For those of you interested in working with laminated cores. I use regular welding rod that I treat. I have a 4" piece of pvc capped on one end with a screw on cap on the other end. I keep it filled with polyurethane.
Tale a piece of steel longer than the 4" opening of the pipe so you can lay it across the top. Stick some neos onto it with paper in between so you can slide them off easier. Lift it up and attach the metal welding rods to the bottom of the steel by magnetic attraction. Be sure to leave some spaces between rods, because you've turned them into magnets that will want to stick to each other, and go SLOW so they don't fall off. Lower them into the polyurethane. You may need to add more liquid to make sure it comes right up to the top and coats the whole rod. If you don't care about reusing your neos for other projects you can dunk the whole thing in the polyurethane, but be warned, it builds up a coating on the steel that will keep the rods from sticking and will have to be removed with a grinder or sanding disk. Remove the rods and let them drip onto something you don't care about. I have a little stand that holds my piece of steel and lets my rods drip onto some newspaper that I can then throw away. When they are dry I will paint the end that was stuck to the steel with a brush and some more polyurethane, and then let them dry again. I'm sure varnish or other coatings would work, but I happen to have this on hand, so it's what I have been using.
