array of small dishes can track the sun like a flat panel collector, and do not require huge support structures. Also, the sunlight can be used in a controlled environment, rather than precariously at the top of some large structure. This enables such things as the creation of nanostructures through solar ablation and surgical procedures with beams of sunlight rather than lasers. Both of these have been accomplished by Dr. Gordon.
                    one more thing to add:
                    Fractal structures of gold obtained by diffusion limited
                    aggregation in alkali halide crystals
                    Electromagnetic Wave Localization in Photonic Fractals
                    Fractal structures have no periodicity and no translational symmetry like crystal structures.
                      posted this earlier in another thread, but this thread is a more suitable:
                      Originally posted by goldsphere View Post
                      I have started reading his book The Evolution of Matter. I highly recommend everyone to do the same. I understand why Moray went on to work with transmutation in the years after he demonstrated his wonder box.
                      Adept Alchemy
                      Part II
                      Modern Arcana
                      Chapter 5
                      Adept Alchemy (Robert A. Nelson): Transmutation of Lead to Mercury
                      Prof. Arthur Smits and Dr. A. Karssen (Univ. of Amsterdam) published reports of their alleged transmutation of lead into mercury and thallium in 1924. Their work was inspired by that of Prof. Miethe, who claimed to have transformed mercury into gold in a modified Jaenicke mercury ultraviolet lamp. (4, 5)
                      The lamp was constructed of lead quartz. Two legs (A, B), ending in narrow tubes, contain two steel electrodes cemented with sealing wax. The electrodes were inserted in two small removable copper water coolers (G, H). Pure liquid lead was poured into storage vessel C, after which the open end was sealed off. The lead was kept liquid at 350o C by an electric furnace around C. Tube D contained capillary F and terminated in stopcock K, which was connected to a mercury diffusion pump (Fig. 5.1)....
                      ...After that we burned the lamp at 40 A/80 V for 10 hours
                      why you ask? how about this:
                      see also Sprink experiment: Leon Sprink - Antigravity - patents
                      Thomas Henry MORAY
                      Radiant Energy Receiver
                      [p. 66] Dr Moray... described the radio detector he had developed... He compared it to what was commonly known as the crystal of a crystal set . However, his detector was superior since it could drive a loudspeaker without the use of a battery...
                      about
                      It is a Fractal set up of the Crystals (just search crystal and fractal )
                      Computational Modeling of New Kinds of Fractal Antennas and
                      Fractal Frequency-selective Structures Based on Them
                      Abstract| Authors' realized modeling of two kinds of fractal antennas with similar structure, but different algorithms of development. The first antenna geometry is a figure "Life Flower" and the second one is series of crossed circles nested to each other. The obtained results were analyzed and conclusion of the practical applicability for these antennas was made. The obtained theoretical results allow us to conclude that synthesized fractal antennas have multi-band and wide-band features. Besides the direct usage, such fractal structures performed on micron-level may reveal an application in a wide class of new fractal frequency-selective materials and surfaces. The applicability sphere of fractal antennas in modern technologies was shown: cellular communication, wireless information transmission and reception, and radar location devices. Also application filed was described for fractal antennas in modern technology: cellular communications, wireless receiving and transmitting information devices, and radar.
                      Cycles, fractal patterns, and exponential functions
                      If you want to understand the world as a system then you need to investigate three key components.
                      Cycles
                      Fractal patterns
                      Exponential functions
                      Here are some of the authors I have studied
                      Fred Harrison(18 year land price cycle)
                      Nokolai Kondratieff (60 year price/debt cycle)
                      Oswald Spengler - book: "The Decline of the West" (1500-2000 civilisation cycles)
                      Martin Armstrong (8.6 year PI cycle, fractal patterns)
                      Robert Prechter (Elliott waves, fractal patterns, 300 years)
                      Chris Martenson (exponential functions, 10,000 years)
                      Most authors try and model the world with only one of these components. Martin Armstrong was the exception as he used 2 components (cycles and fractal patterns)
                      Winston Churchill said, "The further back you look, the further forward you can see."
                      So why not create a model that incorporates all three components and goes back as far as the Big Bang.
                      Cycles, fractal patterns, and exponential functions - General Discussion and Questions - Forums at Chris Martenson
                      Remember Walter Russell's periodic table, if not see
                        this is is also relevant:
                        If you look more carefully you'll see that the common thread is...:
                        Hubbard Coil Runs Boat On Portage Bay Ten Knots An Hour; Auto Test Next
                        Moray valve
                        "I started my experiments with the taking of electricity from the ground, as I termed it, during the summer of 1909. By fall of 1910 I had sufficient power to operate a small electrical device, and I made a demonstration of my idea to two friends... This demonstration in the early stages consisted of operating a miniature arc light... It soon became evident that the energy was not static and that the static of the universe would be of no assistance to me in obtaining the power I was seeking...
                        Hendershot Motor
                        Hendershot Lived in Michigan Detroit
                        Edward V. GRAY
                        from California
                        Stanley Meyer: Water Fuel Cell
                        Tariel Kapanadze's device
                        In my explanation, I will try totaly to exclude the pressence of the water, as seen in the
                        movie
                        Now one last quote for you guys, from The Great Nicholas Tesla:
                        This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body
                        I'll give you one clue:
                        The human body at about 60% water in adult males and 55% in adult females.
                          one more info i would like to add:
                          Gustave Le Bon: The Evolution of Matter --- Complete text
                          It results, then, from what precedes that the formation of electric aigrettes is accompanied by an enormous production of invisible light. With a high frequency resonator the quantity is so great that illumination of the platino-cynanide can be produced up to a distance of more than 5 meters.
                          Among the causes of error which I must point out, there is one which has never, to my knowledge, been mentioned anywhere, and is of considerable importance. I refer to the superficial alteration of a strip of quartz exposed for less than a quarter of an hour to the sparks of the electrodes. It becomes covered with an almost invisible layer of particles of dust which suffice to render it opaque to the ultraviolet rays inferior to 0.250 microns. When quartz thus altered is used, it is as if use were made of a strip of thin glass, opaque, as we know, to the extreme ultraviolet, and all the effects observed are falsified. This cause of error, which occasioned me much loss of time, is very easy to avoid, since it is sufficient to wipe the quartz with fine linen clothe every 10 or 15 minutes.
                          search quartz on this page (CTRL + F ) Gustave Le Bon: The Evolution of Matter --- Complete text
                          why ? how about this:
                          • #14
                            also related to previous post
                            Kiril CHUKANOV
                            Ball Lightning
                            In keeping with the focus of the present invention, the inventor has discovered that low- dielectric-constant substances are advantageous because of their ability to withstand and maintain high or intense electrostatic fields. As such, dielectric container 150 is preferably comprised primarily of quartz, ceramics, or porcelains, as these provide the necessary electron layer (or dielectric) within the wall of dielectric container 150, thus allowing the wall of dielectric container 150 to serve as one side of the double electron barrier needed to contain the energized electrons (or other particles). In the event the present invention is performed without the use of dielectric container 150, other mediums, for example dry air, which is an excellent dielectric, may serve to create the necessary conditions for generating the quantum macro object of the present invention.
                            Ball lightning has been known to last from a few seconds to greater than 150 seconds. These relatively long lifetimes are one of the most intriguing features of ball lightning as this may suggest that the ball possesses some inherent energy source independent of external sources see post above. On the other hand, some balls have been reported to fade out quietly, while others disappear abruptly, and occasionally with an explosion or by breaking into small fragments. On the whole, observers report detection of no radiant heat from the balls, even when the ball passes by at close range.
                            Kiril Chukanov: Ball Lightning
                            hope you are enjoying this...because i am
                            • #15
                              here is a nice presentation from IEEE - The world's largest professional association for the advancement of technology on quartz oscillator and resonator (use internet explorer browser to view)
                              Quartz Crystal Resonators and Oscillators
                              Quartz Resonator & Oscillator Tutorial
                              also
                              RF Energy Harvesting Design Using High Q Resonators
                              Abstract-This paper presents a new method for rectifying low
                              ambient radiation sources to supply autonomous measurement
                              systems such as microsystems. An impedance transformation with
                              high quality factor (Q) in front of a Schottky-Diode using a quartz
                              resonator at 24 MHz is presented. In addition to an analytic
                              computation and nonlinear simulation of the rectifier circuit
                              with Advanced Design System (ADS) software, the circuit was
                              built and the efficiency of the RF Energy Harvesting system was
                              measured. The design has been optimized to achieve maximum
                              sensitivity. The measurement results show a sensitivity of -30
                              dBm (1 p,W) for DC output voltage of 1 V and an efficiency of
                              more than 22 %.
                              Index Terms- RF energy harvesting, wireless energy transmission,
                              ultra-low-power rectifiers, RF-to-DC conversion passive
                              RFID
