You are welcome. I would still use the same components, especially the rod and same amount of turns, and same type of 110v led bulb, on 12v., not 24v. If you keep a finger on the transistor, that will let you know if it is going to fry or not, before it does so. If it's untouchable it is not going to work for long.
Here is a picture of the 3 inch ferrite core from my old crt monitor. This should work as well as the rod, and it's free.
Slider: It may also be possible to just add more secondary turns to the same radio core, as I'm about to do, as just one layer is not much compared to the amount of turns that some transformers use to up the voltage.
But, having 3 of the 3 inch radio cores glued together for a 9 inch core might work well, also.
I don't quite understand why Skywatcher was not able to get his working, even without the ferrite beads it should work to some degree just from the windings as if it were an air core.
Totoalas: I can see you in the background, so, what do you think...
