  • @Rod,
    The ratio follows the often mentioned (on the huge OU forumj thread) 2:1 ratio. The coil being twice as large as the core. However, the magnets are only what I have from hard drives or CD-Rom drives and so that's why you often see a couple more on the back etc.
    The plastic middle former piece that surrounds the core creates a distance to the coil itself. In other words, the coil doesn't sit right on the core, it has a plastic layer between. The bobbins themselves are wound to give a 2:1 ratio and that is about the way they sit anyway with their plastic end pieces.
    I tend to use a small spacer of something non metallic on the backs of them now, after reading about outputs increasing like that. The optimal distance for such spacing to a magnet is, I believe, just at the change over from repulsion of the rotor magnets to attraction of the core. The downside of that, is that the magnets fall off the back unless glued !
    • Do a little break and watch this ‪(Kent Hovind) Creation Seminar 1 - Age of the Earth Part 2‬‏ - YouTube
      Pay attention to one experiment at 5:20 and compare to electrical circuit
      Just a little fresh look
        cool
        • I have changed the magnet to coil Ratio
          I have checked the results many times and will continue.
            <snip >
            Nice work toranarod! Looks like you are tip toeing into Overunity territory.
            • Yeah...are we viewing the .98 in the way we think we're viewing it ?
                ehheh.
                Nice done toranarod, Good Job. And even Slider, to bring it closer. Ty.
                Looks like that can be something to rebuild.
                • This is the new motor setup that has been yielding better figures.
                  There is another coil piggy backing on the iron core behind the litz coil.
                  The small magnets have also provided a much faster RPM as well as more out put verses input. Reducing the coil to magnet ratio was an improvement.
                  Best RPM today 3206, Watts 1.08 Ratio.
                  All other figures still check out. I am a bit restless with the new figures.
                  The hypothesis is? If I can maintain a 1:1 ratio from the drive coil on recovery anything generated by the generator coils is a free bee.
                  I have been working like crazy to assemble my magnet and gen coil ring around the out side of the rotor. All I need to do is extract current from the generator coils so as not to incur any slowing of the rotor.
                  I still have the nine litz wire coil to assemble and a few other improvements to try. you just need to keep on thinking about ways to make improvements and give them a try.
                    i did a little addition exercise, some may think it is useless, but i usually look for a hidden pattern, and you never know what could come out of it
                    I took toranarod values and added them to themselves (ex 16=1+6=7 )
                    anyway here is the numbers for the two first line
                    1/6/2/3/2/6/3/7/3/4/7
                    1/6/1/7/2/5/3/8/8/8/3
                    i may have mis-added, so please double check (did the calculations in my head)...
                    Signs and symbols -Confucius.
                    • Comment
                        I have pages and Pages of these data collections.
                        Maybe I should put them in an excel graph.
                        Would you like to see more?
                        as i mentioned before in other thread the secret is in the numbers, as numbers are but a reflection of reality...do you happen to have the data on when a storm or sun gave an "OU effect" or an unusual effects
                        I'm sure some of you have data lying around, having looked at them from all angles and moved on to adding more data. Maybe you should try the above mentioned method and see what comes out...
                        it's all about translation
                          What I do is control the coil charge up time as coils work like capacitors the more you charge them up the more energy they give back. The idea is not to let the coil reach saturation because this is a waste of energy this is how I fine tune the coils power consumption verse is power out put.
                          This makes it possible to see how efficient a coil can be and test one coil against another.
                          You need to no how long the charge time is and only allow it to discharge until it is reached a point that renders it useless.
                          do you stop at 2 trigger events, and can you go higher (comparing 2, 5, 8 for instance ) ?
                          also, do you happen to know (you could check online) the humidity levels while you were running your experiment?
                          see also: http://www.energeticforum.com/148124-post93.html
                          • efficiency
                            Toranarod,
                            Would it not be more appropriate to change the colum "Ratio in watts / out" into the more commonly used "Ratio out watts / in"?
                            The figures in that colum would then show:
                            .75 (75% efficient)
                            1.01 (101% efficient!!)
                            .93 (93% efficient)
                            Regards Itsu
                            • Originally posted by Itsu View Post
                              Toranarod,
                              .75 (75% efficient)
                              .93 (93% efficient)
                              Regards Itsu
                              yes that will be fine
                              if it makes more sense I will change the presentation of the data.
                              • I have been busy building an adjustable coil slide. It became very important to find the correct distance between the coil and the magnet to achieve running under load.
                                I can short the coil completely out with no apparent loss in speed. RPM stays constant at 2652 RPM.
                                Coil generates 31 volts open circuit.
                                Coil 9mH at 1.1 OHM 250 turns with 0.9mm wire on an iron core.
