Originally posted by Farmhand
If I put a filament bulb there it glows, and a resistor gets really hot unless it's more than a couple of watts value, the transmission still happens almost the same, but a fluro won't light because the voltage at the bottom of my coils is too low and this stops the transmission like an open circuit.
My transmission stops if I use the filament bulb between the coils. Or it won't light the LEDs, I don't know if it stops completely. Any idea how/why the top of your coil can light a fluoro but the bottom can't?I suppose the behaviour of my spirals are confusing me even more. I mean, I have a bigger diameter on the outside of the secondary than the inside, whereas a helical coil is equal diameter all the way up. So based on that alone I would have thought that with a helical coil you should be able to turn it upside down if you will in a similar way and get more or less the same result, easier than using the bigger diameter outside of the spiral secondary as an output. If you see what I'm getting at.
My main objective is to try determine the frequency the lightning can excite things at. My theory is to get the coil sympathetically resonating with the lightning and measure the frequency.
It's been a while since I listened to Meyl, I'll have to listen again
I guess I can check that to see if it changes it, when I put it back together.
But I'm just experimenting.
