Alfred Hubbard free energy device need your help
  • MonsieurM
    I know some of you already are aware of this but for those who are not:
    interview with Dr. Tesla from
    Popular Science - Nov 1928 - Page 16
    BESIDES his world power scheme, Dr. Tesla says he is devoting his time chiefly to his vertically rising flying machine. This aerial flivver is to weigh less 200 pound...
    ...On the whole subject of matter, in fact, Dr. Tesla holds views that are startlingly original. He disagrees with the accepted atomic theory of matter, and does not believe in the existence of an "electron" as pictured by science or, he maintains, if it can exist at all, it does so only in perfect vacuum...
    ...Even before the discovery of radium, Tesla expressed his belief that radioactive rays were of this sort, a view ridiculed at that time. When radium was discovered it was found actually to emit particles of matter ....Tesla has maintained ever since that radium is not a generator but a transformer of energy, the emanations being caused by cosmic rays of immense power capable of penetrating all obstacles however thick.
    Popular Science - Google Books
    very interesting read...
    Sometimes we have to go back to the Master himself to find the answer...
  • wrtner
    "household wiring" sounds good but how about : "radio transmitting"
    Do you see now the importance in those two words ? Curious incident erased so important parts or maybe it was someone who did it .... ?
    could not the ---ing word be "resonating" ?
  • boguslaw
    Yes, radioactive battery or ... not that simple
    I agree that Hubbard might have used a bit of radium but that device works also without that , however like in Kapanadze it require then a small amount (40W as Tariel said) of energy to sustain operation.
    Mark my words ! This is all based on the same coil schematic dated back to Daniel McFarland Cook . Apprantly McFarland also used iron contaminated with some slightly radioactive material.
    But stating that radioactive is required is plainly wrong !
    You can add Paul Brown device to the list.
  • teslaproject
    Simple really
    Whether you like it or not, the Hubbard coild DID use a radioactive component in order to achieve OU. Also, it is why nobody can get that Gray tube to work without it either! BOTH need a radioactive component.
    **** A tiny bit of energy to begin with that you 'strike' with a hammer and it 'rings' longer than a dead bit of iron.
    You know that you require some sort of oscillation....a resonance of something that you can harness. Well....if something is ALREADY oscillating (even a little) and then you give it a whack in the right way, this will deliver more energy back than what you put in.
    Radioactive materials are already oscillating which is what makes them dangerous....emitting all those deadly rays.
    Hubbards coil was basically a radioactive battery that would last a long time but it was not perpetual motion because the radioactive material would be eventually used up (even if a tiny piece lasted 20 years).
    Promethium 147 (a byproduct of Nuclear fission) can provide 10 - 20 year battery life by way of beta particle emission harvesting. Other options are Tritium (used in expensive watches and Military illuminated nightscopes). Tritium has a half life of 13.2 years but unfortunately is very expensive and the annual production is pitifully low.
    Paul Browns Resonant Nuclear Battery is very similar to the Hubbard Coil.
    Paul M. Brown: Resonant Nuclear Battery (Nucell) ~ Beta Voltaic Effect ~ Collected papers & US Patent # 4,835,433
  • MonsieurM
    you should add in your title "need help from Seattle" or something like that, it may attract attention from someone living there
  • boguslaw
    Many thanks MonsieurM. I've read it also but now with fresh info it looks better.Of COURSE radium soaking is a myth ! It may work better with radium butstill it's only additional effect.
    Hubbard also stated that Hendershot device is exactly the same as his and I believe him.
    This article you posted is also a strong indication that radio transmitting may be used in Hubbard device.
    Now surprise : I posted that all and asked for help because I believe this Hubbard alone device can explain :
    - Hendershot device
    - Don Smith tabletop device
    - Kapanadze device !
    - many others
    the last two are simply a limited to one transformer coil(s) design !
    Now,when I uncovered very important feeling of myself - do I find somebody from Seattle to help me/help us ?
  • MonsieurM
    The Hubbard Energy Transformer by Gaston Burridge.
    A 1956 article
  • boguslaw
    I bet there were other photos not included in original article.
  • boguslaw
    Not much. I knew that also.
    "During Prohibition, Hubbard worked for a gang of bootleggers and smugglers in Seattle using a cab driving company as a front. He built a "ship-to-shore communication device" which he concealed in the trunk of his taxicab, to aid him in making liquor runs over the Canadian border."
    What really would help is a detective investigation on original newpapers copies .... trying to read what was on unreadable parts.
  • MonsieurM
    Alfred Hubbard Coil Designs
    bio on hubbard
    Unusual Kentucky: Alfred M. Hubbard
    hope this helps
  • boguslaw
  • Slider2732
    +1
    It seems similar to the lock of current within Leedskalnin horseshoe magnet experiments and other devices. The initial spike sets up fields which aren't there without power. Such fields no doubt react with Radium in some exotic way. Probably left well alone for many of us tinkerers - not that I see anyone replicating by using peeled away numerals from an old alarm clock or something !
  • nowatts
    Hubbard Coil
    I believe the missing words were "household wiring", indicating the device was started using standard 110 vac current.
  • wrtner
    This is done by connecting the ends of its windings for a fraction of a second to an ordinary[two words unreadable R.L.R.] -ing circuit, he says. "
    We are looking for those "two words unreadable" and I think it is important info.
    Could somebody help ?
    Can we find the original article and see these unreadable words for ourselves?
    Does anyone live in Seattle and could visit the newspaper?
    A
  • MonsieurM
    If so, and here I am only trying to turn a bad situation into a positive one, With the Fukushima water spill, the Pacific salt water have probably absorbed some of the radioactive elements that could be tested as earth battery,capacitor etc...
    check out rexresearch for inventions concerning isotopes and radioactive elements.
