Originally posted by Slider2732
Joule Ringer!
Hi folks, Here is the lasersaber/minoly mod for the SSG circuit.
Uploaded with ImageShack.us
peace love light
tyson
edit: had to move the base diode back and place a base resistor at first transistor. Now it looks right.
I fired up my setup, though with only two strands for now and it is working as minoly has said, though I'm using a 1uf-250volt capacitor instead of 10uf. It is drawing 180 milliamps with the 2 coil strands, though I have another to use. It is charging well even with just the two strands so far. Also, I am using 1kohm base resistors instead of 100ohm.Last edited by SkyWatcher; 12-05-2011, 07:20 AM.
Thanks Sky Minoly and allOriginally posted by SkyWatcher View PostHi folks, Here is the lasersaber/minoly mod for the SSG circuit.
peace love light
tyson
did miss the diode in my shopping list so I can start again next week as my day off comes to a clos
thanks
totoalas
peace love light
tyson
SS-SSG Expandable
Patrick etc.,
This thread is going wonderfully far afield. I'm loving the different variants being explored.
I took Blackchisel's schematic of the Bedini SS-SSG that you referenced and tried to see if I could expand it to a multi-coil setup.
In all my experimentation, expanding an SS-SSG to multiple coils with just one trigger has been a bit of an issue.
I've looked at a lot of setups and this is by far the best.
Patrick, thanks for opening my mind!
Using the Bedini / Welcome to Renaissance Charge - SSG PCBs. Multiple coils can be added with just one trigger.
The boards/coils can be chained.
I made a video showing this.
SS SSG setup can be expanded.mov - YouTube
Does anyone have any thoughts about the signal variation between the two coils?
They seem to sync up at the sweet spot?
The 18 gauge wire requires (as BlackChisel shows in his schematic) a 20K resistor from the master coil B to C and a 10K from the B to E, to oscillate without allowing too much current to be used.
The system gets hot at half of those value and runs too fast at twice those values.
The system shows what Patrick confirmed about the SS-SSG charging 6 big batteries from one small one.
Didn't John Bedini have independent testing to confirm he was fully charging 12 batteries from 1?
I thought I added the Blackchisel schematic to the end of my vid but it seems to have dropped off. It was referenced a couple of pages back.
Here it is again.
Thanks to all for this very dynamic thread.
StephenPotential, is a terrible thing to waste.
NICE Stephen!Originally posted by Stephen Brown View PostPatrick etc.,
Here it is again.
Stephen
I like all your explanations it cleans it up.
It's crazy how simple this is.
well almost...
I also forgot all about the extra resistors on the first "trigger" transistor when I was looking at Tyson's drawing...
It will be nice to have JB's comparator ckt added to this.
Patrick
Originally posted by altrez View PostGed,
I have a small 150 watt inverter that is powered by 4 small 7aH 12 v SLA Battery's and charged by two 18 watt panels to keep the battery bank topped off.
It has 5 2 watt LED lights running from the inverter perfectly. I can also charge a cell phone and power a radio and laptop all at the same time at right around 85 watts use.
The battery bank gives me 28 amp hours. I get right at 1.2 amps on the panels some times more some times less. The draw on the hot side of the inverter is right around .230mA
Total pull from the battery under heavy use is about .635mA
The whole setup cost less $100 and could be done for under $50 if you shop around.
My goal with the Joule Thief / Ringer is tie them into the hot side of the inverter with a step down adjustable power source. That way hopefully one day I can run a whole lot more lights
The plan is to take one plug-in from the surge strip and use it to power all my Free Energy projects.
So for example I have plunged in a battery charger and used it to power a JT that can run 200 leds. It only cost me 60 mAs extra.
That I feel is where this tech will really shine.
-Altrez
Thank you for your comprehensive response.Nuff said.
Best regards,
Ged.
Flip Flop.
I just bought and sucessfully built a $7 Velleman Intermitant LED flasher circuit from Radio Shack. This circuit is identical to the first part of the "French Inverter" astable multi vibrator circuit. The componants included are: 4 resistors, 2 capacitors, 2 transisters and two trimmer pots that wire in series with the high value resistors. These two trimmer pots allow one to vary the transistor base tank resistance and control the frequency of the intermitant flashes, so exactly 50 or 60 Hz can be dialed in conveniently.
Can anyone tell me how I should go about connecting the Mosfets to the LED electrodes, to wire the Velleman circuit like the "French Inverter"? This addition should allow me to fine tune the inverter Hertz with a very high degree of precision, and help maximize efficiency! I think just one 1K pot wired in between the positive rail and the junction of the high value resistors, in the "French Inverter circuit, would help the same way. The addition of the voltage regulator makes a very versatile inverter, capable of running European and Japanese equipment in a broad range of power settings. I don't think anything this sophisticated is available in the market place currently.Last edited by Allen Burgess; 12-07-2011, 02:53 AM.
Hi folks, I have setup a four battery parallel charge bank for testing, each are 12volt-7AH-SLA and using one 12 volt-7AH-sla primary battery to charge them.
I hope to be able to fully charge these with the one battery.
A first partial test charging two has proved promising using my ferrite core, 7 strand coil, though only using three strands, one trigger at the moment, until i get more transistors.
This setup for some reason is performing better than any setup I've built previously.
Usually in past experiments, when using an identical voltage source battery, it tended to be a more fluffy charge.
Though this setup provides solid charging, as a 12volt taillight bulb as a load test proves, the voltage bounces right back to its previous level and this result from only 23awg magnet wire.
Something must have been a bit off with the past radiant spike devices I've built when using identical voltage as a primary source.
peace love light
tyson
Hi Tyson,Originally posted by SkyWatcher View PostHi folks, I have setup a four battery parallel charge bank for testing, each are 12volt-7AH-SLA and using one 12 volt-7AH-sla primary battery to charge them.
peace love light
tyson
Now were going somewhere with your results
lol
Just finished my 6 strand 23 awg magnet wire ......
Hi Minoly,
as for the 3300 uf cap , Hope you can give the termination points
in my joule thief with 6 parallel 2n3055 , Im using a triac BT 41 and 2 dc capacitor for fast charging 12 v car battery..... still looking for my old schematic
With solar cell input, can somebody give a rough size / amperes required
In China they sell for Renminbi 1000 for a 24 W solar panel / dc charger for 650
Altrez mentioned 2 18 w solar cells
My load to be used one lcd tv 24 inches one amplifier for audio one computer desk top one lap top home lighting one ceiling fan
cheers
totoalas
lol
Hi Minoly,
cheers
totoalas
totoalas,
Can you list the watt usage for each device you want to power please.
-Altrez
Hi AltrezOriginally posted by altrez View Posttotoalas,
-Altrez
Below are some rough estimates minimum load that are currently available for connection to the solar panel / battery
Denon Amplifier 50 watts
Lenovo Desktop + 18 inc lcd display around 15 watts
LCD TV 20 watts
Lighting 30 watts
Ceiling fan 30 watts
lap top 10 watts
all are 220 v ac 50/60 hz
thanks for your support as I am eager to buy the 24 watt panel but in doubt
for the size and quantity
I have two car batteries 12 v 70Ah that will be used .....
thanks again
totoalas
