Solar Charging/Pulsing Circuit and Variants
  • #16
    Here's the swapper video, I realised while making the vid that it's wired wrong, different to the drawing, but it works just different, i'll make a drwing of how it is now, when I work that out. Then i'll wire it like the drawing and try again.
    Hope that makes sense.
    YouTube - AlternateFarmhand1's Channel
    • #17
      Farmhand Battery Swapper Slayer Circuit Self Runner
      Hi jbsolar, and welcome to the forum welcome also to automan, and thank you all for the kind words.
      I have good news, I found my baby rooster this morning. Guruji made me think I shouldn't give up on it so easily and assume the lump I seen in the snake was it, So I look and look and I find him he was stuck under a upturned water tub. I am so happy about that. Thanks Guruji if it were not for you his fate would have been worse than being eaten.
      Anyway my visitors got to laugh at me before they left.
      Last night I dragged my little toy three pole Bedini out to demonstrate to people so I make a small video, it has some pretty lights and spins pretty fast.
      I am determined to demonstrate the battery swapper today, I have finally got a firewire connection in this computer, for better vids hopefully.
      Totalas I have been thinking that with an exciter in your circuit you would maybe be able to use a "plate P" setup, a (Tesla radiant energy receiver) instead of a solar panel. I don't really know but I think the exciter would make it work better than normal. It might not work good enough but I think it should be tried. I get good results putting mine near a AC Flouro, enough to charge a 6v battery very slowly. It may even be able make the setup self sustaining.
      It's a fine day today.
      Cheers all.
      IMG] Uploaded with ImageShack.us[/IMG]
      hi Farmhand
      Self sustaining and self runner The GOLD MEDAL of the Exciter Circuit
      A lot of ways to charge battery but no feedback/ charge /regulation/mechanism to the source
      Yours is the answer to our prayers Allelujah Buddy
      Any kind of power source let it be solar wind radiant energy Bedini and even HHO will solve half of the worlds climate change
      Thanks to you guys in the forum
      Let the fun begin
      cheers
      totoalas
      • #18
        I'll try to make a drawing later tonight, I would like to try this as well with a simple exciter circuit, as simple as possible so I can get some results quickly as an indication. I really don't know if it would work. Maybe someone with an exciter could try a small experiment soon ?
        I think I have some sketches of an appropriate circuit here to go by. It's all in my head too but sometimes I forget some minor details. I nearly always get it wrong the first couple of times.
        There is one thing. A good earth stake will most likely be needed. There might be a way around that too if thats impossible.
        It was just an idea it doesn't hurt to aim high to start with we might get lucky. A piece of aluminium is much cheaper than a solar panel. There is always the solar cell to fall back on of course.
        Here's a sketch of kinda what I had in mind, the neon would need to go and a low voltage zener used with another diode to charge a 1.2 / 1.3v battery, It works on a six volt battery I tried it, it charged to 6.4v but thats all. There are probably other ways to do the switching as well.
        http://public.bay.livefilestore.com/...001.JPG?psid=1
        Now if the plate "p" was a pyramid shape and near the exciter. Nah just kidding, I like pyramids, it would look neat if it worked as a pyramid shape, that would Sweet.
        Actually with an exciter lighting lights completely wirelessly this should be easy, however i would advise precautions be taken incase of unexpected results ie higher than expected voltage or current, I would begin by short burst's if measurements are incremental or monitor it. We can only hope.
        I only urge caution because I am not familiar with exciters, those that are, will know whats safe much better than me of course, but I had to say it.
        • #19
          Alive
          Hi Farmhand I was happy that the chicken is still alive and you continued to search for it. That's the true spirit. Perseverance
          Totoalas interesting that video of the fan modification. I had one but in the past but now destroyed it cause I thought that it cannot be modified to a genny Ok thanks guys for the info that you're sharing.
          • #20
            Joule Theif Evolution; The Eternity Light Project
            YouTube - Inquorate's Channel
            Hi Farmhand
            I think youll like this
            cheers
            totoalas
            • #21
              Circuits
              Hello all,
              I've been messing around for a while with a very simple circuit to pulse a battery from a solar panel and make some better use of low light days (cloudy).
              Here is the basic circuit.
              http://7iprpq.bay.livefilestore.com/...c-2.bmp?psid=1
              The SCR capacitor arrangement allows the solar panel to keep the capacitors a couple of volts over the battery even in continuous conduction mode when the SCR does not switch off, in low light when the caps fill very slowly the SCR switches off and on and the circuit pulses the battery with amplified power up to 5 or 6 X, eg with 50Ma from the panels this setup pulses out up to 300Ma.
              It's quite simple and works pretty good I have this basic setup boxed up so I can use it as a portable charger with a small solar panel.
              I have played around with ways to force the SCR to commutate (switch off and on) and came up with the idea of adding an trifiler oscillator with capacitor discharger to the output of the original circuit which works very well and also allows the oscillator output to used alone.
              Here is the final circuit that i'm using now minus the led I havn't tried that yet.
              The oscillator source battery can be recharged from the panels, the capacitor dump voltage can be adjusted by the zener selection, the oscillator has frequency/power control, the SCR cap dump on the charge side of the oscillator has not been tested yet because I use a cheapo charge controller there but I think it will pulse charge the oscillator source battery as well when the oscillator is running.
              The setup is self regulating to a degree in that when the oscillator is running and the setup is pulsing, the battery will stop charging at the desired voltage if the correct zener is selected eg. if the panels can only put out 20 volts max and the voltage drop caused by the zener the 1N5408 diode and the SCR gate trigger voltage equals or exceeds the difference between the battery voltage and the panel output voltage the panels can't raise the cap voltage high enough to dump so the solar power is blocked and the battery is trickle charged by the oscillator. This feature can also be used to equalise a bank by selecting a lower value zener.
              I also made a battery swapper with load dump to go with it, it still has a bug so I have not labeled the zener value's and relay working voltage ratings yet.
              It works ok but the zeners get warm so power is leaking where it shouldn't.
              http://public.bay.livefilestore.com/...1.0.bmp?psid=1
              Here's some video's they are not good I will make a better one later.
              Any idea's too improve or vary this circuit or add to it are welcome. The oscillator I use is a variant of John Bedini's design the SCR cap dump is old hat. I think that covers it so far.
              Edit. I should add that the capacitors in the basic circuit could be any suitable value or number of caps you would wish or need, the zener on the SCR gate could be replaced with one or more 1n5408 diode's or a different diode or diode's could be used there and used in different combinations, a triac or even a mosfet could possiblly be used instead of the SCR anything is possible if it works.
              Cheers all.
              Hi Farmhand can you please post those schematics a little bigger cause they're too small.
              • #22
                Hi all, very sorry about that, accidentally removed wrong pictures from my space, will upload them again as soon as possible. My mistake just another funny error on my part. Very busy today probably about 4 to 5 hours.
                I don't know how I went wrong, they are upgrading windows live blogs to something else and I was attempting to move my pics to a different location, but i ran out of time. I'll fix the links above and all as soon as I can.
                Once again very sorry about that. I'll fix it.
                Cheers all.
                Farmhand
                • #23
                  Ok fixed the links above. I'm not as computer savvy as I would like to be I can't work out how to make it so the thumbnail attachments open up big. Any hints on how to do that ? I won't change any attachments till I work that out.
                  Any way I have a lot of links to fix now, how embarrasing. I'll do the best i can as quickly as I can.
                  Sorry folks monumental mess here, it seems my computer is just as messy as my work bench.
                  If anyone wants a drawing linked or fixed just let me know.
                  • #24
                    Image attachment
                    Hi farmhand
                    imageshack and yahoo flkr they are all great link tools
                    e too i want to start on your voltage swapper ad auto oltage regulator from solar panel
                    thanks
                    totoalas
                    • #25
                      Good stuff
                      Nice thread. I love it when people make useful projects
                      • #26
                        Hi Inquorate, Thanks mate, I was inspired by a drawing you posted here somewhere actually, showing a relay cap pulser, and you also posted the method for the SCR as well I think in that same thread, very helpfull. And so while I was trying to devise an alternating relay pulser, I decided it was too difficult and decided to go this way.
                        Mine is still working very well, it will take some tuning of the setup to work in different ways. But it works. Though I get the feeling it does restrict the energy flow a bit at higher throughputs. At lower throughput it improves the flow in my opinion. Well thats the idea.
                        So has anyone had any success with it yet? Anyone tried a different switching method?
                        Totoalas I havn't had a chance to rewire the battery swapper yet, but I think it will work ok, on mine I used 5v relays with a 100 ohm fixed resister in series with a 5.6v zener diode the 5k trim pot and the relay coil (the 100 ohm fixed resister is not shown on the drawing and is probably not needed anyway).
                        The theory is the 5v relay has less resistance than a 12v one so the 100 ohm resister is to make up for that. I'll rewire mine test and edit the drawing when I get time.
                        Cheers all
                        • #27
                          An innovative capacitive voltage doubler
                          pulser circuit, principally for battery desulfation,
                          has been developed by Mark at the Desulfation
                          Forum. See it here:
                          Voltage Doubler Pulser
                          With just a little modification it would lend
                          itself well to a Solar Charging application.
                          As is, it is an efficient self-powered desulfator
                          for keeping lead acid batteries in top condition.
                          • #28
                            farmhand circuit
                            Hi Farmhand so in moonlight do you manage to run the oscillator? Cause yesterday I tried to see what voltage is coming in full moon and it was only 0.3v measured on my panel
                            • #29
                              Hi Guruji,
                              No I haven't been able to get anymore than that either, Apparently if the trigger is inverted, it can work like that, I tried it but I think I may have done something wrong because my transistor got so hot at 12 volts input it burned a blister on my finger when I touched it. Post #61 in the thred below has the patent number for that setup. I got it to work but it got very hot at 12 volts I think i did something wrong, I guess I must have. Do you have your setup working ?
                              http://www.energeticforum.com/renewa...battery-3.html
                              Seamonkey you are a very helpfull, Thank you that looks good. I haven't had a chance to build the cmos desufator yet but I am very close to starting the circuit I have the 4001 chips, when I start I don't stop till I finished, so I can keep my mind on the job.
                              Got another big battery online now.
                              For those reviving old batteries with a radiant spike device , I noticed that if there is any trace of electrolyte on the top of the battery it conducts the radiant puses outside the battery from one terminal to the other, I was measuring 9 volts on the plastic case inches from the terminal, both probes at once. So what I did was washed the battery with soapy water and rag then scrubbed it a bit with baking soda in solution, problem solved now no voltage reading outside of the battery. I think it making problems for the restoration of that battery.
                              • #30
                                moonlight
                                Hi Guruji,
                                Hi Farmhand no I'm using a JT to pulse my battery and needs about 150ma least to oscillate maybe I will try the stingo now but as I said 0.3v are too low to work with.
