Originally posted by Shadesz
I also think along your lines. It's initially hard to identify what is the root cause because we have so many variables, but observations made by experimenters can help. One observation is high coil current. There are many factors contribute to high coil current like resistance, change in magnetic flux, core, magnet..etc. Luckily, the coil and magnet are not changing in the experiment leaving the rotor speed as the variable. With your reasoning, I think we can made changes to coil/core/magnet size, strength, orientation and that could changes result also. Romero use the sides of the magnet or NS or SN passing the core. I think he just squeezing poles to makes more efficient magnet to achieve result at lower speed. The direction we're going right now is merging on zooty, elias, hoptoad(thanks qvision) and it makes sense. Hope we find something else along the way that reinforce our vision. Once we find the root cause, we can just swing it.
but i never took in to account the resistance of the coil. According to the document, the delay in the core increases as the coil resistance decreases which now makes absolute sense! Drop the resistance of your coil more and more and lenz is offset more and more. Once lenz happens on the on the trailing side of a magnet, it pushes it. I guess core material is of importance here to get the best effect and ferrite is probably not a good choice unless you are going above 6000 RPM. Low frequency core material with good permeability like soft iron is probably a good easy to find alternative.
Sorry.
