Whereas, the reason why the Spanish commercial WMO recycling refinery, has a fairly clear end product is they are most probably triple distilling it. So, I am currently rebuilding my WMO distillation system to accommodate a number of improvements which will include triple distillation and fractionation on the fly.
Originally posted by rozier56
Originally posted by cornishscrimper
Excalibur's comments should be noted carefully. Any valve is going to goop up if it is high up the stream closer to the boiler. However, down stream after cooling the fluid below ambient would work fine as a place to put a check valve. The check valve should be as low a pressure as possible, such as one used for an oxy-acetylene torch.
/ Thanks again
I expect we would have an explosive flame exiting the PRV. So...
