Hello all,
I've been messing around for a while with a very simple circuit to pulse a battery from a solar panel and make some better use of low light days (cloudy).
Here is the basic circuit.
http://public.bay.livefilestore.com/...c-2.bmp?psid=1
The SCR capacitor arrangement allows the solar panel to keep the capacitors a couple of volts over the battery even in continuous conduction mode when the SCR does not switch off, in low light when the caps fill very slowly the SCR switches off and on and the circuit pulses the battery with amplified power up to 5 or 6 X, eg with 50Ma from the panels this setup pulses out up to 300Ma.
It's quite simple and works pretty good I have this basic setup boxed up so I can use it as a portable charger with a small solar panel.
I have played around with ways to force the SCR to commutate (switch off and on) and came up with the idea of adding an trifiler oscillator with capacitor discharger to the output of the original circuit which works very well and also allows the oscillator output to used alone.
Here is the final circuit that i'm using now minus the led I havn't tried that yet.
http://public.bay.livefilestore.com/...1.4.bmp?psid=1
The oscillator source battery can be recharged from the panels, the capacitor dump voltage can be adjusted by the zener selection, the oscillator has frequency/power control, the SCR cap dump on the charge side of the oscillator has not been tested yet because I use a cheapo charge controller there but I think it will pulse charge the oscillator source battery as well when the oscillator is running.
The setup is self regulating to a degree in that when the oscillator is running and the setup is pulsing, the battery will stop charging at the desired voltage if the correct zener is selected eg. if the panels can only put out 20 volts max and the voltage drop caused by the zener the 1N5408 diode and the SCR gate trigger voltage equals or exceeds the difference between the battery voltage and the panel output voltage the panels can't raise the cap voltage high enough to dump so the solar power is blocked and the battery is trickle charged by the oscillator. This feature can also be used to equalise a bank by selecting a lower value zener.
I also made a battery swapper with load dump to go with it, it still has a bug so I have not labeled the zener value's and relay working voltage ratings yet.
It works ok but the zeners get warm so power is leaking where it shouldn't.
Here's some video's they are not good I will make a better one later.
http://public.bay.livefilestore.com/...1.0.bmp?psid=1
YouTube - AlternateFarmhand1's Channel
Any idea's too improve or vary this circuit or add to it are welcome. The oscillator I use is a variant of John Bedini's design the SCR cap dump is old hat. I think that covers it so far.
Edit. I should add that the capacitors in the basic circuit could be any suitable value or number of caps you would wish or need, the zener on the SCR gate could be replaced with one or more 1n5408 diode's or a different diode or diode's could be used there and used in different combinations, a triac or even a mosfet could possiblly be used instead of the SCR anything is possible if it works.
Cheers all.
Cheers all.
it's new to me. This time I managed to not say hello folks at the start but there's still a lot of umms Sorry, not many ahh's though.
I used a digital current meter on the output to show some numbers.
I labeled them on the first drawing for those like me who are easily distracted and confused.
It will be a good feed for it, it was a hybrid meat chicken and was to be my new breeding rooster. That one snake has set back my breeding program by six months.
he was stuck under a upturned water tub. I am so happy about that. Thanks Guruji if it were not for you his fate would have been worse than being eaten.
