Harvesting Energy From the Sun Using Crystals
    you are correct, to make up for it here is a website that shows how to make one
    caduceous coil experimental handbook and my experiments with it.
    • @petar113507
      check this out Smith Coil (Caduceus )
      Levitationsmaschine-Cetin BAL - GSM:+90* 05366063183 -Turkey/Denizli
      Signs and symbols -Confucius.
      • MM cool site I put it into google translate
        I wonder is the A vector field moving in the aluminum disk, is it attracted to the disc.
        • This makes sense in that if the disk were charged with a electrostatic field the A vector field would be attracted to it. It would boost the magnetic field in one direction causing lift - maybe
          About the time travel- that may be a stretch
          • ZPE
              ZPE
              THE STUBBLEFIELD PAPERS
              your second coil:
              The golden ratio spotted in a magnetic compound.
              Access : Solid-state physics: Golden ratio seen in a magnet : Nature
              Tachionator
                This is one reason why certain scientific investigations in the area of subtle energies cannot be readily replicated. It is not always a matter of scientific protocol, but a matter of relationship. Unfortunately many scientists would consider this to be some kind of inessential and perhaps bothersome epiphenomena. Although such individuals are scientists, to Marcel, they were technicians attempting to prove what they already thought was true. The true scientist is one who attempts to discover with childlike curiosity. Too often we, all of us, only want to confirm what we already believe.
                The word crystal meaning frozen light.
                  what you are seeing is two opposing "drains" connected by the Smith Coil or if you prefer a "white hole/black hole"
                    ZPE
                    translation: Google not me
                    If two coils are connected symmetrically in opposite directions against each other, this is a non-coil inductive.Wenn a current flows through it, one fine Helion it generates a field that shields the front of the room air flow coil. Sealing a room may not be with an external magnetic field lines penetrate filled. It is designated as a shield. This is also known as field Hochst resulting ZPE. This is only needed. Coils are not connected together as the inductive, not disturbing the flow and electromagnetic influences affecting escapes, and the pulsing coil.
                      As happened in his study of luminescence, he found the published technical literature sorely lacking. One morning, as shown in the Kabbalistic teachings. This was a teaching and a pattern with which Marcel was unfamiliar. At the time he saw only the pattern of a rectangle with a triangle at each termination.
                      Tree of Life:
                      As i was searching the symbol Flower of Life, i found this tidbit of info
                      Flower of Life - Wikipedia, the free encyclopedia
                      Tesla and and Leedskalnin had the same opinion...
                      see post: http://www.energeticforum.com/148673-post110.html ;
                      A Vogel Cut Crystal (compare with Dan Winter's vortexer )
                        I got this in an email amazing
                        The Cross in Our Bodies
                        This would make a great coil configuration
                        My Truth
                        new illuminati: ALCHEMY: The Science of Enlightenment
                        The Emerald Formula
                        The foundation of alchemical philosophy and practice is reflected in nature's elements and universal pattern of transformation.
                        7 spheres... (middle picture )
                          Tree of Life:
                          Dave, you should definitely read Vogel's research ...on structured water
                          remember this
                          Resonance transfer occurs because the energy waveforms coming out of a vibrating substance have nearly identical waveforms.
                          • MM Iv been looking at the Testatika machine, could we rotate the wheel around a coil in the A vector field, and collect the field.
                            Or maybe in the middle of these coils
                            I really need to put the bucking fields of a magnet in the freezer, I may get it done tonight.
                              After quite a few minutes looking at the coils, it dawned on me:
                              Felix Ehrenhaft: Magnetic Current --- 9 articles
                              Ehrenhaft and his colleague, Ernst Reeger, have proved that there is more than a little truth in the suspicion that tiny particles of dust tend to rotate when exposed to the rays of the sun. For they have not only reproduced this phenomenon in the laboratory, but they have succeeded in photographing it as well. In order to do this, Ehrenhaft placed tiny graphite particles into a glass flask, from which the air was completely evacuated. Then the flask was exposed to focused beams of sunlight. Instantly a large number of particles were seen to rise from the bottom of the flask and start to weave elliptical, circular and spiral-shaped paths, which were quite visible to the naked eye. The phenomenon ceased as soon as the light was weakened or cut off completely. Photographs taken at one-fifth and one-tenth of a second proved that not only were the particles orbiting, but more significantly, they were spinning on their own axis.
                              Electric and Magnetic Charges ~
                              In subsequent experiments Ehrenhaft established that particles can carry both electric and magnetic charges at the same time as evidenced by their motion in gas or liquid. He theorized that the magnetic charge equaled the electric charge on particles of the same size. In one experiment, the particles rotated around the magnetic current because of their electric charges. Because of their magnetic charges, bubbles moved either upeard or downward. Their resulting path was a helix and could be seen "even by the naked eye to be circulating in a counterclockwise direction, when looking upon the face of the S pole. This movement carried the bubbles downward, even against the force of buoyancy". (Ref. 12)
                              • We're not the first, Pay attention to detail
                                I didnt get the bucking magnets in yet, its hard to get them aligned and keep them there. But I got it.
                                Next Im going to put them in attraction mode, we may explore some new ground after all
