Originally posted by rozier56
what do you mean? your groove is milled all the way to the center?Originally posted by rozier56 View PostThe female bottom flange is cut 20mm deep with a 10mm round groove machined through center.
so your rope goes circles allot of times all the way to the center for a tight fit?
Or just 1 circle and compress?
also how do you compress a female 10mm groove with a 10mm protrude male with the 10mm graphite gasket?
What I understood:
Example
I have a 4 inch outer diameter ring flange male female.
female 20mm deep 10mm milled at 3inch going to 1inch then hole.
male on the 3rd inch i protrude 10mm and 2.5inch to 1inch I fill with a graphite rope 10mm (square) until I reach my desired hole of 1inch?
Derek`s problem is that he installed a new diesel burner, now it performs too well compared to the lpg gas burner and his measurements is all out of sync, so the reflux need to be adjusted if he cannot adjust the diesel burner in the correct way.
Waxing was described in detail, why it occurs and what to do to fix it.
I was caught up for awhile in a new relationship, but now I can focus my attention here again.
My prototype is almost finished, I must just do the insulation, connect my exhaust heat with my reflux chamber and with my first condenser and connect all the pid controllers and the temp probes, then I can start the system for the first time and test. Before I start my first run I will put it under a pressure test to see if the system is leak proof.
I`m going to get all the welding done by professionals as my welding will not be up to standard. Once this is done I will post some pics.
As I go I take pictures to record my progress and for the satisfaction it gives just to see what you accomplish.
The system will deliver between 80 and 86 liters per run, this one will be a batch system.
Originally posted by VAST View PostDerek`s problem is that he installed a new diesel burner, now it performs too well compared to the lpg gas burner and his measurements is all out of sync, so the reflux need to be adjusted if he cannot adjust the diesel burner in the correct way.
ThanksOriginally posted by torak View Post
Got me thinking now.. That's a much bigger setup to what I am trying to build.. What is the white material that was between the lid and the cylinder?
Thanks for that.. What valve are you referring to?? Should I install a directional valve right after the Reflux and attach a vacuum to that? but then how will I vacuum the rest of the system during operation? I was under the impression that I would install a vacuum at the very end of the system after all the condensers and bubblers etc..?Originally posted by wheels View PostDon't worry about sucking out too much. Providing you have a solid containment vessel and everything is Air tight, the a maximum vacuum can be pulled and the Oil will stay put in the bottom of the vessel. The more air you can pull out, the better and safer everything will be. One really big plus with having a good vacuum is that you lower the boiling point of everything. That will not be of concern with the Oil as the pressure should be neutral by the time the Oil gets up to temperature. But it will aid in removal of water at a much lower and earlier temperature. It would be helpful to have a Vacuum gauge of course and basically vacuum the Air out, then watch the gauge and when it has returned to zero, you can open the valve to allow the Gas to flow. Remember to close the Valve when vacuuming, or you will suck all your Bubbling water back through the system and maybe into the Compressor Pump.
One wee tip, reduce the oil level in the compressor pump a little. Not essential, but when you use it as a vacuum pump, it can pick up some of that oil and blow it out the outlet. It shouldn't do any damage, just annoying.
You are going to need a Valve placed just before the bubbler, or you will suck the water back through everything and into the vacuum pump. If the Bubbler is the terminal end to the plant, then you might get away with a valve right at the end. But realize that the air in the pipe work after the bubbler will be sucked out and so that will cause water to suck through with it.Originally posted by MangiPNG View PostThanks for that.. What valve are you referring to?? Should I install a directional valve right after the Reflux and attach a vacuum to that? but then how will I vacuum the rest of the system during operation? I was under the impression that I would install a vacuum at the very end of the system after all the condensers and bubblers etc..?
WMO tends to produce vapors well before the flash point is reached. Those Vapors will displace oxygen in the tank and pipe work. WMO also does not have properties that react with oxygen to create nasties like Dioxin. So a small amount of Oxygen in the tank before it reaches the vaporizing temperature is fairly safe.
This is unlike Plastics which will react in a low oxygen environment and produce Dioxins. Plus many plastics vaporize at close to the Vapors flash point and an oxygen rich environment is asking for trouble.
graphite rope, usually used as seal for wood stoves doorsOriginally posted by MangiPNG View PostThanks
size of retort can be modified, just give you idea how to do it without flange.
hi, check out album i post before, hopefully that's give you idea, i think it is same principle as rozier56 described, but this one is welded together from metal pates.Originally posted by chacowako View Postwhat do you mean? your groove is milled all the way to the center?
What I understood:
Example
Be very very cautious of Graphite rope or any similar high temp rope or fibre, synthetic or Glass fibre materials. It will leak Gas. The Gas that comes off is Hydrogen and will find it's way through the smallest of gaps. We are talking microscopic here. Any fibre materials will not stop it. Even bolted down tightly, the gaps in the fibres are large enough for hydrogen molecules to pass through. You MUST have a solid seal.Originally posted by torak View Postgraphite rope, usually used as seal for wood stoves doors
welcome to the league of sucessful DIY fellowsOriginally posted by chacowako View Post
My first try had to stop half way through because of leakage.
this is 100%pp strange why its yellow?
isnt pp black?
your o/p sample looks nice whether you use any catalyst or simple thermal pyrolysis
