Hi dR,
I can use more power yeah but only by either changing my primary circuit like
Dragon said, less turns more capacitance or by using a higher input voltage.
If I use more everything gets brighter.
It's funny because if there is more load on the receiver the potential drops
and so does input power but the light in the connecting wire gets dimmer.
The thing I also noticed is that I can take the wire from the fluro to the
receiver off and the fluro is lit then only by one wire from the transmitter
much the same. So I'll have to think about that one. Ahah ! Must be the frequency,
mine will go through the bulb without filter "low pass" and not the fluro "high
pass" because I have 480 Khz and your's is opposite because you have 8 Mhz.
Certain filters can allow high frequency to pass but block low frequency that's
a "high pass" filter I think and it's opposite for the low pass filter.
480 Khz is closer to 35 Khz than is 8 Mhz
but not close enough for the
cookie so we will both have to be satisfied with a wire instead for now.
I can go to 24 volts input but more and I will need to change my caps out for
higher voltage ones because the transmitter tank caps gets peaks of 35 or
more volts in it as the scope shots show with a 12 volt input. Also then all my
analogue voltage meters won't be enough for the receiver and things might
burn up. I think I smoked the resistors on the LED board powering it with 120
volts in a 40 volt cap
charged from the receiver. I'm lucky I haven't
blown a cap yet. Iv'e taken 275 volt caps to over 800 volts.
Yes some of these revelations are astonishing. Good stuff. It's also funny how
simple it really is, but how difficult it is to understand and explain.
Hmm I think I need to have a think about all the info we have both gathered
in these observations and ponder.
Thank you for sharing.
P.S. I need to make a list of effects and observations I want to show and make a good video to show them all in one video.
420mA for that? Doesn't look bad at all Can you drive the input with more power? I mean, that's a 25w bulb with 5w input, so what happens if you increase the input.
The bulb is also brighter between my coils than the receiver output, but we seem to have the opposite effect happening. With a bulb between the coils my receiver output is reduced or non-existent, but with a fluoro it isn't really affected. A 1k resistor doesn't really affect it either, the bulb is about 360 ohms if I remember correctly.
but not close enough for thecookie so we will both have to be satisfied with a wire instead for now.
charged from the receiver. I'm lucky I haven'tblown a cap yet. Iv'e taken 275 volt caps to over 800 volts.
I also forgot to mention earlier, I had a bit of an epiphany after playing with an AV plug and LEDs the night I drained the battery. This might be obvious to others already or irrelevant but it suddenly made sense to me and at least helps me in terms of being able to think about it. Walking around the room with the AV plug, I noticed that it was working up to about 8 feet away from the coils. But then I realised I could make it brighter in my left hand by extending my right hand into the field of the coil. So I was clearly becoming a conductor and my body could transfer the energy to light the LEDs. This got me thinking of how to light LEDs remotely with a conductor near the coil, but then that would require wires from the conductor to the LEDs, which would defy the point. And then I realised, THE EARTH. The earth is a "physical body" like mine, it extends to all "remote locations" and in all directions except up, it can touch the terminal of the coil directly where I fear to do so, and it can also be in direct contact with the receiving load, in this case the AV plug.
So I don't know what that means to anyone else, but now I think I'm starting to understand, or at least I have a concept to be able to think about the whole thing.
, then the low voltage winding
But I just tried something with I'll get to because you also mentioned something else...
I think I had the converter tuned resonant to 60 Hz. hehehe
